z-axis movement via ultrasonic sensor
- saztyga
23 Sep 2020 16:23 #183492
by saztyga
Replied by saztyga on topic z-axis movement via ultrasonic sensor
Sir,
I am Using ToF sensor , which field is quite narrow , but can you suggest me how can i achieve this setup by ardiuno.(or you suggest me any other board)
or please suggest me any tutorial so i can learn that.
thank you for your support ,this mean a lot to me.
- saztyga
23 Sep 2020 16:28 #183493
by saztyga
Yes Real time height adjustment , how can i achieve all this?
please suggest me any tutorial or give me some hint , i know how to connect sensor to ardiuno but how it will going to communicate with LunixCnc.
Please help me with this sir
- Thank you received: 7468
23 Sep 2020 16:30 #183495
Replied by tommylight on topic z-axis movement via ultrasonic sensor
The following user(s) said Thank You: saztyga
- saztyga
29 Sep 2020 22:55 #184334
by saztyga
one more time i had to bother you sir,
in my understanding X Y Z all moments are control by G-code and M-code, and these code are provided by CAD.
they fed to the CNC , then how the sensor going to interact with z axis.
- saztyga
29 Sep 2020 22:59 #184335
by saztyga
What if i create a mechanism that read sensor o/p and move entire tool up and down.
this motor(rack and pinion arrangement ) will completely independent of x y z axis motors.
Time to create page: 0.202 seconds
