Poti for overrides
3 years 5 months ago #272041 by PCW
Replied by PCW on topic Poti for overrides
Do you have field power?
3 years 5 months ago #272049 by Dragonick
Replied by Dragonick on topic Poti for overrides
Hal
File Name: my_LinuxCN...hine.hal
File Size:10.43 KB
Yes, I have a 5v or 24v power supply
3 years 5 months ago #272050 by PCW
The symptoms suggest you have no field power (Orange connector)
or there is some other issue with the field I/O section
(maybe W12 right or W1 right)
The following user(s) said Thank You: Dragonick
3 years 5 months ago #272052 by Dragonick
You are genius.
Brand new power supply defective.
Only after checking with a meter it turned out that there is no 24V.
Thank you
It remains to deal with the modbus because some error pops up and the machine will work
3 years 5 months ago - 3 years 5 months ago #272054 by JPL
Replied by JPL on topic Poti for overrides
@PCW: This is slightly off-topic but I wanted you to know that I believe there's an error in the 7i77 manual, on page 17, there:
ANALOG INPUTS
All field input pins are capable of reading the input voltage. These are not highly accurate or high resolution but can be useful for things like potentiometer inputs. Input resolution is 8 bits and input full scale value is 36.3V. Accuracy is +-5%. Software process data modes 1 and 2 allow reading the analog voltage on inputs 0 through 3, in addition to the 32 digital bit inputs.
I believe the text in bold should read:
"Software process data modes 1,2 and 3 allow reading the analog voltage on inputs 0 through 3"
Last edit: 3 years 5 months ago by JPL.
3 years 5 months ago #272055 by PCW
Yes, that's a mistake. I'll fix it.
Time to create page: 0.177 seconds
