( Solved ) Issues with python plugin for remap
6 years 2 months ago - 6 years 2 months ago #177064 by bevins
new box 2.8 same thing. I am out of options with linuxcnc......
I dont know what else to do.
Maybe try a different distribution than linux Mint.
Last edit: 6 years 2 months ago by bevins.
6 years 2 months ago #177087 by cmorley
distribution change is the least likely cause.
can you confirm the sample sim/axis/remap/extend-builtin works?
I then added print statements to nc_files/remap_lib/stdglue.py 's
change_prolog and change_epilog.
They both printed when I ran the default program for that sample from 2.8
This would prove the underlying code is working.
The following user(s) said Thank You: bevins, tommylight
6 years 2 months ago #177103 by bevins
cmorley wrote: distribution change is the least likely cause.
I will check this tonight, but did you run this on machine or simulator?
6 years 2 months ago #177112 by cmorley
6 years 2 months ago #177121 by bevins
Rack_tool change and extend-builtin works in the sim.
6 years 2 months ago #177123 by bevins
not sure how to make the sim config work on a real machine. IT has the halib,
Time to create page: 0.197 seconds
