MATRIX_KB in 2.8.0
- Thank you received: 5330
09 Aug 2020 15:23 #177756
Replied by PCW on topic MATRIX_KB in 2.8.0
Very odd
Can you do a little experiment?
leave the matrix_kb keycode pin unconnected until linuxcnc starts
and then enter the net command by hand, to see if the same issue
that is, comment out the connection in your hal file
#net keypad hm2_7i76e.0.7i73.0.2.keycode => matrix_kb.0.keycode
and then connect by hand when linuxcnc is running
halcmd net keypad hm2_7i76e.0.7i73.0.2.keycode => matrix_kb.0.keycode
(trying to see if there is an initial keycode problem of some kind)
The following user(s) said Thank You: Daniel_D_Punkt
- Daniel_D_Punkt
09 Aug 2020 15:53 #177759
by Daniel_D_Punkt
Replied by Daniel_D_Punkt on topic MATRIX_KB in 2.8.0
Ok, I did that:
when net keypad was unconnected it stated in the correct state (all keys inactive). Then I connected it via halcmd and it was inactive and worked as it should.
I moved the lineto the postgui.hal. Now it is working.
But i think this is a quick and dirty work around and the bug is still not found.
I moved the line
net keypad hm2_7i76e.0.7i73.0.2.keycode => matrix_kb.0.keycodeBut i think this is a quick and dirty work around and the bug is still not found.
09 Aug 2020 16:24 #177761
Does the problem happen with P1 unconnected?
- Daniel_D_Punkt
09 Aug 2020 16:48 #177763
by Daniel_D_Punkt
Same when P1 is unconnected.
09 Aug 2020 17:30 #177766
So its still not clear what is different between our setups. I guess It could be a faulty
7I73 but its still a pretty strange fault.
It does seem the the matrix_kb component should have a reset pin
to mask any startup transitions and restore operations if there has been an I/O fault
- Daniel_D_Punkt
09 Aug 2020 18:09 #177769
by Daniel_D_Punkt
A reset pin would be good.
I do not think it is a faulty 7i73.
I think there is a bug in my hal. It works when I connect matrix_kb in the postgui.hal and works with 2.7.14.
Thanks for helping me find the work around.
Time to create page: 4.627 seconds
