Linux start up questions(configuration)
- Frank80
22 Jul 2020 22:19 #175422
by Frank80
Linux start up questions(configuration) was created by Frank80
Hi, linux cnc people my name is Frank80 I'm a newbie at linux cnc. Actually my name is Frank and I happen to be 80 years old, hence Frank80. My problem is 'tho I'm an old time machinist and have built a small but very heavy gantry type mill, I don't have any experience with Linux. I'm using a Mesa 6i25 pcie fpga board and the 7i76 daughter board with their connecting cable. So far so good, but nothing works yet. I had to move a jumper on the fpga (6i25) board to get 5vdc to the 7i76 board (I have the Led ON ). Also had to get a 24vdc wall wart for the field pwr to the 7i76 TB1. I now have both Led's ON the 7i76 board.
Linux will not run but immediately shuts down. I think after reading the Linux msg, it's looking for a spindle drive, I don't use a digital spindle drive. Linux seems to be looking for 9600 baud etc ,etc Spindle Drive connection. After finding None, Linux Begins a shut down.
My Spindle VFD is connected to 7i76 TB4 analog spindle outputs (0 to 5VDC). My VFD doesn't accept digital speed inputs.
What to do? I hope some body knows. I'm not a programmer. I'm just an old man who wants to experience a digital machine. Your help will be much and greatly appreciated.
Thanks for your help
Frank
Frank
- Thank you received: 2175
22 Jul 2020 22:36 #175423
Replied by cmorley on topic Linux start up questions(configuration)
please post your configuration files. and the relevant error messages
- Frank80
23 Jul 2020 00:00 #175425
by Frank80
Replied by Frank80 on topic Linux start up questions(configuration)
I'm using Linux 2.7.0, I don't know yet what it's running in maybe Unbunto, don't know yet. Any way about half way down the PRINT FILE INFO, it says
'killing task linuxcncsvr, pid=3363'
'killing task milltask, pid= 3682'
Also in the DEBUG FILE INFO it says
3363 pidtty stat time command
3682 pidtty stat time command
I think this occurs just after linux can't find the Spindle access for digital speed inputs.
- Frank80
23 Jul 2020 00:02 #175426
by Frank80
thanks for your help
- Frank80
23 Jul 2020 00:08 #175428
by Frank80
Oops, the DEBUG FILE INFO also says
'stopping realtime threads'
'unloading hal components'
- Clive S
- Thank you received: 486
23 Jul 2020 07:05 #175470
by Clive S
Can you post the config files ie. machine_name.hal and the machine_name.ini file from the config folder.
As that would help a lot
Replied by Clive S on topic Linux start up questions(configuration)
- Sooqa
23 Jul 2020 07:54 - 24 Jul 2020 09:00 #175474
by Sooqa
Replied by Sooqa on topic Linux start up questions(configuration)
Thanks guyz!!!
Last edit: 24 Jul 2020 09:00 by Sooqa.
The following user(s) said Thank You: Frank80
- Frank80
23 Jul 2020 19:37 #175566
by Frank80
Thank you Clive S. I don't know where the config files are located I will gladly send anything you think you need, if I can find and figure out how to copy them. This Linux is a mystery to me. I know much of the interface is by command line, i'm very intimidated by the command prompt from early days of DOS in the mid 70's one mistake "poof " everything's gone. Please be patient.
I'll look for the files.
- Thank you received: 7468
23 Jul 2020 20:51 #175571
Replied by tommylight on topic Linux start up questions(configuration)
Open the home folder, then linuxcnc folder, then configs folder, copy the folder with the name of your machine.
- Frank80
26 Jul 2020 01:28 #175834
by Frank80
thanks for the help! I've found the requested files,found both in franks_cnc_file_ manager. Both are plain text files. now the question is how to copy them to a stick.
I plugged in a 8GB stick nothing happened. and second can the files on the stick be sent to the forum page?
Time to create page: 0.117 seconds
