Cannot get M6 ngc remap working
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Aug 2020 00:22 #177561 by bevins
Replied by bevins on topic Cannot get M6 ngc remap working
I really am lost as for why this is not working. I literally did the same thing you did.
I have a 7i92/7i76 connected.
I dont know what else to do. If I do another config, I would do the same thing and it would behave the same. I have done it 4 times now. three different computers.
I don't get it.
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 08:28 #177585 by bevins
Here is my console output.
homed, touch off and ran but didnt move.
Warning: Spoiler!
  • Moderator
  • Moderator
07 Aug 2020 09:01 #177587 by tommylight
Replied by tommylight on topic Cannot get M6 ngc remap working
What is the actual machine name ?
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 11:34 #177597 by bevins
The machine name now is changer.
  • Moderator
  • Moderator
07 Aug 2020 11:58 #177600 by tommylight
OK.
I am at a loss as to why it is not working for you, i did test last night on the big PC without a machine attached and it also worked as i can see the LED's on the parallel port monitor doing their thing.
Can you attach that gcode so i can give it a run?
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 12:12 #177602 by bevins
OK.
It is sample gcode file in the racktoolchange sim.
I also did one with just a circle.
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 12:15 #177603 by bevins
I am installing Linux Mint 19.3 Really don't think it is that but I have been testing on linux mint 18.
Maybe something in python in that version is causing it. I don't know, wild guess.
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 14:52 - 07 Aug 2020 16:18 #177624 by bevins
linuxmint 19.3 master,
Something in my config......I dont get it.
OK So its working in Linux Mint 19.3 running master.
I will copy this config to linux Mint 18.3 and see if it works.
Last edit: 07 Aug 2020 16:18 by bevins.
  • bevins
  • Platinum Member
  • Platinum Member
07 Aug 2020 18:07 - 07 Aug 2020 18:09 #177635 by bevins
Cant get it to work with Linux Mint 18.3 with master.
It doesn't work,.
I do have it working with Linux Mint 19.3 with the same config.
May be that certain version of master.. I don't know, but I lost alot of time on this........
Last edit: 07 Aug 2020 18:09 by bevins.
  • Moderator
  • Moderator
07 Aug 2020 19:31 #177642 by tommylight
Most probably a Python issue as it has been changed a lot lately and somehow they just dumped backward compatibility.
