Can LinuxCNC do 3d printing?
6 years 3 months ago #174170 by kdsands88
New, again to CNCLinux.
Just wondering if CNCLinux is any good for 3D printing?
6 years 3 months ago - 6 years 3 months ago #174192 by trial31
[strike]Hi,
It works! the problem was the Marvell internal network card! Using the realtek card everything works correctly!
PCW and tommylight: if you come in the north of Italy (Val di Non) I will offer you a dinner!
Thank you for help[/strike]
Sorry wrong place...
Last edit: 6 years 3 months ago by trial31. Reason: Sorry wrong place...
6 years 3 months ago #174198 by kdsands88
So, is there a preferred controller board? An examples of a currently build setup? How does CNCLinux handle the extruder?
6 years 3 months ago #174200 by Mike_Eitel
I'm a strong believer that lcnc is a very good solution.
But for 3D printing i go marlin.
m5c Mike
6 years 3 months ago #174247 by tommylight
trial31 wrote: Hi,
Thank you for help
Thank you for the offer.
6 years 3 months ago #174248 by tommylight
kdsands88 wrote: So, is there a preferred controller board? An examples of a currently build setup? How does CNCLinux handle the extruder?
LinuxCNC is the controller, so no controller board is needed as with other printers, but you do need a board with analogue and digital in/out's and preferably step generation, and some small relay or MosFet boards to switch on and off heaters and fans.
There are not many examples of using LinuxCNC for 3D printing but some do exist and there was a pretty big one on youtube but can not find it. Here are some examples:
www.youtube.com/results?search_query=3d+printer+linuxcnc
Time to create page: 0.265 seconds
