You're not the only one, awhile back i was wondering why the plasma is not cutting the material, just making a hole and gouging the rest of the cut, wasted an hour and left the blame to a small compressor that barely reaches the pressure required, came in the next day and stepped on the ground clamp, it was not attached to the material ! :side:bevins wrote: Nothing worse than chasing two issues and one you created yourself to make matters worse.....
tommylight wrote: Not sure, but did you try making the O stuff executable ?
I recall reading here that it is needed for something or another when calling code, but can not recall exactly what or how.
