List of CNC devices I can use with LinuxCNC?
13 Jul 2020 06:21 #174467 by Tango
I am brand new to CNC. I've thought about it in the past, because I have a number of signs I want to put up on our lot (like, "All Deliveries, Stop Here" to stop idiot delivery drivers from messing up our front yard or taking the wrong turn and leaving packages at our guest house!). I've also figured that once I get a CNC machine and start using it, I'll find uses for it every time I'm thinking of a new project I want to build.
I have used Linux for decades and love it for many reasons. I currently have a server running on a mini computer that cost me very little and I'm thinking I could get another one like that for my shop, to control a CNC machine. My desktop systems are Macs and I haven't used Windows since XP, so I'm out of the loop there and don't want to have to get a Windows box just for this one task.
I've seen this list of hardware in the wiki. It's quite possible I don't know all the terms I need to know, but it looks to me like no specific actual CNC systems or machines are listed. Ideally, I'm looking for a machine that can work with a 2' x 2' cutting area, but where I could slide the board I'm working on sideways so I could double my work area without modifying the machine.
I thought Bob's Evolution 4 CNC Router Kit would be just what I needed, but I see the only software they sell with it is Windows only. I have seen Bob's routers discussed in the forum, along with, "Does not play well with LInuxCNC." (Or something similar.)
At this point is there a way to use LinuxCNC with Bob's devices?
Is there a list of CNC devices LinuxCNC will work with? (Or if the list is on the page I'm looking for, what terms describe a full CNC machine on that list?)
I'm just trying to find a CNC machine or kit I can use with LinuxCNC so I can do what I've mentioned above.
13 Jul 2020 07:59 #174475 by tommylight
Replied by tommylight on topic List of CNC devices I can use with LinuxCNC?
That list would be very long as LinuxCNC can control anything from small hobby stuff to big industrial machines by adding some control boards ( very cheap compared to the price of the machine).
In general hobby machines that use parallel port will always work, some USB ones can be used by removing the USB part and using a parallel port BOB or no BOB at all, etc.
Instead of Parallel port, there are several Mesa boards that can be used, they can be programmed to do exactly what parallel port does but at much higher speeds, have more IO and are very versatile, all at a price of under 100$.
13 Jul 2020 13:35 #174507 by Mike_Eitel
Replied by Mike_Eitel on topic List of CNC devices I can use with LinuxCNC?
I often thing people forget one of the bigget advantages the get with fpg stepping:
Very small phase jitter The constanter step generation gives especialy steppers smother torque jumps.
13 Jul 2020 16:51 #174516 by gerritv
Replied by gerritv on topic List of CNC devices I can use with LinuxCNC?
"I thought Bob's Evolution 4 CNC Router Kit would be just what I needed, but I see the only software they sell with it is Windows only. I have seen Bob's routers discussed in the forum, along with, "Does not play well with LInuxCNC." (Or something similar.)"
BobCNC machines uses Grbl controllers and related stepper drivers. Replace those with e.g. a Gecko G540 and you can use the machine with LinuxCNC using a parralel port or Mesa card.
The software they are selling is CAM software. Linux might have a limited set of replacements for those specific packages, I don't know because I chose not to limit myself so still use Windows.
13 Jul 2020 17:03 #174517 by Tango
How hard is replacing the GRBL controllers with a Gecko G540? Once I really get into something, I do a lot of hacking, but since I'm brand new, my goal, at the beginning, is to just get this working so I can make things. After I've been doing that for a while and know the system, I always find I'm hacking things and replacing or modifying parts. I just don't want to do that until I'm used to things.
You say I need a parallel port. Can I use a USB to DB25 cable to do that?
13 Jul 2020 18:07 #174524 by tommylight
Nope, that will not work with LinuxCNC.
Parallel port PCI cards are cheap, but some of them will not work so try to find something with the NetMos chip.
Also some older PC's have parallel ports, and most motherboards do have it or a header for it.
New ones do not have any of those things.
13 Jul 2020 18:19 #174525 by Tango
Okay, got that. The issue is that the minicomputer I was looking at using does not have PCI slots - just an extra SATA connection inside for a 2nd internal drive.
Is there some adapter or something external so I can plug it into a USB port and plug the parallel cable into that converter or adaptor?
13 Jul 2020 18:47 #174529 by tommylight
No USB anything, USB has terrible latency and is not real time in any way, shape or form.
But there are Mesa boards, namely the Mesa 7i92 that will do two parallel ports at much faster rates, or whatever you might need. It connects to the ethernet port on the PC.
There are also Mesa 7i96 and 7i76E, both ethernet and both with plenty of IO and everything required to run a machine.
For small PC's those are the only viable solutions that do not cost an arm and a leg.
13 Jul 2020 18:55 #174530 by Tango
Any chance of anything I can connect to via ethernet?
It sounds like I have to get a computer with at least one PCI slot, then. Is that right?
And if I get one of those boards, then (from another reply), I can use a Gecko G540 on the CNC platform itself. Do you know if that's an easy substitution to make?
13 Jul 2020 19:25 #174533 by gerritv
Rewire the stepper motors to the G540 or similar. Use the Grbl controller and stepper drivers for some other project :-)
The cost diff between 5i25 (Pci board) and 7i9x boards is minimal, and removes t he need for pci slots. You will however need a second ethernet port. Use the builtin port for the 7i9x board, add a wifi or ethernet usb dongle for internet/network use.
Time to create page: 0.169 seconds
