Can LinuxCNC do 3d printing?
10 Jul 2020 02:05 #174170 by kdsands88
Can LinuxCNC do 3d printing? was created by kdsands88
New, again to CNCLinux.
Just wondering if CNCLinux is any good for 3D printing?
10 Jul 2020 07:31 - 11 Jul 2020 08:46 #174192 by trial31
Replied by trial31 on topic Can LinuxCNC do 3d printing?
It works! the problem was the Marvell internal network card! Using the realtek card everything works correctly!
PCW and tommylight: if you come in the north of Italy (Val di Non) I will offer you a dinner!
Thank you for help
Sorry wrong place...
Last edit: 11 Jul 2020 08:46 by trial31. Reason: Sorry wrong place...
10 Jul 2020 10:52 #174198 by kdsands88
Replied by kdsands88 on topic Can LinuxCNC do 3d printing?
So, is there a preferred controller board? An examples of a currently build setup? How does CNCLinux handle the extruder?
10 Jul 2020 11:37 #174200 by Mike_Eitel
Replied by Mike_Eitel on topic Can LinuxCNC do 3d printing?
I'm a strong believer that lcnc is a very good solution.
But for 3D printing i go marlin.
m5c Mike
  • Moderator
  • Moderator
10 Jul 2020 18:51 #174247 by tommylight
Replied by tommylight on topic Can LinuxCNC do 3d printing?
Thank you for help
Thank you for the offer.
  • Moderator
  • Moderator
10 Jul 2020 18:57 #174248 by tommylight
LinuxCNC is the controller, so no controller board is needed as with other printers, but you do need a board with analogue and digital in/out's and preferably step generation, and some small relay or MosFet boards to switch on and off heaters and fans.
There are not many examples of using LinuxCNC for 3D printing but some do exist and there was a pretty big one on youtube but can not find it. Here are some examples:
www.youtube.com/results?search_query=3d+printer+linuxcnc
10 Jul 2020 19:37 #174259 by kdsands88
I am currently have a Duet 3d controller board Duet 3. (Also, FastBot, and Replicate - BeagleBone.)
But I am running into issues. I have used the Gecko G540 4-axis driver controller board from my CNC router and CNC mill. Both use CNCLinux.
But, 3d printer board run differently (1:30 minutes in to the follow video):
The big different between CNC and 3D printing is the heat controller for the extruder and heat controller for the heat bed. Everything else is the same.
So, no off the self controller board for 3d printing on CNCLinux?
Also, how close are we for a Raspberry Pi 4 computer running CNCLinux? Need to update computer for router and mill.
10 Jul 2020 19:45 #174260 by kdsands88
My big disappointment with the Duet 3 is no warranty. You short a driver and you are out $300 usd.
  • Moderator
  • Moderator
10 Jul 2020 20:27 #174267 by tommylight
Not that i know of.
It runs pretty well.
forum.linuxcnc.org/9-installing-linuxcnc...pberry-pi-4-tutorial
forum.linuxcnc.org/18-computer/36879-raspberry-pi-4
11 Jul 2020 13:06 #174300 by kdsands88
Thank you tommylight for the useful links on the Raspberry Pi 4.
I have also reached out to Geckodrive. From their promotion video it seems their G540 can be used for 3d printing.
Time to create page: 0.114 seconds
