Which Mesa board?
- bevins
- Thank you received: 338
04 Aug 2020 01:22 #177150
by bevins
Wow, I didnt know that. I thought it swapped the inputs also. Thanks.
Replied by bevins on topic Which Mesa board?
Unfortunately the 7I76ED only changes the digital outputs
to sinking vs the 7I76Es sourcing output drivers.
- Clive S
- Thank you received: 486
04 Aug 2020 07:25 #177189
by Clive S
Yes , that is what I would do. With the 7i76 or 7i76e you can also fit two mpg's on it as well
Replied by Clive S on topic Which Mesa board?
Oh now I'm confused
My servo drives are fairly new Chinese drives, step and direction for DC servo motors. My sensors are all NPN. Im currently running Mach4 with Ethernet smooth stepper and BOB. I want to gut all this for Linuxcnc and and use the 7i76e in place of both the ESS and the current 5v BOB.
So with all this in mind is it the 7i76e or ed? I dont mind changing stuff around.
So its looking more like the regular 7i76e and then using pull-up resistors to accommodate all my NPN limit / homing switch inputs. Yes?
The following user(s) said Thank You: palmac
- Thank you received: 4145
04 Aug 2020 08:52 - 04 Aug 2020 08:57 #177198
Replied by rodw on topic Which Mesa board?
I would go with the 7i76e if you don't gain anything to help with the inputs. When I built my machine, I bought all these NPN sensors and then found out I should have used PNP's's I just added the pullups and it all works pefectly.
Last edit: 04 Aug 2020 08:57 by rodw.
- Clive S
04 Aug 2020 08:54 #177199
by Clive S
Did you mean PNP
I would go with the 7i76e if you don't gain anything to help with the inputs. When I built my machine, I bought all these NPN sensors and then found out I should have used NPN's I just added the pullups and it all works pefectly.
Did you mean PNP
04 Aug 2020 08:58 #177200
Yes, I caught a case of dislexia from Bevins
Corrected
Did you mean PNP
- palmac
04 Aug 2020 23:58 #177313
by palmac
Replied by palmac on topic Which Mesa board?
Done! 7i76e it is.
thank you all.
Im excited
thank you all.
Im excited
- Boogie
- Thank you received: 9
09 Feb 2022 01:49 - 09 Feb 2022 01:50 #234369
by Boogie
Replied by Boogie on topic Which Mesa board?
Guys,
do you know if 7i76E / ED can be flashed so instead of 4 STEP/DIRr outputs i can have 4 PWM/DIR outputs? I'd like to try to drive h-bridges and use 7i85 for encoders feedback. Any *.bin exist to do it? Maybe can it be made in HAL file?
Thank you
Thank you
Last edit: 09 Feb 2022 01:50 by Boogie.
- Thank you received: 5321
09 Feb 2022 15:06 #234395
Replied by PCW on topic Which Mesa board?
It certainly possible but does require different firmware
Time to create page: 0.098 seconds
