Linux start up questions(configuration)
- Clive S
- Thank you received: 486
26 Jul 2020 06:29 #175857
by Clive S
You can copy and paste the files to a stick (right click with the mouse and you will see "copy" or use Ctrl +C on the keyboard and the Ctrl +V to paste)
Then at the bottom of your reply you should see the attachment button click on that.
Replied by Clive S on topic Linux start up questions(configuration)
thanks for the help! I've found the requested files,found both in franks_cnc_file_ manager. Both are plain text files. now the question is how to copy them to a stick.
I plugged in a 8GB stick nothing happened. and second can the files on the stick be sent to the forum page?
- Thank you received: 7468
26 Jul 2020 09:20 #175875
Replied by tommylight on topic Linux start up questions(configuration)
There should be more than 2 files, and they are all text files with different extensions.
- Frank80
25 Sep 2020 00:03 #183651
by Frank80
Replied by Frank80 on topic Linux start up questions(configuration)
I figured out how to upload my .ini and .hal files, they should be attached now. Currently when I try and run LinuxCNC it tries to load then crashes. Remember I do not have a digital interface to the VFD (9600 baud) instead I have an analog input 0-5v from the 5i25 to my spindle drive.
FWIW, The physical card in my computer is a 6i25 card with no changes i.e. jumpers. It's my understanding that it is completely 5i25 compatible in this state)
Below is the output I get when the application terminates. (Note, If it makes a difference, I am running the application right now with nothing connected to the card in the computer)
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/frank/linuxcnc/configs/franks_cnc_router'
Machine configuration file is 'franks_cnc_router.ini'
INIFILE=/home/frank/linuxcnc/configs/franks_cnc_router/franks_cnc_router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./franks_cnc_router.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
spindle-vfd: device='/dev/ttyS0', baud=9600, parity='N', bits=8, stopbits=2, address=1, enabled=1
spindle-vfd: ERROR: couldn't open serial device: Input/output error
Running HAL shutdown script
task: 76 cycles, min=0.000005, max=0.022284, avg=0.008223, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
mitsub_vfd.hal:12: waitpid failed gs2_vfd spindle-vfd
mitsub_vfd.hal:12: gs2_vfd exited without becoming ready
8289
8338
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[ 0.000000] BIOS-e820: 0000000020200000 - 0000000040000000 (usable)
[ 0.000000] BIOS-e820: 0000000040000000 - 0000000040200000 (reserved)
[ 0.000000] BIOS-e820: 0000000040200000 - 00000000ce14e000 (usable)
[ 0.000000] BIOS-e820: 00000000ce14e000 - 00000000ce941000 (reserved)
[ 0.000000] BIOS-e820: 00000000ce941000 - 00000000ceb95000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ceb95000 - 00000000ceba2000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000ceba2000 - 00000000cebc1000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cebc1000 - 00000000cebc6000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cebc6000 - 00000000cec09000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cec09000 - 00000000cf000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf800000 - 00000000dfa00000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021f600000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: ASUSTeK Computer INC. CM6630_CM6730_CM6830./CM6330_CM6630_CM6730_CM6830, BIOS 4101 09/04/2012
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D7FFF write-protect
[ 0.000000] D8000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 4 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 5 base 21F800000 mask FFF800000 uncachable
[ 0.000000] 6 base 21F600000 mask FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fcd90] fcd90
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0097000] 97000 size 16384
[ 0.000000] reserving inaccessible SNB gfx pages
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36416000 - 37203000
[ 0.000000] ACPI: RSDP 000f0450 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT ceb95078 0006C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP ceb9f558 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT ceb95180 0A3D3 (v02 ALASKA A M I 00000015 INTL 20051117)
[ 0.000000] ACPI: FACS cebbff80 00040
[ 0.000000] ACPI: APIC ceb9f650 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG ceb9f6c8 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET ceb9f708 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT ceb9f740 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT ceb9fab0 009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT ceba0460 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: BGRT ceba10c8 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SLIC ceba0f50 00176 (v01 _ASUS_ Notebook 00000000 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2424MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020200 -> 0x00040000
[ 0.000000] 0: 0x00040200 -> 0x000ce14e
[ 0.000000] 0: 0x000cec09 -> 0x000cf000
[ 0.000000] On node 0 totalpages: 843986
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4a36200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4849 pages used for memmap
[ 0.000000] HighMem zone: 612438 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[ 0.000000] Allocating PCI resources starting at dfa00000 (gap: dfa00000:18600000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 837361
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=7adbfe91-4260-44a3-9049-54aa19e103e9 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6782848 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf000)
[ 0.000000] Memory: 3321004k/3391488k available (3495k kernel code, 54940k reserved, 1237k data, 416k init, 2469148k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2993.078 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 5986.15 BogoMIPS (lpj=11972312)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.000032] Security Framework initialized
[ 0.000036] AppArmor: AppArmor disabled by boot time parameter
[ 0.000047] Mount-cache hash table entries: 512
[ 0.000177] Initializing cgroup subsys cpuacct
[ 0.000179] Initializing cgroup subsys memory
[ 0.000184] Initializing cgroup subsys devices
[ 0.000186] Initializing cgroup subsys freezer
[ 0.000187] Initializing cgroup subsys net_cls
[ 0.000189] Initializing cgroup subsys blkio
[ 0.000193] Initializing cgroup subsys perf_event
[ 0.000213] CPU: Physical Processor ID: 0
[ 0.000214] CPU: Processor Core ID: 0
[ 0.000217] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000218] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000220] mce: CPU supports 9 MCE banks
[ 0.000230] CPU0: Thermal monitoring enabled (TM1)
[ 0.000302] ACPI: Core revision 20120320
[ 0.019520] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.019910] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.059581] CPU0: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz stepping 07
[ 0.164964] Performance Events: PEBS fmt1+, 16-deep LBR, SandyBridge events, Intel PMU driver.
[ 0.164970] PEBS disabled due to CPU errata.
[ 0.164972] ... version: 3
[ 0.164973] ... bit width: 48
[ 0.164974] ... generic registers: 8
[ 0.164976] ... value mask: 0000ffffffffffff
[ 0.164977] ... max period: 000000007fffffff
[ 0.164978] ... fixed-purpose events: 3
[ 0.164979] ... event mask: 00000007000000ff
[ 0.177014] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.188975] CPU 1 irqstacks, hard=f3cd8000 soft=f3cda000
[ 0.188977] Booting Node 0, Processors #1
[ 0.199277] Initializing CPU#1
[ 0.202121] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.208972] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.208975] #2
[ 0.219211] Initializing CPU#2
[ 0.222116] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.228963] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[ 0.228966] #3 Ok.
[ 0.239202] Initializing CPU#3
[ 0.242107] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.242132] Brought up 4 CPUs
[ 0.242134] Total of 4 processors activated (23944.62 BogoMIPS).
[ 0.244495] devtmpfs: initialized
[ 0.244665] PM: Registering ACPI NVS region [mem 0xce941000-0xceb94fff] (2441216 bytes)
[ 0.244731] PM: Registering ACPI NVS region [mem 0xceba2000-0xcebc0fff] (126976 bytes)
[ 0.244736] PM: Registering ACPI NVS region [mem 0xcebc6000-0xcec08fff] (274432 bytes)
[ 0.244815] dummy:
[ 0.244858] NET: Registered protocol family 16
[ 0.244951] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.244953] ACPI: bus type pci registered
[ 0.244996] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.244998] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.245000] PCI: Using MMCONFIG for extended config space
[ 0.245001] PCI: Using configuration type 1 for base access
[ 0.245461] bio: create slab <bio-0> at 0
[ 0.245532] ACPI: Added _OSI(Module Device)
[ 0.245534] ACPI: Added _OSI(Processor Device)
[ 0.245535] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.245537] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.247303] ACPI: EC: Look up EC in DSDT
[ 0.249237] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.253390] ACPI: SSDT ce8ee018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.253861] ACPI: Dynamic OEM Table Load:
[ 0.253864] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.254157] ACPI: SSDT ce8efa98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.254669] ACPI: Dynamic OEM Table Load:
[ 0.254671] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.254803] ACPI: SSDT ce8f0c18 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.255269] ACPI: Dynamic OEM Table Load:
[ 0.255271] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.255920] ACPI: Interpreter enabled
[ 0.255931] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.255955] ACPI: Using IOAPIC for interrupt routing
[ 0.261391] ACPI: Power Resource [FN00] (off)
[ 0.261466] ACPI: Power Resource [FN01] (off)
[ 0.261539] ACPI: Power Resource [FN02] (off)
[ 0.261611] ACPI: Power Resource [FN03] (off)
[ 0.261683] ACPI: Power Resource [FN04] (off)
[ 0.262205] ACPI: No dock devices found.
[ 0.262210] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.262564] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.263091] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.263093] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.263095] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.263097] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.263099] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.263101] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.263103] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.263105] pci_root PNP0A08:00: host bridge window [mem 0xdfa00000-0xfeafffff]
[ 0.263129] PCI host bridge to bus 0000:00
[ 0.263131] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.263133] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.263134] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.263136] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.263138] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.263140] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.263141] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.263143] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff]
[ 0.263151] pci 0000:00:00.0: [8086:0100] type 00 class 0x060000
[ 0.263181] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[ 0.263204] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.263222] pci 0000:00:02.0: [8086:0102] type 00 class 0x030000
[ 0.263232] pci 0000:00:02.0: reg 10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.263238] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.263242] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.263288] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.263311] pci 0000:00:16.0: reg 10: [mem 0xf7c06000-0xf7c0600f 64bit]
[ 0.263372] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.263405] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.263426] pci 0000:00:1a.0: reg 10: [mem 0xf7c04000-0xf7c043ff]
[ 0.263499] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.263522] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.263585] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.263610] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.263672] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.263696] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[ 0.263758] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.263783] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[ 0.263846] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.263870] pci 0000:00:1c.4: [8086:244e] type 01 class 0x060401
[ 0.263932] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.263957] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
[ 0.264019] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.264049] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.264069] pci 0000:00:1d.0: reg 10: [mem 0xf7c03000-0xf7c033ff]
[ 0.264143] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.264168] pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
[ 0.264281] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[ 0.264299] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.264307] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.264314] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.264322] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.264329] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.264337] pci 0000:00:1f.2: reg 24: [mem 0xf7c02000-0xf7c027ff]
[ 0.264369] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.264386] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.264401] pci 0000:00:1f.3: reg 10: [mem 0xf7c01000-0xf7c010ff 64bit]
[ 0.264422] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.264464] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.264540] pci 0000:02:00.0: [104c:8240] type 01 class 0x060400
[ 0.264656] pci 0000:02:00.0: supports D1 D2
[ 0.268948] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.268956] pci 0000:00:1c.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.269079] pci 0000:03:00.0: [2718:5125] type 00 class 0x110000
[ 0.269104] pci 0000:03:00.0: reg 10: [mem 0xf7b00000-0xf7b0ffff]
[ 0.269293] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.269307] pci 0000:02:00.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.269392] pci 0000:04:00.0: [1814:3090] type 00 class 0x028000
[ 0.269412] pci 0000:04:00.0: reg 10: [mem 0xf7a00000-0xf7a0ffff]
[ 0.276944] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.276952] pci 0000:00:1c.1: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.277036] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000
[ 0.277056] pci 0000:05:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.277090] pci 0000:05:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.277112] pci 0000:05:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.277172] pci 0000:05:00.0: supports D1 D2
[ 0.277173] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.284940] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.284946] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.284957] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.285041] pci 0000:06:00.0: [1b21:1042] type 00 class 0x0c0330
[ 0.285070] pci 0000:06:00.0: reg 10: [mem 0xf7900000-0xf7907fff 64bit]
[ 0.285196] pci 0000:06:00.0: PME# supported from D3hot D3cold
[ 0.292935] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.292944] pci 0000:00:1c.3: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.293022] pci 0000:07:00.0: [1b21:1080] type 01 class 0x060401
[ 0.293128] pci 0000:00:1c.4: PCI bridge to [bus 07-08] (subtractive decode)
[ 0.293138] pci 0000:00:1c.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.293140] pci 0000:00:1c.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.293142] pci 0000:00:1c.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.293144] pci 0000:00:1c.4: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.293146] pci 0000:00:1c.4: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.293148] pci 0000:00:1c.4: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.293150] pci 0000:00:1c.4: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.293152] pci 0000:00:1c.4: bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[ 0.293267] pci 0000:07:00.0: PCI bridge to [bus 08-08] (subtractive decode)
[ 0.293289] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293291] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293293] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293295] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293297] pci 0000:07:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.293299] pci 0000:07:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.293300] pci 0000:07:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.293302] pci 0000:07:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.293304] pci 0000:07:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.293306] pci 0000:07:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.293308] pci 0000:07:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.293310] pci 0000:07:00.0: bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[ 0.293385] pci 0000:09:00.0: [1b21:0612] type 00 class 0x010601
[ 0.293404] pci 0000:09:00.0: reg 10: [io 0xd050-0xd057]
[ 0.293418] pci 0000:09:00.0: reg 14: [io 0xd040-0xd043]
[ 0.293431] pci 0000:09:00.0: reg 18: [io 0xd030-0xd037]
[ 0.293445] pci 0000:09:00.0: reg 1c: [io 0xd020-0xd023]
[ 0.293459] pci 0000:09:00.0: reg 20: [io 0xd000-0xd01f]
[ 0.293473] pci 0000:09:00.0: reg 24: [mem 0xf7800000-0xf78001ff]
[ 0.300932] pci 0000:00:1c.5: PCI bridge to [bus 09-09]
[ 0.300938] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.300943] pci 0000:00:1c.5: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.300991] pci_bus 0000:00: on NUMA node 0
[ 0.300993] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.301222] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.301266] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.301309] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.301352] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.301395] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.301439] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05.P8P9._PRT]
[ 0.301477] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.301527] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.301649] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.306954] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.307002] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 6 10 11 12 14 15)
[ 0.307049] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.307095] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.307141] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.307189] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.307235] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.307282] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.307339] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.307348] vgaarb: loaded
[ 0.307349] vgaarb: bridge control possible 0000:00:02.0
[ 0.307369] PCI: Using ACPI for IRQ routing
[ 0.308760] PCI: pci_cache_line_size set to 64 bytes
[ 0.308841] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.308843] reserve RAM buffer: 00000000ce14e000 - 00000000cfffffff
[ 0.308845] reserve RAM buffer: 00000000cf000000 - 00000000cfffffff
[ 0.308942] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.308949] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.311965] Switching to clocksource hpet
[ 0.312007] pnp: PnP ACPI init
[ 0.312015] ACPI: bus type pnp registered
[ 0.312297] pnp 00:00: [bus 00-3e]
[ 0.312299] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.312301] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.312303] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.312305] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.312306] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.312308] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.312310] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.312311] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.312313] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.312315] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.312316] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.312318] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.312320] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.312321] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.312323] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.312325] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.312327] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.312328] pnp 00:00: [mem 0xdfa00000-0xfeafffff window]
[ 0.312330] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.312373] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.312395] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.312425] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.312427] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.312438] pnp 00:02: [io 0x0000-0x001f]
[ 0.312439] pnp 00:02: [io 0x0081-0x0091]
[ 0.312441] pnp 00:02: [io 0x0093-0x009f]
[ 0.312442] pnp 00:02: [io 0x00c0-0x00df]
[ 0.312444] pnp 00:02: [dma 4]
[ 0.312459] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.312467] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.312483] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.312543] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.312564] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.312574] pnp 00:05: [io 0x002e-0x002f]
[ 0.312576] pnp 00:05: [io 0x004e-0x004f]
[ 0.312577] pnp 00:05: [io 0x0061]
[ 0.312579] pnp 00:05: [io 0x0063]
[ 0.312580] pnp 00:05: [io 0x0065]
[ 0.312582] pnp 00:05: [io 0x0067]
[ 0.312583] pnp 00:05: [io 0x0070]
[ 0.312584] pnp 00:05: [io 0x0080]
[ 0.312586] pnp 00:05: [io 0x0092]
[ 0.312587] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.312589] pnp 00:05: [io 0x0680-0x069f]
[ 0.312590] pnp 00:05: [io 0x0200-0x020f]
[ 0.312592] pnp 00:05: [io 0xffff]
[ 0.312593] pnp 00:05: [io 0xffff]
[ 0.312594] pnp 00:05: [io 0x0400-0x0453]
[ 0.312596] pnp 00:05: [io 0x0458-0x047f]
[ 0.312597] pnp 00:05: [io 0x0500-0x057f]
[ 0.312599] pnp 00:05: [io 0x164e-0x164f]
[ 0.312632] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.312634] system 00:05: [io 0x0200-0x020f] has been reserved
[ 0.312636] system 00:05: [io 0xffff] has been reserved
[ 0.312638] system 00:05: [io 0xffff] has been reserved
[ 0.312640] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.312642] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.312644] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.312646] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.312648] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312657] pnp 00:06: [io 0x0070-0x0077]
[ 0.312663] pnp 00:06: [irq 8]
[ 0.312679] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.312703] pnp 00:07: [io 0x0454-0x0457]
[ 0.312732] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.312734] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.312789] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312791] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312792] pnp 00:08: [io 0x0290-0x029f]
[ 0.312794] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312822] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.312825] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312844] pnp 00:09: [io 0x0010-0x001f]
[ 0.312846] pnp 00:09: [io 0x0022-0x003f]
[ 0.312847] pnp 00:09: [io 0x0044-0x005f]
[ 0.312849] pnp 00:09: [io 0x0062-0x0063]
[ 0.312850] pnp 00:09: [io 0x0065-0x006f]
[ 0.312852] pnp 00:09: [io 0x0072-0x007f]
[ 0.312853] pnp 00:09: [io 0x0080]
[ 0.312855] pnp 00:09: [io 0x0084-0x0086]
[ 0.312856] pnp 00:09: [io 0x0088]
[ 0.312857] pnp 00:09: [io 0x008c-0x008e]
[ 0.312859] pnp 00:09: [io 0x0090-0x009f]
[ 0.312860] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.312862] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.312863] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.312895] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.312897] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312904] pnp 00:0a: [io 0x00f0-0x00ff]
[ 0.312909] pnp 00:0a: [irq 13]
[ 0.312934] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.313191] pnp 00:0b: [mem 0xfed1c000-0xfed1ffff]
[ 0.313193] pnp 00:0b: [mem 0xfed10000-0xfed17fff]
[ 0.313194] pnp 00:0b: [mem 0xfed18000-0xfed18fff]
[ 0.313196] pnp 00:0b: [mem 0xfed19000-0xfed19fff]
[ 0.313197] pnp 00:0b: [mem 0xf8000000-0xfbffffff]
[ 0.313199] pnp 00:0b: [mem 0xfed20000-0xfed3ffff]
[ 0.313201] pnp 00:0b: [mem 0xfed90000-0xfed93fff]
[ 0.313202] pnp 00:0b: [mem 0xfed45000-0xfed8ffff]
[ 0.313204] pnp 00:0b: [mem 0xff000000-0xffffffff]
[ 0.313205] pnp 00:0b: [mem 0xfee00000-0xfeefffff]
[ 0.313207] pnp 00:0b: [mem 0xdfa00000-0xdfa00fff]
[ 0.313257] system 00:0b: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.313259] system 00:0b: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.313261] system 00:0b: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.313263] system 00:0b: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.313265] system 00:0b: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.313268] system 00:0b: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.313270] system 00:0b: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.313272] system 00:0b: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.313274] system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
[ 0.313276] system 00:0b: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.313278] system 00:0b: [mem 0xdfa00000-0xdfa00fff] has been reserved
[ 0.313280] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.313416] pnp 00:0c: [mem 0x20000000-0x201fffff]
[ 0.313418] pnp 00:0c: [mem 0x40000000-0x401fffff]
[ 0.313467] system 00:0c: [mem 0x20000000-0x201fffff] has been reserved
[ 0.313469] system 00:0c: [mem 0x40000000-0x401fffff] has been reserved
[ 0.313471] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.313495] pnp: PnP ACPI: found 13 devices
[ 0.313496] ACPI: ACPI bus type pnp unregistered
[ 0.313498] PnPBIOS: Disabled by ACPI PNP
[ 0.349572] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.349578] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.349586] pci 0000:02:00.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.349600] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.349605] pci 0000:00:1c.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.349613] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.349617] pci 0000:00:1c.1: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.349625] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.349628] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.349635] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.349641] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.349646] pci 0000:00:1c.3: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.349654] pci 0000:07:00.0: PCI bridge to [bus 08-08]
[ 0.349673] pci 0000:00:1c.4: PCI bridge to [bus 07-08]
[ 0.349684] pci 0000:00:1c.5: PCI bridge to [bus 09-09]
[ 0.349687] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.349691] pci 0000:00:1c.5: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.349761] pci 0000:07:00.0: setting latency timer to 64
[ 0.349771] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.349773] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.349775] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.349776] pci_bus 0000:00: resource 7 [mem 0x000d8000-0x000dbfff]
[ 0.349778] pci_bus 0000:00: resource 8 [mem 0x000dc000-0x000dffff]
[ 0.349780] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.349782] pci_bus 0000:00: resource 10 [mem 0x000e4000-0x000e7fff]
[ 0.349783] pci_bus 0000:00: resource 11 [mem 0xdfa00000-0xfeafffff]
[ 0.349785] pci_bus 0000:02: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.349787] pci_bus 0000:03: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.349789] pci_bus 0000:04: resource 1 [mem 0xf7a00000-0xf7afffff]
[ 0.349790] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 0.349792] pci_bus 0000:05: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.349794] pci_bus 0000:06: resource 1 [mem 0xf7900000-0xf79fffff]
[ 0.349796] pci_bus 0000:07: resource 4 [io 0x0000-0x0cf7]
[ 0.349797] pci_bus 0000:07: resource 5 [io 0x0d00-0xffff]
[ 0.349799] pci_bus 0000:07: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.349801] pci_bus 0000:07: resource 7 [mem 0x000d8000-0x000dbfff]
[ 0.349802] pci_bus 0000:07: resource 8 [mem 0x000dc000-0x000dffff]
[ 0.349804] pci_bus 0000:07: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.349806] pci_bus 0000:07: resource 10 [mem 0x000e4000-0x000e7fff]
[ 0.349808] pci_bus 0000:07: resource 11 [mem 0xdfa00000-0xfeafffff]
[ 0.349809] pci_bus 0000:08: resource 8 [io 0x0000-0x0cf7]
[ 0.349811] pci_bus 0000:08: resource 9 [io 0x0d00-0xffff]
[ 0.349813] pci_bus 0000:08: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.349814] pci_bus 0000:08: resource 11 [mem 0x000d8000-0x000dbfff]
[ 0.349816] pci_bus 0000:08: resource 12 [mem 0x000dc000-0x000dffff]
[ 0.349818] pci_bus 0000:08: resource 13 [mem 0x000e0000-0x000e3fff]
[ 0.349819] pci_bus 0000:08: resource 14 [mem 0x000e4000-0x000e7fff]
[ 0.349821] pci_bus 0000:08: resource 15 [mem 0xdfa00000-0xfeafffff]
[ 0.349823] pci_bus 0000:09: resource 0 [io 0xd000-0xdfff]
[ 0.349824] pci_bus 0000:09: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.349888] NET: Registered protocol family 2
[ 0.349928] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.350046] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.350212] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.350283] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.350284] TCP: reno registered
[ 0.350286] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350290] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350346] NET: Registered protocol family 1
[ 0.350678] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
[ 0.350846] pci 0000:00:02.0: Boot video device
[ 0.599963] PCI: CLS 64 bytes, default 64
[ 0.599990] Unpacking initramfs...
[ 0.815542] Freeing initrd memory: 14260k freed
[ 0.817464] audit: initializing netlink socket (disabled)
[ 0.817478] type=2000 audit(1600962520.700:1): initialized
[ 0.827073] highmem bounce pool size: 64 pages
[ 0.827076] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.827230] VFS: Disk quotas dquot_6.5.2
[ 0.827251] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.827303] msgmni has been set to 1691
[ 0.827417] alg: No test for stdrng (krng)
[ 0.827438] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.827441] io scheduler noop registered
[ 0.827442] io scheduler deadline registered
[ 0.827459] io scheduler cfq registered (default)
[ 0.827766] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.827777] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.827779] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.828206] GHES: HEST is not enabled!
[ 0.828213] isapnp: Scanning for PnP cards...
[ 1.183057] isapnp: No Plug & Play device found
[ 1.183085] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.183470] Linux agpgart interface v0.103
[ 1.183553] agpgart-intel 0000:00:00.0: Intel Sandybridge Chipset
[ 1.183599] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 1.184346] agpgart-intel 0000:00:00.0: detected 262144K stolen memory
[ 1.184435] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.184538] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.187011] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.187033] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.187100] mousedev: PS/2 mouse device common for all mice
[ 1.187137] rtc_cmos 00:06: RTC can wake from S4
[ 1.187248] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.187273] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.187367] TCP: cubic registered
[ 1.187419] NET: Registered protocol family 10
[ 1.187570] Mobile IPv6
[ 1.187572] NET: Registered protocol family 17
[ 1.187575] Registering the dns_resolver key type
[ 1.187614] Using IPI No-Shortcut mode
[ 1.187678] PM: Hibernation image not present or could not be loaded.
[ 1.187702] registered taskstats version 1
[ 1.188154] rtc_cmos 00:06: setting system clock to 2020-09-24 15:48:41 UTC (1600962521)
[ 1.188242] Freeing unused kernel memory: 416k freed
[ 1.188339] Write protecting the kernel text: 3496k
[ 1.188357] Write protecting the kernel read-only data: 984k
[ 1.195995] udevd[57]: starting version 175
[ 1.206501] usbcore: registered new interface driver usbfs
[ 1.212521] usbcore: registered new interface driver hub
[ 1.212659] SCSI subsystem initialized
[ 1.213445] usbcore: registered new device driver usb
[ 1.213680] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.213726] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.213729] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.213745] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.213765] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.214620] microcode: CPU0 sig=0x206a7, pf=0x2, revision=0x28
[ 1.214726] libata version 3.00 loaded.
[ 1.214998] ACPI: Fan [FAN0] (off)
[ 1.216066] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.216287] r8169 0000:05:00.0: eth0: RTL8168evl/8111evl at 0xf8012000, 54:04:a6:f2:d7:a5, XID 0c900800 IRQ 18
[ 1.216290] r8169 0000:05:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.217665] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.217682] ehci_hcd 0000:00:1a.0: irq 23, io mem 0xf7c04000
[ 1.218291] ACPI: Fan [FAN1] (off)
[ 1.218325] ACPI: Fan [FAN2] (off)
[ 1.218355] ACPI: Fan [FAN3] (off)
[ 1.218383] ACPI: Fan [FAN4] (off)
[ 1.227706] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.227728] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.227730] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.227732] usb usb1: Product: EHCI Host Controller
[ 1.227733] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.227735] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.227823] hub 1-0:1.0: USB hub found
[ 1.227827] hub 1-0:1.0: 2 ports detected
[ 1.227922] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.227926] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.227932] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.227946] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.227953] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.227955] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 3
[ 1.231856] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.231864] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7c03000
[ 1.232429] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.232432] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.232434] usb usb3: Product: xHCI Host Controller
[ 1.232436] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.232437] usb usb3: SerialNumber: 0000:06:00.0
[ 1.233119] xHCI xhci_add_endpoint called for root hub
[ 1.233121] xHCI xhci_check_bandwidth called for root hub
[ 1.233143] hub 3-0:1.0: USB hub found
[ 1.233150] hub 3-0:1.0: 2 ports detected
[ 1.233210] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.233215] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 4
[ 1.233239] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.233241] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.233243] usb usb4: Product: xHCI Host Controller
[ 1.233244] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.233246] usb usb4: SerialNumber: 0000:06:00.0
[ 1.233711] xHCI xhci_add_endpoint called for root hub
[ 1.233713] xHCI xhci_check_bandwidth called for root hub
[ 1.233733] hub 4-0:1.0: USB hub found
[ 1.233740] hub 4-0:1.0: 2 ports detected
[ 1.238481] microcode: CPU0 updated to revision 0x29, date = 2013-06-12
[ 1.238492] microcode: CPU1 sig=0x206a7, pf=0x2, revision=0x28
[ 1.240526] microcode: CPU1 updated to revision 0x29, date = 2013-06-12
[ 1.240535] microcode: CPU2 sig=0x206a7, pf=0x2, revision=0x28
[ 1.242181] microcode: CPU2 updated to revision 0x29, date = 2013-06-12
[ 1.242187] microcode: CPU3 sig=0x206a7, pf=0x2, revision=0x28
[ 1.243696] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.243714] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.243716] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.243718] usb usb2: Product: EHCI Host Controller
[ 1.243719] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.243721] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.243804] hub 2-0:1.0: USB hub found
[ 1.243808] hub 2-0:1.0: 2 ports detected
[ 1.243822] microcode: CPU3 updated to revision 0x29, date = 2013-06-12
[ 1.243867] ahci 0000:00:1f.2: version 3.0
[ 1.243879] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.259700] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x33 impl SATA mode
[ 1.259706] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 1.259720] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.284074] scsi0 : ahci
[ 1.284160] scsi1 : ahci
[ 1.284214] scsi2 : ahci
[ 1.284266] scsi3 : ahci
[ 1.284316] scsi4 : ahci
[ 1.284368] scsi5 : ahci
[ 1.284722] ata1: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02100 irq 19
[ 1.284725] ata2: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02180 irq 19
[ 1.284727] ata3: DUMMY
[ 1.284728] ata4: DUMMY
[ 1.284730] ata5: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02300 irq 19
[ 1.284732] ata6: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02380 irq 19
[ 1.284797] ahci: SSS flag set, parallel bus scan disabled
[ 1.284846] ahci 0000:09:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.284848] ahci 0000:09:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 1.285162] scsi6 : ahci
[ 1.285291] scsi7 : ahci
[ 1.285332] ata7: SATA max UDMA/133 abar m512@0xf7800000 port 0xf7800100 irq 17
[ 1.285336] ata8: SATA max UDMA/133 abar m512@0xf7800000 port 0xf7800180 irq 17
[ 1.539590] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.603598] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.603626] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.603641] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.603662] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.604500] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.604505] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5a368), AE_NOT_FOUND (20120320/psparse-536)
[ 1.604618] ata5.00: ATA-9: PNY CS1211 480GB SSD 754D117-533, CS121101, max UDMA/133
[ 1.604620] ata5.00: 937703088 sectors, multi 2: LBA48 NCQ (depth 31/32), AA
[ 1.604780] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.604788] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5a368), AE_NOT_FOUND (20120320/psparse-536)
[ 1.604886] ata5.00: configured for UDMA/133
[ 1.604959] scsi 4:0:0:0: Direct-Access ATA PNY CS1211 480GB CS12 PQ: 0 ANSI: 5
[ 1.606071] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.606085] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f3c5a320), AE_NOT_FOUND (20120320/psparse-536)
[ 1.606094] ata6.00: ATAPI: ATAPI DVD A DH24ABS, AAA1, max UDMA/100
[ 1.606907] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.606914] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f3c5a320), AE_NOT_FOUND (20120320/psparse-536)
[ 1.606932] ata6.00: configured for UDMA/100
[ 1.609151] scsi 5:0:0:0: CD-ROM ATAPI DVD A DH24ABS AAA1 PQ: 0 ANSI: 5
[ 1.671961] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.671965] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.672102] hub 1-1:1.0: USB hub found
[ 1.672204] hub 1-1:1.0: 4 ports detected
[ 1.775532] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.776742] ata7.00: ATA-8: ST31000524AS, JC45, max UDMA/133
[ 1.776746] ata7.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1.778144] ata7.00: configured for UDMA/133
[ 1.778237] scsi 6:0:0:0: Direct-Access ATA ST31000524AS JC45 PQ: 0 ANSI: 5
[ 1.815500] Refined TSC clocksource calibration: 2993.200 MHz.
[ 1.815507] Switching to clocksource tsc
[ 1.839492] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 1.858340] usb 3-1: New USB device found, idVendor=046d, idProduct=c534
[ 1.858343] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.858346] usb 3-1: Product: USB Receiver
[ 1.858349] usb 3-1: Manufacturer: Logitech
[ 1.862804] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1c.3/0000:06:00.0/usb3/3-1/3-1:1.0/input/input0
[ 1.862855] generic-usb 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:06:00.0-1/input0
[ 1.864902] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1c.3/0000:06:00.0/usb3/3-1/3-1:1.1/input/input1
[ 1.864991] generic-usb 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:06:00.0-1/input1
[ 1.865003] usbcore: registered new interface driver usbhid
[ 1.865005] usbhid: USB HID core driver
[ 1.971455] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 2.095431] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.097134] sd 4:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 2.097138] sd 6:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.097174] sd 6:0:0:0: [sdb] Write Protect is off
[ 2.097176] sd 6:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.097182] sd 4:0:0:0: [sda] Write Protect is off
[ 2.097184] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.097192] sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.097198] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.098317] sda: sda1 sda2 < sda5 >
[ 2.098582] sd 4:0:0:0: [sda] Attached SCSI disk
[ 2.099635] sd 4:0:0:0: Attached scsi generic sg0 type 0
[ 2.099689] scsi 5:0:0:0: Attached scsi generic sg1 type 5
[ 2.099718] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 2.103818] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.103823] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.103961] hub 2-1:1.0: USB hub found
[ 2.104061] hub 2-1:1.0: 6 ports detected
[ 2.111019] sdb: sdb1
[ 2.111210] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 2.116931] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.116955] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.117048] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 2.175552] usb 1-1.3: new high-speed USB device number 3 using ehci_hcd
[ 2.278389] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0158
[ 2.278394] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.278398] usb 1-1.3: Product: USB2.0-CRW
[ 2.278401] usb 1-1.3: Manufacturer: Generic
[ 2.278403] usb 1-1.3: SerialNumber: 20071114173400000
[ 2.284385] Initializing USB Mass Storage driver...
[ 2.284426] usbcore: registered new interface driver usb-storage
[ 2.284428] USB Mass Storage support registered.
[ 2.298547] scsi8 : usb-storage 1-1.3:1.0
[ 2.298596] usbcore: registered new interface driver ums-realtek
[ 2.498567] usb 1-1.3: USB disconnect, device number 3
[ 7.302453] PM: Starting manual resume from disk
[ 7.302456] PM: Hibernation image partition 8:5 present
[ 7.302457] PM: Looking for hibernation image.
[ 7.302666] PM: Image not found (code -22)
[ 7.302668] PM: Hibernation image not present or could not be loaded.
[ 7.332916] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.495178] udevd[432]: starting version 175
[ 7.542323] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 7.542327] ACPI: Power Button [PWRB]
[ 7.542370] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 7.542373] ACPI: Power Button [PWRF]
[ 7.545950] wmi: Mapper loaded
[ 7.554461] [drm] Initialized drm 1.1.0 20060810
[ 7.561307] i915 0000:00:02.0: setting latency timer to 64
[ 7.566197] iTCO_vendor_support: vendor-support=0
[ 7.567717] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 7.567780] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 7.568031] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 7.572447] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 7.572450] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 7.572575] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 7.572577] [drm] Driver supports precise vblank timestamp query.
[ 7.572606] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.574631] cfg80211: Calling CRDA to update world regulatory domain
[ 7.589140] asus_wmi: ASUS WMI generic driver loaded
[ 7.589978] asus_wmi: Initialization: 0x0
[ 7.590004] asus_wmi: BIOS WMI version: 0.9
[ 7.590056] asus_wmi: SFUN value: 0x0
[ 7.590326] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input4
[ 7.591788] asus_wmi: Backlight controlled by ACPI video driver
[ 7.596756] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 7.596909] Registered led device: rt2800pci-phy0::radio
[ 7.596923] Registered led device: rt2800pci-phy0::assoc
[ 7.596936] Registered led device: rt2800pci-phy0::quality
[ 7.615791] [drm] Enabling RC6 states: RC6 on, RC6p off, RC6pp off
[ 7.625612] cfg80211: World regulatory domain updated:
[ 7.625615] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.625617] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.625619] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.625620] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 7.625622] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625623] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625625] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 7.625627] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625628] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 7.796536] fbcon: inteldrmfb (fb0) is primary device
[ 7.966327] Console: switching to colour frame buffer device 128x48
[ 7.967900] fb0: inteldrmfb frame buffer device
[ 7.967902] drm: registered panic notifier
[ 7.968310] acpi device:50: registered as cooling_device5
[ 7.968486] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 7.968521] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 7.968536] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 7.968564] ACPI Warning: 0x0000f040-0x0000f05f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 7.968569] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 7.968599] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.148548] Adding 16166908k swap on /dev/sda5. Priority:-1 extents:1 across:16166908k SS
[ 8.157085] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 8.195215] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.207976] loop: module loaded
[ 8.560821] RPC: Registered named UNIX socket transport module.
[ 8.560824] RPC: Registered udp transport module.
[ 8.560825] RPC: Registered tcp transport module.
[ 8.560826] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 8.564656] FS-Cache: Loaded
[ 8.569536] NFS: Registering the id_resolver key type
[ 8.569547] FS-Cache: Netfs 'nfs' registered for caching
[ 8.572604] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 8.926343] Bluetooth: Core ver 2.16
[ 8.926355] NET: Registered protocol family 31
[ 8.926356] Bluetooth: HCI device and connection manager initialized
[ 8.926358] Bluetooth: HCI socket layer initialized
[ 8.926360] Bluetooth: L2CAP socket layer initialized
[ 8.926364] Bluetooth: SCO socket layer initialized
[ 8.929750] Bluetooth: RFCOMM TTY layer initialized
[ 8.929754] Bluetooth: RFCOMM socket layer initialized
[ 8.929755] Bluetooth: RFCOMM ver 1.11
[ 8.941082] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.941085] Bluetooth: BNEP filters: protocol multicast
[ 8.947910] lp: driver loaded but no devices found
[ 8.950958] ppdev: user-space parallel port driver
[ 9.815906] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 10.685410] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.781629] r8169 0000:05:00.0: eth0: link down
[ 10.781712] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.456213] wlan0: authenticate with 60:38:e0:d5:e9:43
[ 13.504017] wlan0: send auth to 60:38:e0:d5:e9:43 (try 1/3)
[ 13.505632] wlan0: authenticated
[ 13.531762] wlan0: associate with 60:38:e0:d5:e9:43 (try 1/3)
[ 13.551058] wlan0: RX AssocResp from 60:38:e0:d5:e9:43 (capab=0x411 status=0 aid=5)
[ 13.576360] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.576391] wlan0: associated
[ 23.672535] wlan0: no IPv6 routers present
[ 250.369085] wlan0: deauthenticating from 60:38:e0:d5:e9:43 by local choice (reason=3)
[ 250.662025] cfg80211: Calling CRDA to update world regulatory domain
[ 250.666960] cfg80211: World regulatory domain updated:
[ 250.666963] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 250.666965] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 250.666967] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 250.666968] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 250.666970] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666972] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666973] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 250.666975] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666977] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 261.369384] wlan0: authenticate with 60:38:e0:d5:e9:43
[ 261.417580] wlan0: send auth to 60:38:e0:d5:e9:43 (try 1/3)
[ 261.418756] wlan0: authenticated
[ 261.444923] wlan0: associate with 60:38:e0:d5:e9:43 (try 1/3)
[ 261.464012] wlan0: RX AssocResp from 60:38:e0:d5:e9:43 (capab=0x411 status=0 aid=5)
[ 261.489333] wlan0: associated
[ 273.401117] wlan0: no IPv6 routers present
[ 433.809327] I-pipe: head domain RTAI registered.
[ 433.809331] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 433.809378] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 433.809380] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 433.809382] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 433.809384] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 3886750
[ 433.821570] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 433.821589] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 433.821592] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 433.821594] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 433.821596] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 433.829795] RTAI[math]: loaded.
[ 433.892264] hm2: loading Mesa HostMot2 driver version 0.15
[ 433.894936] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 433.894962] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 433.895288] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 433.950723] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 433.950725] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 433.950727] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 433.950729] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 433.950731] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 433.950733] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 433.950735] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 433.950737] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 433.950738] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 433.950740] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 433.950742] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 433.950744] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 433.950745] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 433.950747] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 433.950748] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 433.950750] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 433.950752] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 433.950754] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 433.950755] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 433.950757] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 433.950758] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 433.950760] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 433.950761] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 433.950763] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 433.950764] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 433.950766] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 433.950767] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 433.950768] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 433.950770] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 433.950771] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 433.950773] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 433.950774] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 433.950776] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 433.950777] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 433.950779] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 433.950815] hm2/hm2_5i25.0: registered
[ 433.950817] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 470.645723] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 470.645727] hm2/hm2_5i25.0: unregistered
[ 470.645755] hm2_pci: driver unloaded
[ 470.646734] hm2: unloading
[ 472.718498] RTAI[math]: unloaded.
[ 472.719491] SCHED releases registered named ALIEN PEDV$D
[ 472.722376] RTAI[malloc]: unloaded.
[ 472.821703] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 472.822820] I-pipe: head domain RTAI unregistered.
[ 472.822870] RTAI[hal]: unmounted.
[ 482.673936] I-pipe: head domain RTAI registered.
[ 482.673940] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 482.673986] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 482.673988] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 482.673990] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 482.673992] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6191000
[ 482.677625] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 482.677645] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 482.677648] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 482.677650] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 482.677652] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 482.681710] RTAI[math]: loaded.
[ 482.722299] hm2: loading Mesa HostMot2 driver version 0.15
[ 482.723419] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 482.723445] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 482.723736] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 482.778992] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 482.778995] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 482.778997] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 482.778999] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 482.779001] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 482.779003] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 482.779005] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 482.779007] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 482.779008] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 482.779010] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 482.779011] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 482.779013] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 482.779014] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 482.779015] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 482.779017] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 482.779018] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 482.779020] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 482.779021] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 482.779023] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 482.779024] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 482.779026] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 482.779027] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 482.779029] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 482.779030] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 482.779031] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 482.779033] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 482.779034] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 482.779036] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 482.779037] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 482.779039] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 482.779040] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 482.779042] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 482.779043] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 482.779045] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 482.779046] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 482.779080] hm2/hm2_5i25.0: registered
[ 482.779082] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 483.627469] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 483.627473] hm2/hm2_5i25.0: unregistered
[ 483.627502] hm2_pci: driver unloaded
[ 483.628469] hm2: unloading
[ 485.697244] RTAI[math]: unloaded.
[ 485.698241] SCHED releases registered named ALIEN PEDV$D
[ 485.700670] RTAI[malloc]: unloaded.
[ 485.797576] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 485.798621] I-pipe: head domain RTAI unregistered.
[ 485.798672] RTAI[hal]: unmounted.
[ 520.175016] I-pipe: head domain RTAI registered.
[ 520.175020] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 520.175065] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 520.175068] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 520.175070] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 520.175072] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6227500
[ 520.178697] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 520.178718] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 520.178721] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 520.178723] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 520.178725] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 520.183820] RTAI[math]: loaded.
[ 520.223844] hm2: loading Mesa HostMot2 driver version 0.15
[ 520.224921] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 520.224948] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 520.225239] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 520.280559] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 520.280561] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 520.280563] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 520.280565] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 520.280567] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 520.280569] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 520.280571] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 520.280572] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 520.280574] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 520.280575] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 520.280577] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 520.280578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 520.280580] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 520.280581] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 520.280583] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 520.280584] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 520.280586] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 520.280587] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 520.280589] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 520.280590] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 520.280591] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 520.280593] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 520.280594] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 520.280596] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 520.280597] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 520.280599] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 520.280600] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 520.280602] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 520.280603] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 520.280605] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 520.280606] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 520.280608] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 520.280609] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 520.280611] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 520.280612] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 520.280646] hm2/hm2_5i25.0: registered
[ 520.280648] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 521.076213] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 521.076217] hm2/hm2_5i25.0: unregistered
[ 521.076246] hm2_pci: driver unloaded
[ 521.077205] hm2: unloading
[ 523.145988] RTAI[math]: unloaded.
[ 523.146983] SCHED releases registered named ALIEN PEDV$D
[ 523.149534] RTAI[malloc]: unloaded.
[ 523.245669] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 523.246769] I-pipe: head domain RTAI unregistered.
[ 523.246820] RTAI[hal]: unmounted.
[ 638.488133] I-pipe: head domain RTAI registered.
[ 638.488136] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 638.488181] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 638.488184] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 638.488186] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 638.488188] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6181750
[ 638.491809] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 638.491829] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 638.491832] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 638.491834] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 638.491836] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 638.497574] RTAI[math]: loaded.
[ 638.537589] hm2: loading Mesa HostMot2 driver version 0.15
[ 638.538653] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 638.538679] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 638.538971] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 638.594324] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 638.594327] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 638.594329] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 638.594331] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 638.594333] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 638.594335] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 638.594336] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 638.594338] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 638.594340] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 638.594341] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 638.594343] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 638.594344] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 638.594345] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 638.594347] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 638.594348] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 638.594350] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 638.594351] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 638.594353] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 638.594354] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 638.594356] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 638.594357] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 638.594359] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 638.594360] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 638.594362] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 638.594363] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 638.594364] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 638.594366] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 638.594367] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 638.594369] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 638.594370] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 638.594372] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 638.594373] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 638.594375] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 638.594376] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 638.594378] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 638.594412] hm2/hm2_5i25.0: registered
[ 638.594414] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 639.376626] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 639.376629] hm2/hm2_5i25.0: unregistered
[ 639.376658] hm2_pci: driver unloaded
[ 639.377633] hm2: unloading
[ 641.446781] RTAI[math]: unloaded.
[ 641.447771] SCHED releases registered named ALIEN PEDV$D
[ 641.450021] RTAI[malloc]: unloaded.
[ 641.548046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 641.549096] I-pipe: head domain RTAI unregistered.
[ 641.549147] RTAI[hal]: unmounted.
[ 703.526890] I-pipe: head domain RTAI registered.
[ 703.526894] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 703.526939] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 703.526942] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 703.526944] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 703.526946] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5034000
[ 703.530594] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 703.530614] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 703.530617] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 703.530619] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 703.530621] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 703.535526] RTAI[math]: loaded.
[ 708.116832] RTAI[math]: unloaded.
[ 708.117839] SCHED releases registered named ALIEN PEDV$D
[ 708.120712] RTAI[malloc]: unloaded.
[ 708.218839] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 708.219886] I-pipe: head domain RTAI unregistered.
[ 708.219938] RTAI[hal]: unmounted.
[ 1196.729820] I-pipe: head domain RTAI registered.
[ 1196.729824] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1196.729869] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1196.729871] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 1196.729874] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1196.729876] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5478250
[ 1196.733530] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1196.733551] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1196.733554] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 1196.733557] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 1196.733558] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1196.738517] RTAI[math]: loaded.
[ 1196.778659] hm2: loading Mesa HostMot2 driver version 0.15
[ 1196.779814] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1196.779843] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 1196.780169] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1196.835492] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1196.835494] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 1196.835497] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 1196.835499] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 1196.835501] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 1196.835502] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 1196.835504] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 1196.835506] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 1196.835508] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 1196.835510] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 1196.835512] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 1196.835513] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1196.835515] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1196.835516] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1196.835518] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1196.835520] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 1196.835521] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 1196.835523] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 1196.835525] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1196.835526] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1196.835528] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1196.835529] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1196.835531] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1196.835532] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1196.835533] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1196.835535] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 1196.835536] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 1196.835538] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 1196.835539] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1196.835541] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1196.835542] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1196.835544] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1196.835545] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1196.835547] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1196.835548] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1196.835584] hm2/hm2_5i25.0: registered
[ 1196.835586] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 1206.312947] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 1206.312950] hm2/hm2_5i25.0: unregistered
[ 1206.312980] hm2_pci: driver unloaded
[ 1206.313958] hm2: unloading
[ 1208.383307] RTAI[math]: unloaded.
[ 1208.384307] SCHED releases registered named ALIEN PEDV$D
[ 1208.387092] RTAI[malloc]: unloaded.
[ 1208.483746] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1208.484799] I-pipe: head domain RTAI unregistered.
[ 1208.484851] RTAI[hal]: unmounted.
[ 1405.156989] I-pipe: head domain RTAI registered.
[ 1405.156993] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1405.157038] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1405.157041] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 1405.157043] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1405.157045] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6191500
[ 1405.160694] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1405.160714] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1405.160717] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 1405.160719] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 1405.160721] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1405.165853] RTAI[math]: loaded.
[ 1405.205917] hm2: loading Mesa HostMot2 driver version 0.15
[ 1405.206984] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1405.207012] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 1405.207304] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1405.262501] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1405.262503] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 1405.262505] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 1405.262507] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 1405.262509] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 1405.262511] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 1405.262513] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 1405.262515] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1405.262516] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1405.262518] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1405.262519] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1405.262521] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1405.262522] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1405.262523] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1405.262525] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1405.262526] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1405.262528] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1405.262529] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1405.262531] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1405.262532] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1405.262534] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1405.262535] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1405.262537] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1405.262538] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1405.262539] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1405.262541] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 1405.262542] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 1405.262544] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 1405.262545] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1405.262547] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1405.262548] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1405.262550] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1405.262551] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1405.262553] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1405.262554] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1405.262588] hm2/hm2_5i25.0: registered
[ 1405.262590] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 1406.114390] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 1406.114394] hm2/hm2_5i25.0: unregistered
[ 1406.114422] hm2_pci: driver unloaded
[ 1406.115374] hm2: unloading
[ 1408.186629] RTAI[math]: unloaded.
[ 1408.187626] SCHED releases registered named ALIEN PEDV$D
[ 1408.190217] RTAI[malloc]: unloaded.
[ 1408.288199] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1408.289262] I-pipe: head domain RTAI unregistered.
[ 1408.289313] RTAI[hal]: unmounted.
[ 2129.361658] I-pipe: head domain RTAI registered.
[ 2129.361662] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2129.361707] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2129.361710] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 2129.361712] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2129.361714] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 4789750
[ 2129.365333] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2129.365353] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2129.365356] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 2129.365358] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 2129.365360] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 2129.370213] RTAI[math]: loaded.
[ 2129.410546] hm2: loading Mesa HostMot2 driver version 0.15
[ 2129.411636] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2129.411662] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 2129.411986] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2129.467255] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2129.467258] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 2129.467260] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 2129.467262] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 2129.467264] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 2129.467266] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 2129.467268] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 2129.467270] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 2129.467271] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 2129.467273] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 2129.467275] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 2129.467277] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2129.467278] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2129.467280] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2129.467281] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2129.467283] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 2129.467285] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 2129.467286] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 2129.467288] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2129.467289] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2129.467291] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2129.467292] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2129.467294] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2129.467295] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2129.467297] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2129.467298] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 2129.467300] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 2129.467301] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 2129.467303] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 2129.467304] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 2129.467305] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 2129.467307] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 2129.467308] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 2129.467310] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 2129.467311] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 2129.467348] hm2/hm2_5i25.0: registered
[ 2129.467349] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 2185.639894] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 2185.639897] hm2/hm2_5i25.0: unregistered
[ 2185.639926] hm2_pci: driver unloaded
[ 2185.640877] hm2: unloading
[ 2187.712476] RTAI[math]: unloaded.
[ 2187.713478] SCHED releases registered named ALIEN PEDV$D
[ 2187.716218] RTAI[malloc]: unloaded.
[ 2187.812291] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2187.813351] I-pipe: head domain RTAI unregistered.
[ 2187.813401] RTAI[hal]: unmounted.
[ 3316.328673] I-pipe: head domain RTAI registered.
[ 3316.328677] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3316.328722] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3316.328725] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 3316.328727] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3316.328729] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5759500
[ 3316.332346] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3316.332364] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3316.332367] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3316.332370] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 3316.332371] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3316.337483] RTAI[math]: loaded.
[ 3316.377540] hm2: loading Mesa HostMot2 driver version 0.15
[ 3316.378607] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3316.378634] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 3316.378925] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3316.434173] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3316.434175] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 3316.434177] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 3316.434179] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 3316.434181] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 3316.434183] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 3316.434185] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 3316.434187] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3316.434188] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3316.434190] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3316.434191] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3316.434193] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3316.434194] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3316.434195] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3316.434197] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3316.434198] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3316.434200] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3316.434201] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3316.434203] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3316.434204] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3316.434206] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3316.434207] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3316.434209] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3316.434210] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3316.434212] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3316.434213] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3316.434215] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3316.434216] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3316.434217] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3316.434219] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3316.434220] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3316.434222] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3316.434223] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3316.434225] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3316.434226] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3316.434261] hm2/hm2_5i25.0: registered
[ 3316.434262] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 3317.291261] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 3317.291265] hm2/hm2_5i25.0: unregistered
[ 3317.291294] hm2_pci: driver unloaded
[ 3317.292257] hm2: unloading
[ 3319.364957] RTAI[math]: unloaded.
[ 3319.365951] SCHED releases registered named ALIEN PEDV$D
[ 3319.368424] RTAI[malloc]: unloaded.
[ 3319.468393] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3319.469446] I-pipe: head domain RTAI unregistered.
[ 3319.469498] RTAI[hal]: unmounted.
FWIW, The physical card in my computer is a 6i25 card with no changes i.e. jumpers. It's my understanding that it is completely 5i25 compatible in this state)
Below is the output I get when the application terminates. (Note, If it makes a difference, I am running the application right now with nothing connected to the card in the computer)
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/frank/linuxcnc/configs/franks_cnc_router'
Machine configuration file is 'franks_cnc_router.ini'
INIFILE=/home/frank/linuxcnc/configs/franks_cnc_router/franks_cnc_router.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./franks_cnc_router.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
spindle-vfd: device='/dev/ttyS0', baud=9600, parity='N', bits=8, stopbits=2, address=1, enabled=1
spindle-vfd: ERROR: couldn't open serial device: Input/output error
Running HAL shutdown script
task: 76 cycles, min=0.000005, max=0.022284, avg=0.008223, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
mitsub_vfd.hal:12: waitpid failed gs2_vfd spindle-vfd
mitsub_vfd.hal:12: gs2_vfd exited without becoming ready
8289
8338
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[ 0.000000] BIOS-e820: 0000000020200000 - 0000000040000000 (usable)
[ 0.000000] BIOS-e820: 0000000040000000 - 0000000040200000 (reserved)
[ 0.000000] BIOS-e820: 0000000040200000 - 00000000ce14e000 (usable)
[ 0.000000] BIOS-e820: 00000000ce14e000 - 00000000ce941000 (reserved)
[ 0.000000] BIOS-e820: 00000000ce941000 - 00000000ceb95000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ceb95000 - 00000000ceba2000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000ceba2000 - 00000000cebc1000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cebc1000 - 00000000cebc6000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cebc6000 - 00000000cec09000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cec09000 - 00000000cf000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf800000 - 00000000dfa00000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021f600000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: ASUSTeK Computer INC. CM6630_CM6730_CM6830./CM6330_CM6630_CM6730_CM6830, BIOS 4101 09/04/2012
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D7FFF write-protect
[ 0.000000] D8000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 4 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 5 base 21F800000 mask FFF800000 uncachable
[ 0.000000] 6 base 21F600000 mask FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fcd90] fcd90
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0097000] 97000 size 16384
[ 0.000000] reserving inaccessible SNB gfx pages
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36416000 - 37203000
[ 0.000000] ACPI: RSDP 000f0450 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT ceb95078 0006C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP ceb9f558 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT ceb95180 0A3D3 (v02 ALASKA A M I 00000015 INTL 20051117)
[ 0.000000] ACPI: FACS cebbff80 00040
[ 0.000000] ACPI: APIC ceb9f650 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG ceb9f6c8 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET ceb9f708 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT ceb9f740 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT ceb9fab0 009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT ceba0460 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: BGRT ceba10c8 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SLIC ceba0f50 00176 (v01 _ASUS_ Notebook 00000000 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2424MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020200 -> 0x00040000
[ 0.000000] 0: 0x00040200 -> 0x000ce14e
[ 0.000000] 0: 0x000cec09 -> 0x000cf000
[ 0.000000] On node 0 totalpages: 843986
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4a36200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4849 pages used for memmap
[ 0.000000] HighMem zone: 612438 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[ 0.000000] Allocating PCI resources starting at dfa00000 (gap: dfa00000:18600000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 837361
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=7adbfe91-4260-44a3-9049-54aa19e103e9 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6782848 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf000)
[ 0.000000] Memory: 3321004k/3391488k available (3495k kernel code, 54940k reserved, 1237k data, 416k init, 2469148k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2993.078 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 5986.15 BogoMIPS (lpj=11972312)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.000032] Security Framework initialized
[ 0.000036] AppArmor: AppArmor disabled by boot time parameter
[ 0.000047] Mount-cache hash table entries: 512
[ 0.000177] Initializing cgroup subsys cpuacct
[ 0.000179] Initializing cgroup subsys memory
[ 0.000184] Initializing cgroup subsys devices
[ 0.000186] Initializing cgroup subsys freezer
[ 0.000187] Initializing cgroup subsys net_cls
[ 0.000189] Initializing cgroup subsys blkio
[ 0.000193] Initializing cgroup subsys perf_event
[ 0.000213] CPU: Physical Processor ID: 0
[ 0.000214] CPU: Processor Core ID: 0
[ 0.000217] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000218] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000220] mce: CPU supports 9 MCE banks
[ 0.000230] CPU0: Thermal monitoring enabled (TM1)
[ 0.000302] ACPI: Core revision 20120320
[ 0.019520] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.019910] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.059581] CPU0: Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz stepping 07
[ 0.164964] Performance Events: PEBS fmt1+, 16-deep LBR, SandyBridge events, Intel PMU driver.
[ 0.164970] PEBS disabled due to CPU errata.
[ 0.164972] ... version: 3
[ 0.164973] ... bit width: 48
[ 0.164974] ... generic registers: 8
[ 0.164976] ... value mask: 0000ffffffffffff
[ 0.164977] ... max period: 000000007fffffff
[ 0.164978] ... fixed-purpose events: 3
[ 0.164979] ... event mask: 00000007000000ff
[ 0.177014] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.188975] CPU 1 irqstacks, hard=f3cd8000 soft=f3cda000
[ 0.188977] Booting Node 0, Processors #1
[ 0.199277] Initializing CPU#1
[ 0.202121] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.208972] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.208975] #2
[ 0.219211] Initializing CPU#2
[ 0.222116] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.228963] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[ 0.228966] #3 Ok.
[ 0.239202] Initializing CPU#3
[ 0.242107] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.242132] Brought up 4 CPUs
[ 0.242134] Total of 4 processors activated (23944.62 BogoMIPS).
[ 0.244495] devtmpfs: initialized
[ 0.244665] PM: Registering ACPI NVS region [mem 0xce941000-0xceb94fff] (2441216 bytes)
[ 0.244731] PM: Registering ACPI NVS region [mem 0xceba2000-0xcebc0fff] (126976 bytes)
[ 0.244736] PM: Registering ACPI NVS region [mem 0xcebc6000-0xcec08fff] (274432 bytes)
[ 0.244815] dummy:
[ 0.244858] NET: Registered protocol family 16
[ 0.244951] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.244953] ACPI: bus type pci registered
[ 0.244996] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.244998] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.245000] PCI: Using MMCONFIG for extended config space
[ 0.245001] PCI: Using configuration type 1 for base access
[ 0.245461] bio: create slab <bio-0> at 0
[ 0.245532] ACPI: Added _OSI(Module Device)
[ 0.245534] ACPI: Added _OSI(Processor Device)
[ 0.245535] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.245537] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.247303] ACPI: EC: Look up EC in DSDT
[ 0.249237] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.253390] ACPI: SSDT ce8ee018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.253861] ACPI: Dynamic OEM Table Load:
[ 0.253864] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.254157] ACPI: SSDT ce8efa98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.254669] ACPI: Dynamic OEM Table Load:
[ 0.254671] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.254803] ACPI: SSDT ce8f0c18 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.255269] ACPI: Dynamic OEM Table Load:
[ 0.255271] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.255920] ACPI: Interpreter enabled
[ 0.255931] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.255955] ACPI: Using IOAPIC for interrupt routing
[ 0.261391] ACPI: Power Resource [FN00] (off)
[ 0.261466] ACPI: Power Resource [FN01] (off)
[ 0.261539] ACPI: Power Resource [FN02] (off)
[ 0.261611] ACPI: Power Resource [FN03] (off)
[ 0.261683] ACPI: Power Resource [FN04] (off)
[ 0.262205] ACPI: No dock devices found.
[ 0.262210] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.262564] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.263091] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.263093] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.263095] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.263097] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.263099] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.263101] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.263103] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.263105] pci_root PNP0A08:00: host bridge window [mem 0xdfa00000-0xfeafffff]
[ 0.263129] PCI host bridge to bus 0000:00
[ 0.263131] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.263133] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.263134] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.263136] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.263138] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.263140] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.263141] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.263143] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff]
[ 0.263151] pci 0000:00:00.0: [8086:0100] type 00 class 0x060000
[ 0.263181] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[ 0.263204] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.263222] pci 0000:00:02.0: [8086:0102] type 00 class 0x030000
[ 0.263232] pci 0000:00:02.0: reg 10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.263238] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.263242] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.263288] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.263311] pci 0000:00:16.0: reg 10: [mem 0xf7c06000-0xf7c0600f 64bit]
[ 0.263372] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.263405] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.263426] pci 0000:00:1a.0: reg 10: [mem 0xf7c04000-0xf7c043ff]
[ 0.263499] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.263522] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.263585] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.263610] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.263672] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.263696] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[ 0.263758] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.263783] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[ 0.263846] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.263870] pci 0000:00:1c.4: [8086:244e] type 01 class 0x060401
[ 0.263932] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.263957] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
[ 0.264019] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.264049] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.264069] pci 0000:00:1d.0: reg 10: [mem 0xf7c03000-0xf7c033ff]
[ 0.264143] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.264168] pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
[ 0.264281] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[ 0.264299] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.264307] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.264314] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.264322] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.264329] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.264337] pci 0000:00:1f.2: reg 24: [mem 0xf7c02000-0xf7c027ff]
[ 0.264369] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.264386] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.264401] pci 0000:00:1f.3: reg 10: [mem 0xf7c01000-0xf7c010ff 64bit]
[ 0.264422] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.264464] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.264540] pci 0000:02:00.0: [104c:8240] type 01 class 0x060400
[ 0.264656] pci 0000:02:00.0: supports D1 D2
[ 0.268948] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.268956] pci 0000:00:1c.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.269079] pci 0000:03:00.0: [2718:5125] type 00 class 0x110000
[ 0.269104] pci 0000:03:00.0: reg 10: [mem 0xf7b00000-0xf7b0ffff]
[ 0.269293] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.269307] pci 0000:02:00.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.269392] pci 0000:04:00.0: [1814:3090] type 00 class 0x028000
[ 0.269412] pci 0000:04:00.0: reg 10: [mem 0xf7a00000-0xf7a0ffff]
[ 0.276944] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.276952] pci 0000:00:1c.1: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.277036] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000
[ 0.277056] pci 0000:05:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.277090] pci 0000:05:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.277112] pci 0000:05:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.277172] pci 0000:05:00.0: supports D1 D2
[ 0.277173] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.284940] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.284946] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.284957] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.285041] pci 0000:06:00.0: [1b21:1042] type 00 class 0x0c0330
[ 0.285070] pci 0000:06:00.0: reg 10: [mem 0xf7900000-0xf7907fff 64bit]
[ 0.285196] pci 0000:06:00.0: PME# supported from D3hot D3cold
[ 0.292935] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.292944] pci 0000:00:1c.3: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.293022] pci 0000:07:00.0: [1b21:1080] type 01 class 0x060401
[ 0.293128] pci 0000:00:1c.4: PCI bridge to [bus 07-08] (subtractive decode)
[ 0.293138] pci 0000:00:1c.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.293140] pci 0000:00:1c.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.293142] pci 0000:00:1c.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.293144] pci 0000:00:1c.4: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.293146] pci 0000:00:1c.4: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.293148] pci 0000:00:1c.4: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.293150] pci 0000:00:1c.4: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.293152] pci 0000:00:1c.4: bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[ 0.293267] pci 0000:07:00.0: PCI bridge to [bus 08-08] (subtractive decode)
[ 0.293289] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293291] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293293] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293295] pci 0000:07:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.293297] pci 0000:07:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.293299] pci 0000:07:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.293300] pci 0000:07:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.293302] pci 0000:07:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.293304] pci 0000:07:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.293306] pci 0000:07:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.293308] pci 0000:07:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.293310] pci 0000:07:00.0: bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[ 0.293385] pci 0000:09:00.0: [1b21:0612] type 00 class 0x010601
[ 0.293404] pci 0000:09:00.0: reg 10: [io 0xd050-0xd057]
[ 0.293418] pci 0000:09:00.0: reg 14: [io 0xd040-0xd043]
[ 0.293431] pci 0000:09:00.0: reg 18: [io 0xd030-0xd037]
[ 0.293445] pci 0000:09:00.0: reg 1c: [io 0xd020-0xd023]
[ 0.293459] pci 0000:09:00.0: reg 20: [io 0xd000-0xd01f]
[ 0.293473] pci 0000:09:00.0: reg 24: [mem 0xf7800000-0xf78001ff]
[ 0.300932] pci 0000:00:1c.5: PCI bridge to [bus 09-09]
[ 0.300938] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.300943] pci 0000:00:1c.5: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.300991] pci_bus 0000:00: on NUMA node 0
[ 0.300993] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.301222] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.301266] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.301309] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.301352] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.301395] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.301439] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05.P8P9._PRT]
[ 0.301477] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.301527] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.301649] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.306954] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.307002] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 6 10 11 12 14 15)
[ 0.307049] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.307095] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.307141] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.307189] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.307235] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.307282] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.307339] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.307348] vgaarb: loaded
[ 0.307349] vgaarb: bridge control possible 0000:00:02.0
[ 0.307369] PCI: Using ACPI for IRQ routing
[ 0.308760] PCI: pci_cache_line_size set to 64 bytes
[ 0.308841] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.308843] reserve RAM buffer: 00000000ce14e000 - 00000000cfffffff
[ 0.308845] reserve RAM buffer: 00000000cf000000 - 00000000cfffffff
[ 0.308942] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.308949] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.311965] Switching to clocksource hpet
[ 0.312007] pnp: PnP ACPI init
[ 0.312015] ACPI: bus type pnp registered
[ 0.312297] pnp 00:00: [bus 00-3e]
[ 0.312299] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.312301] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.312303] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.312305] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.312306] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.312308] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.312310] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.312311] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.312313] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.312315] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.312316] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.312318] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.312320] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.312321] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.312323] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.312325] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.312327] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.312328] pnp 00:00: [mem 0xdfa00000-0xfeafffff window]
[ 0.312330] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.312373] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.312395] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.312425] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.312427] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.312438] pnp 00:02: [io 0x0000-0x001f]
[ 0.312439] pnp 00:02: [io 0x0081-0x0091]
[ 0.312441] pnp 00:02: [io 0x0093-0x009f]
[ 0.312442] pnp 00:02: [io 0x00c0-0x00df]
[ 0.312444] pnp 00:02: [dma 4]
[ 0.312459] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.312467] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.312483] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.312543] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.312564] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.312574] pnp 00:05: [io 0x002e-0x002f]
[ 0.312576] pnp 00:05: [io 0x004e-0x004f]
[ 0.312577] pnp 00:05: [io 0x0061]
[ 0.312579] pnp 00:05: [io 0x0063]
[ 0.312580] pnp 00:05: [io 0x0065]
[ 0.312582] pnp 00:05: [io 0x0067]
[ 0.312583] pnp 00:05: [io 0x0070]
[ 0.312584] pnp 00:05: [io 0x0080]
[ 0.312586] pnp 00:05: [io 0x0092]
[ 0.312587] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.312589] pnp 00:05: [io 0x0680-0x069f]
[ 0.312590] pnp 00:05: [io 0x0200-0x020f]
[ 0.312592] pnp 00:05: [io 0xffff]
[ 0.312593] pnp 00:05: [io 0xffff]
[ 0.312594] pnp 00:05: [io 0x0400-0x0453]
[ 0.312596] pnp 00:05: [io 0x0458-0x047f]
[ 0.312597] pnp 00:05: [io 0x0500-0x057f]
[ 0.312599] pnp 00:05: [io 0x164e-0x164f]
[ 0.312632] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.312634] system 00:05: [io 0x0200-0x020f] has been reserved
[ 0.312636] system 00:05: [io 0xffff] has been reserved
[ 0.312638] system 00:05: [io 0xffff] has been reserved
[ 0.312640] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.312642] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.312644] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.312646] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.312648] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312657] pnp 00:06: [io 0x0070-0x0077]
[ 0.312663] pnp 00:06: [irq 8]
[ 0.312679] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.312703] pnp 00:07: [io 0x0454-0x0457]
[ 0.312732] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.312734] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.312789] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312791] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312792] pnp 00:08: [io 0x0290-0x029f]
[ 0.312794] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.312822] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.312825] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312844] pnp 00:09: [io 0x0010-0x001f]
[ 0.312846] pnp 00:09: [io 0x0022-0x003f]
[ 0.312847] pnp 00:09: [io 0x0044-0x005f]
[ 0.312849] pnp 00:09: [io 0x0062-0x0063]
[ 0.312850] pnp 00:09: [io 0x0065-0x006f]
[ 0.312852] pnp 00:09: [io 0x0072-0x007f]
[ 0.312853] pnp 00:09: [io 0x0080]
[ 0.312855] pnp 00:09: [io 0x0084-0x0086]
[ 0.312856] pnp 00:09: [io 0x0088]
[ 0.312857] pnp 00:09: [io 0x008c-0x008e]
[ 0.312859] pnp 00:09: [io 0x0090-0x009f]
[ 0.312860] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.312862] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.312863] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.312895] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.312897] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.312904] pnp 00:0a: [io 0x00f0-0x00ff]
[ 0.312909] pnp 00:0a: [irq 13]
[ 0.312934] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.313191] pnp 00:0b: [mem 0xfed1c000-0xfed1ffff]
[ 0.313193] pnp 00:0b: [mem 0xfed10000-0xfed17fff]
[ 0.313194] pnp 00:0b: [mem 0xfed18000-0xfed18fff]
[ 0.313196] pnp 00:0b: [mem 0xfed19000-0xfed19fff]
[ 0.313197] pnp 00:0b: [mem 0xf8000000-0xfbffffff]
[ 0.313199] pnp 00:0b: [mem 0xfed20000-0xfed3ffff]
[ 0.313201] pnp 00:0b: [mem 0xfed90000-0xfed93fff]
[ 0.313202] pnp 00:0b: [mem 0xfed45000-0xfed8ffff]
[ 0.313204] pnp 00:0b: [mem 0xff000000-0xffffffff]
[ 0.313205] pnp 00:0b: [mem 0xfee00000-0xfeefffff]
[ 0.313207] pnp 00:0b: [mem 0xdfa00000-0xdfa00fff]
[ 0.313257] system 00:0b: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.313259] system 00:0b: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.313261] system 00:0b: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.313263] system 00:0b: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.313265] system 00:0b: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.313268] system 00:0b: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.313270] system 00:0b: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.313272] system 00:0b: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.313274] system 00:0b: [mem 0xff000000-0xffffffff] has been reserved
[ 0.313276] system 00:0b: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.313278] system 00:0b: [mem 0xdfa00000-0xdfa00fff] has been reserved
[ 0.313280] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.313416] pnp 00:0c: [mem 0x20000000-0x201fffff]
[ 0.313418] pnp 00:0c: [mem 0x40000000-0x401fffff]
[ 0.313467] system 00:0c: [mem 0x20000000-0x201fffff] has been reserved
[ 0.313469] system 00:0c: [mem 0x40000000-0x401fffff] has been reserved
[ 0.313471] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.313495] pnp: PnP ACPI: found 13 devices
[ 0.313496] ACPI: ACPI bus type pnp unregistered
[ 0.313498] PnPBIOS: Disabled by ACPI PNP
[ 0.349572] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.349578] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.349586] pci 0000:02:00.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.349600] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.349605] pci 0000:00:1c.0: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.349613] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.349617] pci 0000:00:1c.1: bridge window [mem 0xf7a00000-0xf7afffff]
[ 0.349625] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.349628] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.349635] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.349641] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.349646] pci 0000:00:1c.3: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.349654] pci 0000:07:00.0: PCI bridge to [bus 08-08]
[ 0.349673] pci 0000:00:1c.4: PCI bridge to [bus 07-08]
[ 0.349684] pci 0000:00:1c.5: PCI bridge to [bus 09-09]
[ 0.349687] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.349691] pci 0000:00:1c.5: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.349761] pci 0000:07:00.0: setting latency timer to 64
[ 0.349771] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.349773] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.349775] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.349776] pci_bus 0000:00: resource 7 [mem 0x000d8000-0x000dbfff]
[ 0.349778] pci_bus 0000:00: resource 8 [mem 0x000dc000-0x000dffff]
[ 0.349780] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.349782] pci_bus 0000:00: resource 10 [mem 0x000e4000-0x000e7fff]
[ 0.349783] pci_bus 0000:00: resource 11 [mem 0xdfa00000-0xfeafffff]
[ 0.349785] pci_bus 0000:02: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.349787] pci_bus 0000:03: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.349789] pci_bus 0000:04: resource 1 [mem 0xf7a00000-0xf7afffff]
[ 0.349790] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 0.349792] pci_bus 0000:05: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.349794] pci_bus 0000:06: resource 1 [mem 0xf7900000-0xf79fffff]
[ 0.349796] pci_bus 0000:07: resource 4 [io 0x0000-0x0cf7]
[ 0.349797] pci_bus 0000:07: resource 5 [io 0x0d00-0xffff]
[ 0.349799] pci_bus 0000:07: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.349801] pci_bus 0000:07: resource 7 [mem 0x000d8000-0x000dbfff]
[ 0.349802] pci_bus 0000:07: resource 8 [mem 0x000dc000-0x000dffff]
[ 0.349804] pci_bus 0000:07: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.349806] pci_bus 0000:07: resource 10 [mem 0x000e4000-0x000e7fff]
[ 0.349808] pci_bus 0000:07: resource 11 [mem 0xdfa00000-0xfeafffff]
[ 0.349809] pci_bus 0000:08: resource 8 [io 0x0000-0x0cf7]
[ 0.349811] pci_bus 0000:08: resource 9 [io 0x0d00-0xffff]
[ 0.349813] pci_bus 0000:08: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.349814] pci_bus 0000:08: resource 11 [mem 0x000d8000-0x000dbfff]
[ 0.349816] pci_bus 0000:08: resource 12 [mem 0x000dc000-0x000dffff]
[ 0.349818] pci_bus 0000:08: resource 13 [mem 0x000e0000-0x000e3fff]
[ 0.349819] pci_bus 0000:08: resource 14 [mem 0x000e4000-0x000e7fff]
[ 0.349821] pci_bus 0000:08: resource 15 [mem 0xdfa00000-0xfeafffff]
[ 0.349823] pci_bus 0000:09: resource 0 [io 0xd000-0xdfff]
[ 0.349824] pci_bus 0000:09: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.349888] NET: Registered protocol family 2
[ 0.349928] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.350046] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.350212] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.350283] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.350284] TCP: reno registered
[ 0.350286] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350290] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350346] NET: Registered protocol family 1
[ 0.350678] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
[ 0.350846] pci 0000:00:02.0: Boot video device
[ 0.599963] PCI: CLS 64 bytes, default 64
[ 0.599990] Unpacking initramfs...
[ 0.815542] Freeing initrd memory: 14260k freed
[ 0.817464] audit: initializing netlink socket (disabled)
[ 0.817478] type=2000 audit(1600962520.700:1): initialized
[ 0.827073] highmem bounce pool size: 64 pages
[ 0.827076] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.827230] VFS: Disk quotas dquot_6.5.2
[ 0.827251] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.827303] msgmni has been set to 1691
[ 0.827417] alg: No test for stdrng (krng)
[ 0.827438] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.827441] io scheduler noop registered
[ 0.827442] io scheduler deadline registered
[ 0.827459] io scheduler cfq registered (default)
[ 0.827766] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.827777] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.827779] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.828206] GHES: HEST is not enabled!
[ 0.828213] isapnp: Scanning for PnP cards...
[ 1.183057] isapnp: No Plug & Play device found
[ 1.183085] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.183470] Linux agpgart interface v0.103
[ 1.183553] agpgart-intel 0000:00:00.0: Intel Sandybridge Chipset
[ 1.183599] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 1.184346] agpgart-intel 0000:00:00.0: detected 262144K stolen memory
[ 1.184435] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.184538] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.187011] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.187033] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.187100] mousedev: PS/2 mouse device common for all mice
[ 1.187137] rtc_cmos 00:06: RTC can wake from S4
[ 1.187248] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.187273] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.187367] TCP: cubic registered
[ 1.187419] NET: Registered protocol family 10
[ 1.187570] Mobile IPv6
[ 1.187572] NET: Registered protocol family 17
[ 1.187575] Registering the dns_resolver key type
[ 1.187614] Using IPI No-Shortcut mode
[ 1.187678] PM: Hibernation image not present or could not be loaded.
[ 1.187702] registered taskstats version 1
[ 1.188154] rtc_cmos 00:06: setting system clock to 2020-09-24 15:48:41 UTC (1600962521)
[ 1.188242] Freeing unused kernel memory: 416k freed
[ 1.188339] Write protecting the kernel text: 3496k
[ 1.188357] Write protecting the kernel read-only data: 984k
[ 1.195995] udevd[57]: starting version 175
[ 1.206501] usbcore: registered new interface driver usbfs
[ 1.212521] usbcore: registered new interface driver hub
[ 1.212659] SCSI subsystem initialized
[ 1.213445] usbcore: registered new device driver usb
[ 1.213680] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.213726] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.213729] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.213745] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.213765] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.214620] microcode: CPU0 sig=0x206a7, pf=0x2, revision=0x28
[ 1.214726] libata version 3.00 loaded.
[ 1.214998] ACPI: Fan [FAN0] (off)
[ 1.216066] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.216287] r8169 0000:05:00.0: eth0: RTL8168evl/8111evl at 0xf8012000, 54:04:a6:f2:d7:a5, XID 0c900800 IRQ 18
[ 1.216290] r8169 0000:05:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.217665] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.217682] ehci_hcd 0000:00:1a.0: irq 23, io mem 0xf7c04000
[ 1.218291] ACPI: Fan [FAN1] (off)
[ 1.218325] ACPI: Fan [FAN2] (off)
[ 1.218355] ACPI: Fan [FAN3] (off)
[ 1.218383] ACPI: Fan [FAN4] (off)
[ 1.227706] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.227728] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.227730] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.227732] usb usb1: Product: EHCI Host Controller
[ 1.227733] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.227735] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.227823] hub 1-0:1.0: USB hub found
[ 1.227827] hub 1-0:1.0: 2 ports detected
[ 1.227922] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.227926] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.227932] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.227946] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.227953] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.227955] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 3
[ 1.231856] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.231864] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7c03000
[ 1.232429] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.232432] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.232434] usb usb3: Product: xHCI Host Controller
[ 1.232436] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.232437] usb usb3: SerialNumber: 0000:06:00.0
[ 1.233119] xHCI xhci_add_endpoint called for root hub
[ 1.233121] xHCI xhci_check_bandwidth called for root hub
[ 1.233143] hub 3-0:1.0: USB hub found
[ 1.233150] hub 3-0:1.0: 2 ports detected
[ 1.233210] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.233215] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 4
[ 1.233239] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.233241] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.233243] usb usb4: Product: xHCI Host Controller
[ 1.233244] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.233246] usb usb4: SerialNumber: 0000:06:00.0
[ 1.233711] xHCI xhci_add_endpoint called for root hub
[ 1.233713] xHCI xhci_check_bandwidth called for root hub
[ 1.233733] hub 4-0:1.0: USB hub found
[ 1.233740] hub 4-0:1.0: 2 ports detected
[ 1.238481] microcode: CPU0 updated to revision 0x29, date = 2013-06-12
[ 1.238492] microcode: CPU1 sig=0x206a7, pf=0x2, revision=0x28
[ 1.240526] microcode: CPU1 updated to revision 0x29, date = 2013-06-12
[ 1.240535] microcode: CPU2 sig=0x206a7, pf=0x2, revision=0x28
[ 1.242181] microcode: CPU2 updated to revision 0x29, date = 2013-06-12
[ 1.242187] microcode: CPU3 sig=0x206a7, pf=0x2, revision=0x28
[ 1.243696] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.243714] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.243716] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.243718] usb usb2: Product: EHCI Host Controller
[ 1.243719] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.243721] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.243804] hub 2-0:1.0: USB hub found
[ 1.243808] hub 2-0:1.0: 2 ports detected
[ 1.243822] microcode: CPU3 updated to revision 0x29, date = 2013-06-12
[ 1.243867] ahci 0000:00:1f.2: version 3.0
[ 1.243879] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.259700] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x33 impl SATA mode
[ 1.259706] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 1.259720] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.284074] scsi0 : ahci
[ 1.284160] scsi1 : ahci
[ 1.284214] scsi2 : ahci
[ 1.284266] scsi3 : ahci
[ 1.284316] scsi4 : ahci
[ 1.284368] scsi5 : ahci
[ 1.284722] ata1: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02100 irq 19
[ 1.284725] ata2: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02180 irq 19
[ 1.284727] ata3: DUMMY
[ 1.284728] ata4: DUMMY
[ 1.284730] ata5: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02300 irq 19
[ 1.284732] ata6: SATA max UDMA/133 abar m2048@0xf7c02000 port 0xf7c02380 irq 19
[ 1.284797] ahci: SSS flag set, parallel bus scan disabled
[ 1.284846] ahci 0000:09:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.284848] ahci 0000:09:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 1.285162] scsi6 : ahci
[ 1.285291] scsi7 : ahci
[ 1.285332] ata7: SATA max UDMA/133 abar m512@0xf7800000 port 0xf7800100 irq 17
[ 1.285336] ata8: SATA max UDMA/133 abar m512@0xf7800000 port 0xf7800180 irq 17
[ 1.539590] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.603598] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.603626] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.603641] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.603662] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.604500] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.604505] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5a368), AE_NOT_FOUND (20120320/psparse-536)
[ 1.604618] ata5.00: ATA-9: PNY CS1211 480GB SSD 754D117-533, CS121101, max UDMA/133
[ 1.604620] ata5.00: 937703088 sectors, multi 2: LBA48 NCQ (depth 31/32), AA
[ 1.604780] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.604788] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT4._GTF] (Node f3c5a368), AE_NOT_FOUND (20120320/psparse-536)
[ 1.604886] ata5.00: configured for UDMA/133
[ 1.604959] scsi 4:0:0:0: Direct-Access ATA PNY CS1211 480GB CS12 PQ: 0 ANSI: 5
[ 1.606071] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.606085] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f3c5a320), AE_NOT_FOUND (20120320/psparse-536)
[ 1.606094] ata6.00: ATAPI: ATAPI DVD A DH24ABS, AAA1, max UDMA/100
[ 1.606907] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20120320/psargs-359)
[ 1.606914] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT5._GTF] (Node f3c5a320), AE_NOT_FOUND (20120320/psparse-536)
[ 1.606932] ata6.00: configured for UDMA/100
[ 1.609151] scsi 5:0:0:0: CD-ROM ATAPI DVD A DH24ABS AAA1 PQ: 0 ANSI: 5
[ 1.671961] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.671965] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.672102] hub 1-1:1.0: USB hub found
[ 1.672204] hub 1-1:1.0: 4 ports detected
[ 1.775532] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.776742] ata7.00: ATA-8: ST31000524AS, JC45, max UDMA/133
[ 1.776746] ata7.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1.778144] ata7.00: configured for UDMA/133
[ 1.778237] scsi 6:0:0:0: Direct-Access ATA ST31000524AS JC45 PQ: 0 ANSI: 5
[ 1.815500] Refined TSC clocksource calibration: 2993.200 MHz.
[ 1.815507] Switching to clocksource tsc
[ 1.839492] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 1.858340] usb 3-1: New USB device found, idVendor=046d, idProduct=c534
[ 1.858343] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.858346] usb 3-1: Product: USB Receiver
[ 1.858349] usb 3-1: Manufacturer: Logitech
[ 1.862804] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1c.3/0000:06:00.0/usb3/3-1/3-1:1.0/input/input0
[ 1.862855] generic-usb 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:06:00.0-1/input0
[ 1.864902] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1c.3/0000:06:00.0/usb3/3-1/3-1:1.1/input/input1
[ 1.864991] generic-usb 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:06:00.0-1/input1
[ 1.865003] usbcore: registered new interface driver usbhid
[ 1.865005] usbhid: USB HID core driver
[ 1.971455] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 2.095431] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.097134] sd 4:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 2.097138] sd 6:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.097174] sd 6:0:0:0: [sdb] Write Protect is off
[ 2.097176] sd 6:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.097182] sd 4:0:0:0: [sda] Write Protect is off
[ 2.097184] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.097192] sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.097198] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.098317] sda: sda1 sda2 < sda5 >
[ 2.098582] sd 4:0:0:0: [sda] Attached SCSI disk
[ 2.099635] sd 4:0:0:0: Attached scsi generic sg0 type 0
[ 2.099689] scsi 5:0:0:0: Attached scsi generic sg1 type 5
[ 2.099718] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 2.103818] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.103823] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.103961] hub 2-1:1.0: USB hub found
[ 2.104061] hub 2-1:1.0: 6 ports detected
[ 2.111019] sdb: sdb1
[ 2.111210] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 2.116931] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.116955] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.117048] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 2.175552] usb 1-1.3: new high-speed USB device number 3 using ehci_hcd
[ 2.278389] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0158
[ 2.278394] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.278398] usb 1-1.3: Product: USB2.0-CRW
[ 2.278401] usb 1-1.3: Manufacturer: Generic
[ 2.278403] usb 1-1.3: SerialNumber: 20071114173400000
[ 2.284385] Initializing USB Mass Storage driver...
[ 2.284426] usbcore: registered new interface driver usb-storage
[ 2.284428] USB Mass Storage support registered.
[ 2.298547] scsi8 : usb-storage 1-1.3:1.0
[ 2.298596] usbcore: registered new interface driver ums-realtek
[ 2.498567] usb 1-1.3: USB disconnect, device number 3
[ 7.302453] PM: Starting manual resume from disk
[ 7.302456] PM: Hibernation image partition 8:5 present
[ 7.302457] PM: Looking for hibernation image.
[ 7.302666] PM: Image not found (code -22)
[ 7.302668] PM: Hibernation image not present or could not be loaded.
[ 7.332916] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.495178] udevd[432]: starting version 175
[ 7.542323] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 7.542327] ACPI: Power Button [PWRB]
[ 7.542370] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 7.542373] ACPI: Power Button [PWRF]
[ 7.545950] wmi: Mapper loaded
[ 7.554461] [drm] Initialized drm 1.1.0 20060810
[ 7.561307] i915 0000:00:02.0: setting latency timer to 64
[ 7.566197] iTCO_vendor_support: vendor-support=0
[ 7.567717] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 7.567780] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 7.568031] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 7.572447] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 7.572450] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 7.572575] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 7.572577] [drm] Driver supports precise vblank timestamp query.
[ 7.572606] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.574631] cfg80211: Calling CRDA to update world regulatory domain
[ 7.589140] asus_wmi: ASUS WMI generic driver loaded
[ 7.589978] asus_wmi: Initialization: 0x0
[ 7.590004] asus_wmi: BIOS WMI version: 0.9
[ 7.590056] asus_wmi: SFUN value: 0x0
[ 7.590326] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input4
[ 7.591788] asus_wmi: Backlight controlled by ACPI video driver
[ 7.596756] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 7.596909] Registered led device: rt2800pci-phy0::radio
[ 7.596923] Registered led device: rt2800pci-phy0::assoc
[ 7.596936] Registered led device: rt2800pci-phy0::quality
[ 7.615791] [drm] Enabling RC6 states: RC6 on, RC6p off, RC6pp off
[ 7.625612] cfg80211: World regulatory domain updated:
[ 7.625615] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.625617] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.625619] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 7.625620] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 7.625622] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625623] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625625] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 7.625627] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 7.625628] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 7.796536] fbcon: inteldrmfb (fb0) is primary device
[ 7.966327] Console: switching to colour frame buffer device 128x48
[ 7.967900] fb0: inteldrmfb frame buffer device
[ 7.967902] drm: registered panic notifier
[ 7.968310] acpi device:50: registered as cooling_device5
[ 7.968486] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 7.968521] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 7.968536] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 7.968564] ACPI Warning: 0x0000f040-0x0000f05f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 7.968569] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 7.968599] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.148548] Adding 16166908k swap on /dev/sda5. Priority:-1 extents:1 across:16166908k SS
[ 8.157085] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 8.195215] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.207976] loop: module loaded
[ 8.560821] RPC: Registered named UNIX socket transport module.
[ 8.560824] RPC: Registered udp transport module.
[ 8.560825] RPC: Registered tcp transport module.
[ 8.560826] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 8.564656] FS-Cache: Loaded
[ 8.569536] NFS: Registering the id_resolver key type
[ 8.569547] FS-Cache: Netfs 'nfs' registered for caching
[ 8.572604] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 8.926343] Bluetooth: Core ver 2.16
[ 8.926355] NET: Registered protocol family 31
[ 8.926356] Bluetooth: HCI device and connection manager initialized
[ 8.926358] Bluetooth: HCI socket layer initialized
[ 8.926360] Bluetooth: L2CAP socket layer initialized
[ 8.926364] Bluetooth: SCO socket layer initialized
[ 8.929750] Bluetooth: RFCOMM TTY layer initialized
[ 8.929754] Bluetooth: RFCOMM socket layer initialized
[ 8.929755] Bluetooth: RFCOMM ver 1.11
[ 8.941082] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.941085] Bluetooth: BNEP filters: protocol multicast
[ 8.947910] lp: driver loaded but no devices found
[ 8.950958] ppdev: user-space parallel port driver
[ 9.815906] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 10.685410] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.781629] r8169 0000:05:00.0: eth0: link down
[ 10.781712] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.456213] wlan0: authenticate with 60:38:e0:d5:e9:43
[ 13.504017] wlan0: send auth to 60:38:e0:d5:e9:43 (try 1/3)
[ 13.505632] wlan0: authenticated
[ 13.531762] wlan0: associate with 60:38:e0:d5:e9:43 (try 1/3)
[ 13.551058] wlan0: RX AssocResp from 60:38:e0:d5:e9:43 (capab=0x411 status=0 aid=5)
[ 13.576360] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.576391] wlan0: associated
[ 23.672535] wlan0: no IPv6 routers present
[ 250.369085] wlan0: deauthenticating from 60:38:e0:d5:e9:43 by local choice (reason=3)
[ 250.662025] cfg80211: Calling CRDA to update world regulatory domain
[ 250.666960] cfg80211: World regulatory domain updated:
[ 250.666963] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 250.666965] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 250.666967] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 250.666968] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 250.666970] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666972] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666973] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 250.666975] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 250.666977] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 261.369384] wlan0: authenticate with 60:38:e0:d5:e9:43
[ 261.417580] wlan0: send auth to 60:38:e0:d5:e9:43 (try 1/3)
[ 261.418756] wlan0: authenticated
[ 261.444923] wlan0: associate with 60:38:e0:d5:e9:43 (try 1/3)
[ 261.464012] wlan0: RX AssocResp from 60:38:e0:d5:e9:43 (capab=0x411 status=0 aid=5)
[ 261.489333] wlan0: associated
[ 273.401117] wlan0: no IPv6 routers present
[ 433.809327] I-pipe: head domain RTAI registered.
[ 433.809331] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 433.809378] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 433.809380] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 433.809382] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 433.809384] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 3886750
[ 433.821570] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 433.821589] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 433.821592] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 433.821594] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 433.821596] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 433.829795] RTAI[math]: loaded.
[ 433.892264] hm2: loading Mesa HostMot2 driver version 0.15
[ 433.894936] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 433.894962] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 433.895288] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 433.950723] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 433.950725] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 433.950727] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 433.950729] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 433.950731] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 433.950733] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 433.950735] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 433.950737] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 433.950738] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 433.950740] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 433.950742] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 433.950744] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 433.950745] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 433.950747] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 433.950748] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 433.950750] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 433.950752] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 433.950754] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 433.950755] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 433.950757] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 433.950758] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 433.950760] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 433.950761] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 433.950763] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 433.950764] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 433.950766] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 433.950767] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 433.950768] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 433.950770] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 433.950771] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 433.950773] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 433.950774] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 433.950776] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 433.950777] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 433.950779] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 433.950815] hm2/hm2_5i25.0: registered
[ 433.950817] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 470.645723] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 470.645727] hm2/hm2_5i25.0: unregistered
[ 470.645755] hm2_pci: driver unloaded
[ 470.646734] hm2: unloading
[ 472.718498] RTAI[math]: unloaded.
[ 472.719491] SCHED releases registered named ALIEN PEDV$D
[ 472.722376] RTAI[malloc]: unloaded.
[ 472.821703] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 472.822820] I-pipe: head domain RTAI unregistered.
[ 472.822870] RTAI[hal]: unmounted.
[ 482.673936] I-pipe: head domain RTAI registered.
[ 482.673940] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 482.673986] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 482.673988] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 482.673990] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 482.673992] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6191000
[ 482.677625] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 482.677645] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 482.677648] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 482.677650] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 482.677652] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 482.681710] RTAI[math]: loaded.
[ 482.722299] hm2: loading Mesa HostMot2 driver version 0.15
[ 482.723419] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 482.723445] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 482.723736] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 482.778992] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 482.778995] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 482.778997] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 482.778999] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 482.779001] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 482.779003] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 482.779005] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 482.779007] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 482.779008] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 482.779010] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 482.779011] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 482.779013] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 482.779014] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 482.779015] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 482.779017] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 482.779018] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 482.779020] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 482.779021] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 482.779023] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 482.779024] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 482.779026] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 482.779027] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 482.779029] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 482.779030] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 482.779031] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 482.779033] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 482.779034] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 482.779036] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 482.779037] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 482.779039] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 482.779040] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 482.779042] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 482.779043] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 482.779045] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 482.779046] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 482.779080] hm2/hm2_5i25.0: registered
[ 482.779082] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 483.627469] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 483.627473] hm2/hm2_5i25.0: unregistered
[ 483.627502] hm2_pci: driver unloaded
[ 483.628469] hm2: unloading
[ 485.697244] RTAI[math]: unloaded.
[ 485.698241] SCHED releases registered named ALIEN PEDV$D
[ 485.700670] RTAI[malloc]: unloaded.
[ 485.797576] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 485.798621] I-pipe: head domain RTAI unregistered.
[ 485.798672] RTAI[hal]: unmounted.
[ 520.175016] I-pipe: head domain RTAI registered.
[ 520.175020] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 520.175065] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 520.175068] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 520.175070] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 520.175072] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6227500
[ 520.178697] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 520.178718] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 520.178721] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 520.178723] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 520.178725] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 520.183820] RTAI[math]: loaded.
[ 520.223844] hm2: loading Mesa HostMot2 driver version 0.15
[ 520.224921] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 520.224948] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 520.225239] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 520.280559] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 520.280561] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 520.280563] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 520.280565] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 520.280567] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 520.280569] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 520.280571] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 520.280572] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 520.280574] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 520.280575] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 520.280577] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 520.280578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 520.280580] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 520.280581] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 520.280583] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 520.280584] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 520.280586] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 520.280587] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 520.280589] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 520.280590] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 520.280591] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 520.280593] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 520.280594] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 520.280596] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 520.280597] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 520.280599] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 520.280600] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 520.280602] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 520.280603] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 520.280605] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 520.280606] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 520.280608] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 520.280609] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 520.280611] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 520.280612] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 520.280646] hm2/hm2_5i25.0: registered
[ 520.280648] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 521.076213] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 521.076217] hm2/hm2_5i25.0: unregistered
[ 521.076246] hm2_pci: driver unloaded
[ 521.077205] hm2: unloading
[ 523.145988] RTAI[math]: unloaded.
[ 523.146983] SCHED releases registered named ALIEN PEDV$D
[ 523.149534] RTAI[malloc]: unloaded.
[ 523.245669] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 523.246769] I-pipe: head domain RTAI unregistered.
[ 523.246820] RTAI[hal]: unmounted.
[ 638.488133] I-pipe: head domain RTAI registered.
[ 638.488136] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 638.488181] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 638.488184] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 638.488186] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 638.488188] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6181750
[ 638.491809] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 638.491829] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 638.491832] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 638.491834] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 638.491836] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 638.497574] RTAI[math]: loaded.
[ 638.537589] hm2: loading Mesa HostMot2 driver version 0.15
[ 638.538653] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 638.538679] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 638.538971] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 638.594324] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 638.594327] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 638.594329] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 638.594331] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 638.594333] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 638.594335] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 638.594336] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 638.594338] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 638.594340] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 638.594341] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 638.594343] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 638.594344] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 638.594345] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 638.594347] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 638.594348] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 638.594350] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 638.594351] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 638.594353] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 638.594354] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 638.594356] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 638.594357] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 638.594359] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 638.594360] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 638.594362] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 638.594363] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 638.594364] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 638.594366] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 638.594367] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 638.594369] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 638.594370] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 638.594372] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 638.594373] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 638.594375] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 638.594376] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 638.594378] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 638.594412] hm2/hm2_5i25.0: registered
[ 638.594414] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 639.376626] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 639.376629] hm2/hm2_5i25.0: unregistered
[ 639.376658] hm2_pci: driver unloaded
[ 639.377633] hm2: unloading
[ 641.446781] RTAI[math]: unloaded.
[ 641.447771] SCHED releases registered named ALIEN PEDV$D
[ 641.450021] RTAI[malloc]: unloaded.
[ 641.548046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 641.549096] I-pipe: head domain RTAI unregistered.
[ 641.549147] RTAI[hal]: unmounted.
[ 703.526890] I-pipe: head domain RTAI registered.
[ 703.526894] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 703.526939] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 703.526942] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 703.526944] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 703.526946] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5034000
[ 703.530594] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 703.530614] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 703.530617] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 703.530619] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 703.530621] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 703.535526] RTAI[math]: loaded.
[ 708.116832] RTAI[math]: unloaded.
[ 708.117839] SCHED releases registered named ALIEN PEDV$D
[ 708.120712] RTAI[malloc]: unloaded.
[ 708.218839] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 708.219886] I-pipe: head domain RTAI unregistered.
[ 708.219938] RTAI[hal]: unmounted.
[ 1196.729820] I-pipe: head domain RTAI registered.
[ 1196.729824] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1196.729869] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1196.729871] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 1196.729874] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1196.729876] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5478250
[ 1196.733530] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1196.733551] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1196.733554] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 1196.733557] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 1196.733558] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1196.738517] RTAI[math]: loaded.
[ 1196.778659] hm2: loading Mesa HostMot2 driver version 0.15
[ 1196.779814] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1196.779843] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 1196.780169] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1196.835492] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1196.835494] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 1196.835497] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 1196.835499] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 1196.835501] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 1196.835502] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 1196.835504] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 1196.835506] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 1196.835508] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 1196.835510] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 1196.835512] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 1196.835513] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1196.835515] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1196.835516] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1196.835518] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1196.835520] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 1196.835521] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 1196.835523] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 1196.835525] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1196.835526] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1196.835528] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1196.835529] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1196.835531] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1196.835532] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1196.835533] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1196.835535] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 1196.835536] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 1196.835538] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 1196.835539] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1196.835541] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1196.835542] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1196.835544] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1196.835545] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1196.835547] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1196.835548] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1196.835584] hm2/hm2_5i25.0: registered
[ 1196.835586] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 1206.312947] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 1206.312950] hm2/hm2_5i25.0: unregistered
[ 1206.312980] hm2_pci: driver unloaded
[ 1206.313958] hm2: unloading
[ 1208.383307] RTAI[math]: unloaded.
[ 1208.384307] SCHED releases registered named ALIEN PEDV$D
[ 1208.387092] RTAI[malloc]: unloaded.
[ 1208.483746] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1208.484799] I-pipe: head domain RTAI unregistered.
[ 1208.484851] RTAI[hal]: unmounted.
[ 1405.156989] I-pipe: head domain RTAI registered.
[ 1405.156993] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1405.157038] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1405.157041] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 1405.157043] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1405.157045] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 6191500
[ 1405.160694] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1405.160714] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1405.160717] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 1405.160719] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 1405.160721] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1405.165853] RTAI[math]: loaded.
[ 1405.205917] hm2: loading Mesa HostMot2 driver version 0.15
[ 1405.206984] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1405.207012] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 1405.207304] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1405.262501] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1405.262503] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 1405.262505] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 1405.262507] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 1405.262509] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 1405.262511] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 1405.262513] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 1405.262515] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1405.262516] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1405.262518] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1405.262519] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1405.262521] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1405.262522] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1405.262523] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1405.262525] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1405.262526] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1405.262528] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1405.262529] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1405.262531] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1405.262532] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1405.262534] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1405.262535] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1405.262537] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1405.262538] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1405.262539] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1405.262541] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 1405.262542] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 1405.262544] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 1405.262545] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1405.262547] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1405.262548] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1405.262550] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1405.262551] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1405.262553] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1405.262554] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1405.262588] hm2/hm2_5i25.0: registered
[ 1405.262590] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 1406.114390] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 1406.114394] hm2/hm2_5i25.0: unregistered
[ 1406.114422] hm2_pci: driver unloaded
[ 1406.115374] hm2: unloading
[ 1408.186629] RTAI[math]: unloaded.
[ 1408.187626] SCHED releases registered named ALIEN PEDV$D
[ 1408.190217] RTAI[malloc]: unloaded.
[ 1408.288199] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1408.289262] I-pipe: head domain RTAI unregistered.
[ 1408.289313] RTAI[hal]: unmounted.
[ 2129.361658] I-pipe: head domain RTAI registered.
[ 2129.361662] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2129.361707] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2129.361710] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 2129.361712] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2129.361714] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 4789750
[ 2129.365333] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2129.365353] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2129.365356] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 2129.365358] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 2129.365360] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 2129.370213] RTAI[math]: loaded.
[ 2129.410546] hm2: loading Mesa HostMot2 driver version 0.15
[ 2129.411636] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2129.411662] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 2129.411986] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2129.467255] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2129.467258] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 2129.467260] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 2129.467262] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 2129.467264] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 2129.467266] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 2129.467268] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 2129.467270] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 2129.467271] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 2129.467273] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 2129.467275] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 2129.467277] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2129.467278] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2129.467280] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2129.467281] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2129.467283] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 2129.467285] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 2129.467286] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 2129.467288] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2129.467289] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2129.467291] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2129.467292] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2129.467294] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2129.467295] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2129.467297] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2129.467298] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 2129.467300] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 2129.467301] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 2129.467303] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 2129.467304] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 2129.467305] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 2129.467307] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 2129.467308] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 2129.467310] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 2129.467311] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 2129.467348] hm2/hm2_5i25.0: registered
[ 2129.467349] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 2185.639894] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 2185.639897] hm2/hm2_5i25.0: unregistered
[ 2185.639926] hm2_pci: driver unloaded
[ 2185.640877] hm2: unloading
[ 2187.712476] RTAI[math]: unloaded.
[ 2187.713478] SCHED releases registered named ALIEN PEDV$D
[ 2187.716218] RTAI[malloc]: unloaded.
[ 2187.812291] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2187.813351] I-pipe: head domain RTAI unregistered.
[ 2187.813401] RTAI[hal]: unmounted.
[ 3316.328673] I-pipe: head domain RTAI registered.
[ 3316.328677] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3316.328722] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3316.328725] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 2993078000, CPU_FREQ 2993078000
[ 3316.328727] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3316.328729] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 5759500
[ 3316.332346] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3316.332364] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3316.332367] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 3316.332370] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2993078000 hz.
[ 3316.332371] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3316.337483] RTAI[math]: loaded.
[ 3316.377540] hm2: loading Mesa HostMot2 driver version 0.15
[ 3316.378607] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3316.378634] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 3316.378925] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3316.434173] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3316.434175] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 3316.434177] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 3316.434179] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 3316.434181] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 3316.434183] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 3316.434185] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 3316.434187] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3316.434188] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3316.434190] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3316.434191] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3316.434193] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3316.434194] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3316.434195] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3316.434197] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3316.434198] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3316.434200] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3316.434201] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3316.434203] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3316.434204] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3316.434206] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3316.434207] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3316.434209] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3316.434210] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3316.434212] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3316.434213] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3316.434215] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3316.434216] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3316.434217] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3316.434219] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3316.434220] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3316.434222] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3316.434223] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3316.434225] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3316.434226] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3316.434261] hm2/hm2_5i25.0: registered
[ 3316.434262] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 3317.291261] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 3317.291265] hm2/hm2_5i25.0: unregistered
[ 3317.291294] hm2_pci: driver unloaded
[ 3317.292257] hm2: unloading
[ 3319.364957] RTAI[math]: unloaded.
[ 3319.365951] SCHED releases registered named ALIEN PEDV$D
[ 3319.368424] RTAI[malloc]: unloaded.
[ 3319.468393] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3319.469446] I-pipe: head domain RTAI unregistered.
[ 3319.469498] RTAI[hal]: unmounted.
- Frank80
25 Sep 2020 00:06 #183653
by Frank80
Replied by Frank80 on topic Linux start up questions(configuration)
Sorry, I didn't realize how long that error was. Next time I'll upload it as a file.
- BeagleBrainz
- Visitor
25 Sep 2020 00:10 - 25 Sep 2020 00:13 #183654
by BeagleBrainz
Replied by BeagleBrainz on topic Linux start up questions(configuration)
Somewhere in your setup you are trying to make a connection to the vfd via a serial connection, Linuxcnc can't open the port and that is why it is shutting down.
Which would point to the permissions on the device file not allowing you access to it.
spindle-vfd: device='/dev/ttyS0', baud=9600, parity='N', bits=8, stopbits=2, address=1, enabled=1
spindle-vfd: ERROR: couldn't open serial device: Input/output error
Running HAL shutdown script
task: 76 cycles, min=0.000005, max=0.022284, avg=0.008223, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
mitsub_vfd.hal:12: waitpid failed gs2_vfd spindle-vfd
mitsub_vfd.hal:12: gs2_vfd exited without becoming ready
8289
8338
Stopping realtime threads
Unloading hal component
Last edit: 25 Sep 2020 00:13 by BeagleBrainz.
- Frank80
25 Sep 2020 00:33 #183656
by Frank80
I searched the the config files and found this in a file called mitsub_vfd.hal
I am going to try removing it from the directory and then launch the application to see what happens.
# Generated by PNCconf at Tue Jul 7 09:31:16 2020
# Automation Direct GS2 VFD for spindle control
# The communications switches must be set to RS-232C
# The motor parameters must be set to match the motor
# P3.00 (Source of Operation Command) must be set to Operation determined by RS-485 interface, 03 or 04
# P4.00 (Source of Frequency Command) must be set to Frequency determined by RS232C/RS485 communication interface, 05
# P9.01 (Transmission Speed) must be set to the specified baud, 9600 = 01
# P9.02 (Communication Protocol) must be set to "Modbus RTU mode, 8 data bits, no parity, 2 stop bits", 03
loadusr -Wn spindle-vfd gs2_vfd -d /dev/ttyS0 -r 9600 -p none -s 2 -t 1 -n spindle-vfd -A 10 -D 0
net spindle-cw => spindle-vfd.spindle-fwd
net spindle-on => spindle-vfd.spindle-on
net spindle-at-speed <= spindle-vfd.at-speed
net spindle-vel-cmd-rpm => spindle-vfd.speed-command
- Frank80
25 Sep 2020 00:39 #183657
by Frank80
I removed the mitsub_vfd.hal file from the config directory and tried re-opening LinuxCNC. It still crashes but no longer with the same error. I have attached the crash output as a file this time.
- BeagleBrainz
- Visitor
25 Sep 2020 00:49 #183658
by BeagleBrainz
Ok that file is still referenced in your ini file.
Removing the file does not remove it from the config, any reference has to be removed inside your ini file or wherever it is referenced.
Could not open hal file 'mitsub_vfd.hal': No such file or directory
9787
9835
Unloading hal componentsPlease Log in or Create an account to join the conversation.
- Frank80
26 Sep 2020 22:57 #183898
by Frank80
I found the string mitsub_vfd.hal referenced in this file postgui_call_list.hal and I commented it out. Now when I run the LinuxCNC program it opens successfully. That's a great accomplishment in itself. Thanks!
Here's the contents of the postgui_call_list.hal file FWIW:
# These files are loaded post GUI, in the order they appear
# source mitsub_vfd.hal
source custom_postgui.hal
Time to create page: 0.154 seconds
