Poti for overrides
3 years 5 months ago #272031 by Dragonick
Replied by Dragonick on topic Poti for overrides
Hi, I have mesa 7i77 and I get this error, what am I doing wrong?
3 years 5 months ago #272033 by PCW
Replied by PCW on topic Poti for overrides
Most likely the 7I77 is not set into a mode that supports analog inputs
Modes 1,2,3 support analog inputs
You change this with the "sserial_port_0=Something" command line argument
in the hal or ini file.
With most 7I77 firmware, sserial_port_0=200xxx should work
3 years 5 months ago #272034 by Dragonick
I changed in the hal file to:
serial_port_0=300xxx
serial_port_0=20xxx
serial_port_0=30xxx
And the same error keeps popping up
3 years 5 months ago - 3 years 5 months ago #272036 by JPL
Replied by JPL on topic Poti for overrides
serial_port_0=20xxx
serial_port_0=30xxx
... So close
Try with sserial_port_0=300xxx
Last edit: 3 years 5 months ago by JPL.
3 years 5 months ago #272037 by Dragonick
Also the same error. As if there were no analog inputs.
3 years 5 months ago #272039 by JPL
Can you attach your hal file here. I'll have a look
Time to create page: 0.369 seconds
