Poti for overrides
5 years 11 months ago - 5 years 11 months ago #189259 by keyboard
Replied by keyboard on topic Poti for overrides
Thanks Roland,
That was what I was going to ask next.,as the value bobbed around , can you post the lines you added after compiling the hyst comp.Im looking to modify the feed pot..
Last edit: 5 years 11 months ago by keyboard.
5 years 11 months ago #189337 by roland
Replied by roland on topic Poti for overrides
You can see my config in the attached hal files.
The feed pot and the rapid pot makes 5% Steps
File Name: 003.hal
File Size:22.87 KB
File Name: panel.hal
File Size:11.48 KB
5 years 11 months ago #189475 by keyboard
Thanks again Roland,
Works fine. Giving me the urge to add Rapid OVR also. I however set it to 1% increments, more used to it.
4 years 5 months ago #241879 by Ss64
Replied by Ss64 on topic Poti for overrides
I could really use this hyst.comp to settle down jumpy analog overrides.
Unfortunately the comp file archive linked here is no longer available and I can't figure out if something similar has been added to linuxcnc in the meantime.
Is there now a better way to do this kind of thing natively in Linuxcnc 2.8.1 or does it still require a custom component?
Maybe someone has a copy of that original hyst.comp file that I could use?
Cheers
Linus
4 years 5 months ago #241929 by roland
File Name: hyst.zip
File Size:1.61 KB
4 years 5 months ago #241937 by Ss64
Thank you!
Time to create page: 0.268 seconds
