The question of proper threading
  • pkasy
  • pkasy's Avatar Topic Author
  • Premium Member
  • Premium Member
16 Jul 2020 09:39 - 16 Jul 2020 09:44 #174820 by pkasy
Replied by pkasy on topic The question of proper threading
when turning the spindle (hm2_5i20.0.encoder.02.scale is 10000)
hm2_5i20.0.encoder.02.position ++
hm2_5i20.0.encoder.02.count --
reverse
hm2_5i20.0.encoder.02.position --
hm2_5i20.0.encoder.02.count ++
if hm2_5i20.0.encoder.02.scale is -10000
reverse
so count is always --
Last edit: 16 Jul 2020 09:44 by pkasy.
  • pkasy
  • Premium Member
  • Premium Member
16 Jul 2020 09:45 #174821 by pkasy
ok, I will rewire spindle so count will ++ when turning the spindle.
16 Jul 2020 09:52 #174822 by Clive S
Replied by Clive S on topic The question of proper threading
I would have thought that changing the sign on scale would have done it.
  • pkasy
  • Premium Member
  • Premium Member
16 Jul 2020 10:36 #174824 by pkasy
I did it. This did not change, but I wrote about it above.
  • pkasy
  • Premium Member
  • Premium Member
16 Jul 2020 12:02 - 16 Jul 2020 12:07 #174835 by pkasy
I checked two times more.
Changing the sign on scale does not affect count only position. Looks like position=count/scale
I use halcmd to change. May be I need to restart axis?
Last edit: 16 Jul 2020 12:07 by pkasy.
16 Jul 2020 12:17 #174837 by tommylight
Replied by tommylight on topic The question of proper threading
You can use the calibration menu (machine/calibration) for axis changes and tuning, not sure if it can do that for spindle.
16 Jul 2020 13:04 #174843 by Clive S
you have to restart the gui for them to take effect
16 Jul 2020 13:27 #174844 by PCW
Replied by PCW on topic The question of proper threading
Only the position is used so the count and rawcount pins are not relevant
The following user(s) said Thank You: pkasy
  • pkasy
  • Premium Member
  • Premium Member
16 Jul 2020 13:28 - 16 Jul 2020 13:29 #174845 by pkasy
no, it does not work after restart gui.
still count --
Last edit: 16 Jul 2020 13:29 by pkasy.
16 Jul 2020 13:30 #174846 by PCW
The count is not used so does not matter, only the position is used for threading
Time to create page: 0.332 seconds
