problem for use remap
- mahdi2001h
23 Jun 2020 07:56 - 23 Jun 2020 08:22 #172445
by mahdi2001h
Replied by mahdi2001h on topic problem for use remap
thanks alot for your reply
I checked your code
but my problem not solved
also I using Sim with remapping setup and add a line for log to terminal
And I saw the same problem there
I will tell you my problem again
when linuxcnc opening the ngc file , in one step all remap function run
and when maching start , in a moment all remap python function run
in fact I want to remaped a g-code to send a serial command by python
and the G-codes should run in own place but its not worked
i think when first run (when ngc file open) is for draw shape for preview and can solve it with check machine power status
but for second run i don't know what should to do
I checked your code
Last edit: 23 Jun 2020 08:22 by mahdi2001h.
- Thank you received: 2164
23 Jun 2020 09:18 - 23 Jun 2020 09:19 #172453
Replied by Aciera on topic problem for use remap
Do you mean that these codes for G70 and G70.1 are running without being called?
def g700(self, **words):
s.poll()
if s.estop == 0:
print "test p =" , words["p"]
return INTERP_OK
def g701(self, **words):
s.poll()
if s.estop == 0:
print "test1"
return INTERP_OK
Last edit: 23 Jun 2020 09:19 by Aciera.
- mahdi2001h
23 Jun 2020 09:34 #172456
by mahdi2001h
Almost
For example in running this code:
in machine start , first printed on the terminal output
and after this The rest of the gcode runs
G70 P1
G0 X[26.55859*#<scale>]
G1 F100.0 Z[-#<depth>]
G1 F400.0 X[29.59375*#<scale>] Y[15.01953*#<scale>]
G1 X[33.3125*#<scale>]
G1 X[32.92969*#<scale>] Y[13.13281*#<scale>]
G2 X[34.16342*#<scale>] Y[14.08624*#<scale>] I[8.82141*#<scale>] J[-10.13994*#<scale>]
G2 X[35.52734*#<scale>] Y[14.8418*#<scale>] I[4.53823*#<scale>] J[-6.58354*#<scale>]
G2 X[38.08398*#<scale>] Y[15.36133*#<scale>] I[2.53506*#<scale>] J[-5.9247*#<scale>]
G70 P2
G2 X[39.5966*#<scale>] Y[15.13543*#<scale>] I[0.06403*#<scale>] J[-4.74845*#<scale>]
G2 X[40.90039*#<scale>] Y[14.33594*#<scale>] I[-1.02874*#<scale>] J[-3.14049*#<scale>]
G2 X[41.7019*#<scale>] Y[13.08328*#<scale>] I[-2.33045*#<scale>] J[-2.37388*#<scale>]
G2 X[41.93945*#<scale>] Y[11.61523*#<scale>] I[-4.07102*#<scale>] J[-1.41199*#<scale>]
G2 X[41.76899*#<scale>] Y[10.15744*#<scale>] I[-10.17473*#<scale>] J[0.45091*#<scale>]
G2 X[41.48828*#<scale>] Y[8.7168*#<scale>] I[-39.45138*#<scale>] J[6.93932*#<scale>]
G1 X[39.7793*#<scale>] Y[0.5*#<scale>]
G1 X[35.85547*#<scale>]
G70 P3
G1 X[37.57813*#<scale>] Y[8.74414*#<scale>]
G3 X[37.79665*#<scale>] Y[9.84001*#<scale>] I[-62.81729*#<scale>] J[13.09579*#<scale>]
G3 X[37.96094*#<scale>] Y[10.94531*#<scale>] I[-9.6524*#<scale>] J[1.99958*#<scale>]
G3 X[37.50977*#<scale>] Y[12.12109*#<scale>] I[-1.54162*#<scale>] J[0.0829*#<scale>]
G3 X[36.2793*#<scale>] Y[12.55859*#<scale>] I[-1.13356*#<scale>] J[-1.23903*#<scale>]
G70 P4
test p = 1
test p = 2
test p = 3
test p = 4and after this The rest of the gcode runs
23 Jun 2020 12:57 #172466
Does this also happen the same way if you use simple numerical positions?
Like:
G70 P1
G0 X10 Y10
G70 P2
G0 X20 Y20
G70 P3
G0 X30 Y30
G70 P4
Like:
G70 P1
G0 X10 Y10
G70 P2
G0 X20 Y20
G70 P3
G0 X30 Y30
G70 P4
- mahdi2001h
23 Jun 2020 15:58 #172480
by mahdi2001h
yes
same problem
same problem
- MaHa
- Thank you received: 240
23 Jun 2020 16:11 #172483
by MaHa
Replied by MaHa on topic problem for use remap
Once i had a similar problem, solved it by adding M66 E0 L0 next line after call G70
The following user(s) said Thank You: Aciera, mahdi2001h
23 Jun 2020 17:14 #172486
This is beyond my scope I fear. We will have to wait for somebody with more programming experience.
The following user(s) said Thank You: mahdi2001h
- mahdi2001h
23 Jun 2020 17:14 - 23 Jun 2020 17:16 #172487
by mahdi2001h
Nice! it worked
thanks a lot of MaHa .
but why should use this!?
in normally , don't think should use this!
also thanks a lot of Aciera for your attention.
Last edit: 23 Jun 2020 17:16 by mahdi2001h.
Time to create page: 0.149 seconds
