List of CNC devices I can use with LinuxCNC?
- Thank you received: 7465
The G250X, the heart of the G540, features proprietary anti-resonance and motor smoothing techniques. At a native ten microstep resolution the G250X does not require extremely high input frequencies to operate at high speed but offers enough resolution to match the accuracy of most stepper motors (+/- 5% of one full step). Full step morphing at higher speeds transitions the drive to send a true square wave when the benefits of microstepping are no longer present. An adjustable low speed smoothness trimpot compensates for motor nonlinearity at the low end while midband resonance compensation ensures reliable torque output through the midband dropout region.Please Log in or Create an account to join the conversation.
- phillc54
- Thank you received: 2100
I made a large disc in cad with marks around the circumference and ran it with the above settings I didn't see that behaviour, I could definitely see the microstepping. It did appear to miss the odd microstep but that is to be expected.Put a big pulley on the motor, set Linuxcnc to put 1 step per mm, set it to 60mm/m velocity, the pulley will move every 10mm on the dro
My G540 is a REV5 and all the G250X drivers are REV2
- phillc54
- Tango
I get that people don't like the Gecko. What I'm NOT clear about is just what I should get instead. At this point, I'm still not clear on whether people are recommending drivers only or something else.
Can someone break that down for me? What would I use to control the CNC machine and would there be any issues with making these adaptions with the BobsCNC Evolution E4?
- phillc54
If you want recommendation, the Lam Technologies drives are by far the best stepper drives money can buy, but the are pricey. The cheapest one is the DS1044 at mechapro.de at 100 Euro a piece. It is a real 4A drive and it does put out full 4A. It also needs a programmer at 28 Euro.What I'm NOT clear about is just what I should get instead. At this point, I'm still not clear on whether people are recommending drivers only or something else.
We can not break that down for you, we do not have that same machine, so we would need some pictures of the insides of the controller.
- Thank you received: 4141
- JohnnyCNC
- Thank you received: 115
- MX_Master
- Thank you received: 48
You can try Orange Pi (H3) boards with LinuxCNCI'm just trying to find a CNC machine or kit I can use with LinuxCNC so I can do what I've mentioned above.
