The question of proper threading
  • pkasy
  • pkasy's Avatar Topic Author
  • Premium Member
  • Premium Member
07 Jul 2020 13:49 #173836 by pkasy
The question of proper threading was created by pkasy
Hello.
I have been using the system not so long ago, maybe since 2014, and I cut a lot of threads. And I was always wondering why they do not always turn out smooth? What settings should be on the lathe, which encoder, what rotation speed?
I tried to increase the distance in front of the thread to stabilize the speed. I tried to exit the thread a multiple of the thread pitch and the length of the thread a multiple of the thread pitch.
it still turns out very badly.
Please teach me how to cut the thread correctly.
  • pkasy
  • Premium Member
  • Premium Member
09 Jul 2020 06:43 #174059 by pkasy
Replied by pkasy on topic The question of proper threading
the simple question, why does the tool pause before the exit taper?
09 Jul 2020 07:46 #174062 by Clive S
Replied by Clive S on topic The question of proper threading
I think it might help if you gave more info ie. Do you have an encoder onthe spindle for A+Z and post your ini and hal files with the Gcode you are using to thread with.
  • pkasy
  • Premium Member
  • Premium Member
09 Jul 2020 08:23 #174073 by pkasy
ok.
I have same problem at all my different cnc lathes.
It does not depends on one exacly machine.
Spindle has encode ABZ 2500 ppr.
GCODE:
G76	Z[-#<Len>+#<startZ>] P[#<P>] I[-#<I>] J[#<FC>] K[#7*2] H2 L[#<Taper>] E[#<TaperL>] R1.5 Q29.5
Hal:
File Name: TR_2020-07-09.hal
File Size:11 KB
It looks to me as working with G61 - tool stopped before exit taper.
If I put G64 P0.25 - it moves much better.
But who cut threads with G64?
  • pkasy
  • Premium Member
  • Premium Member
10 Jul 2020 02:53 - 10 Jul 2020 06:19 #174178 by pkasy
here is a EMC code:
START_SPEED_FEED_SYNCH(pitch, 0);
 if(taper_dist && exit_taper)
   START_SPEED_FEED_SYNCH(taper_pitch, 0);
so in my case taper_pitch < pitch, why?
cutting feed is 600 mm/m as I see at Axis, but at tapper feed is 300 mm/m (about).
but they must be same, right?
Last edit: 10 Jul 2020 06:19 by pkasy.
  • pkasy
  • Premium Member
  • Premium Member
14 Jul 2020 23:33 #174670 by pkasy
G76 doesn't seem to use an encoder to move. I tried to rotate the spindle with my hands on the engine turned off. The EMC waits for a full turn and jumps. and not always.
  • Moderator
  • Moderator
15 Jul 2020 08:16 #174695 by tommylight
Replied by tommylight on topic The question of proper threading
That does not seem right.
Can you do a video of that while monitoring with halshow encoder inputs ?
  • pkasy
  • Premium Member
  • Premium Member
15 Jul 2020 23:34 #174780 by pkasy
the video turned out to be of poor quality, since there is no tripod for the phone.
but here is a screenshot of the signals from the encoder when I rotated the spindle by hand. as you see, everything works.
but the cutter stands still and waits for something. sometimes jumping, sometimes follows.
16 Jul 2020 06:35 #174806 by Clive S
Is the encoder counting the correct way ie is it increasing +ve when turning the spindle
The following user(s) said Thank You: pkasy
  • pkasy
  • Premium Member
  • Premium Member
16 Jul 2020 08:10 #174812 by pkasy
that's a very good question, thanks.
Time to create page: 0.386 seconds
