( Solved ) Issues with python plugin for remap
6 years 3 months ago - 6 years 3 months ago #176655 by bevins
rodw wrote: From what I can see, its trying to add a folder to the path which does not exist
/home/etienne/linuxcnc/python
I think the python folder is under your rack tool changer config. Try copying that folder to the top level ~/linuxcnc folder.
I'm using a RIP config here and I found I had to add these dependencies as well before the sim would even open!
sudo apt-get install -y python-gtkglext1 sudo apt-get install -y python-gtksourceview2
That path exists. I tried it all different ways. It finds it because if I change the file so it has errors it shows different errors. So it can find the files. I'll try that
Last edit: 6 years 3 months ago by bevins.
6 years 3 months ago #176693 by bevins
]They are already installed.
No one knows what these issues are?
6 years 3 months ago - 6 years 3 months ago #176696 by bevins
OK, I got init loaded and working.
But I still have the issue of the oword functions not working.
It is exactly like the rack_change in the sim.The sim doesn't need to load init but what is missing to
make the oword functions work? Why are they not callable? If I put scrap characters in the functions linuxcnc complains and wont load so it knows where they are.
is_callable(__init__) = TRUE 0 words passed is_callable(oword.rack_change) = FALSE is_callable(oword.tool_getput_move) = FALSE is_callable(oword.tool_holder_clear_move) = FALSE
6 years 3 months ago #176700 by bevins
AAAAAAARGGGG..... frustrating
6 years 3 months ago #176701 by rodw
Bevins, I have no idea about toolchangers except that I've seen many echo your last sentiments. :sick:
I still don't know where the oword procedures live. Can you enlighten me?
I know sometimes the sims have symbolic links that don't get copied over but I could not see any in the rack changer
6 years 3 months ago #176707 by bevins
rodw wrote: Bevins, I have no idea about toolchangers except that I've seen many echo your last sentiments. :sick:
They live in the nc_subroutines directory where ever you put it in the ini file.
Time to create page: 0.065 seconds
