MATRIX_KB in 2.8.0
08 Aug 2020 19:18 - 08 Aug 2020 19:19 #177701 by Daniel_D_Punkt
MATRIX_KB in 2.8.0 was created by Daniel_D_Punkt
Hi guys,
I control my WABECO F1410 LF HS with LinuxCNC and MESA 7i76e + 7i85 + 7i73 and am actually very satisfied.
I have loaded a 4x8 matrix_kb for the 7i73. Works in principle, but I think I found a bug in version 2.8.0 pre1 6085:
The output signal of the key.r1c1 button is 'ON' after starting LinuxCNC even though the button is not pressed. If I press it once and release it again, the output of key.r1c1 goes 'LOW' as expected and behaves like all other outputs. Can this be an error during initialization?
I have tested this configuration with version 2.7.14. Here this error does not occur and everything behaves as expected.
I know that LinuxCNC 2.8 is not released yet. Can someone confirm this bug before I downgrade to 2.7.15?
# >>>> Keypad >>>
loadrt matrix_kb config=4x8
addf matrix_kb.0 servo thread -2
net keypad hm2_7i76e.0.7i73.0.2.keycode => matrix_kb.0.keycode
# <<< Keypad #<
Best regards
Last edit: 08 Aug 2020 19:19 by Daniel_D_Punkt.
08 Aug 2020 20:32 #177711 by PCW
Replied by PCW on topic MATRIX_KB in 2.8.0
I cannot duplicate this in master
Your might want to upgrade to the latest 2.8 version
09 Aug 2020 09:53 #177740 by Daniel_D_Punkt
Replied by Daniel_D_Punkt on topic MATRIX_KB in 2.8.0
Thanks for trying and the quick answer.
I have now updated to 2.8.0-pre1-6125 and got the same error.
I had actually excluded the 7i73 as the cause, since it behaves correctly with the same hardware and version 2.7.14.
I have also tried 10k pull-up resistors on the scan inputs of the 7i73, without success.
I start LinuxCNC and add all key-outputs of the 7i73 to the observation window. All are FALSE except r1c1. If I now press r1c1, it stays HIGH and changes to LOW when I release it. After that it behaves normally. When I restart LinuxCNC it is the same game.
Does anyone have any idea what else I could try? Especially after PCW could not reproduce this error I am helpless.
09 Aug 2020 11:35 #177744 by Daniel_D_Punkt
I just created a new configuration with pncconf and this is also the problem.
I have attached the configurations of the MESA boards.
09 Aug 2020 13:21 #177746 by PCW
Your thread order is not right, the hardware read should be the first addf
and the hardware write should be the last, something like this:
# THREADS
addf hm2_[HOSTMOT2](BOARD).0.read         servo-thread
addf mux2.0                               servo-thread
addf mux2.1                               servo-thread
addf mux2.2                               servo-thread
addf mux2.3                               servo-thread
addf motion-command-handler               servo-thread
addf motion-controller                    servo-thread
addf pid.0.do-pid-calcs                   servo-thread
addf pid.1.do-pid-calcs                   servo-thread
addf pid.2.do-pid-calcs                   servo-thread
addf pid.3.do-pid-calcs                   servo-thread
addf matrix_kb.0 servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write        servo-thread
The following user(s) said Thank You: Daniel_D_Punkt
09 Aug 2020 14:15 #177749 by Daniel_D_Punkt
Ohhh, very good point, thank you very much. I changed that... but unfortunately it doesn't fix anything on this button problem
09 Aug 2020 14:17 #177750 by PCW
Do you have the matrix_kb addf between read and write?
09 Aug 2020 14:23 - 09 Aug 2020 14:42 #177751 by Daniel_D_Punkt
Jep, rearranged the HAL a little bit for better readability .
Last edit: 09 Aug 2020 14:42 by Daniel_D_Punkt.
09 Aug 2020 14:47 #177752 by PCW
Hmm I just tried 2.8 and don't see a problem either
Do all the keys work?
(4x8 mode scanner columns are P1 pins 7,8,9,10)
09 Aug 2020 15:07 #177755 by Daniel_D_Punkt
Yes, all keys are wirking fine. Key r1c1 works too, but it starts in pressed state.
If I use 2.7.14 key r1c1 starts in inactive state like all the others do. Because of that i thought it is an issue in 2.8.
Time to create page: 0.263 seconds
