Materialverter input and output files
- Electechcans
12 Oct 2020 21:18 #185881
by Electechcans
Materialverter input and output files was created by Electechcans
Hello, i am trying to use Materialverter so i can use Sheetcam files in Plasmac, I am putting my toolset which i have saved from Sheetcam in the input box and have tried to put my material.cfg file in the output box but nothing changes when i load my .ngc file. I am still getting g-code errors and nothing is changed in the way the code is. Am i putting the wrong file in the output box?
- Thank you received: 4144
12 Oct 2020 23:42 #185896
Replied by rodw on topic Materialverter input and output files
Have you installed the Plasmac post processor in sheetcam?
- Electechcans
13 Oct 2020 02:21 #185908
by Electechcans
Replied by Electechcans on topic Materialverter input and output files
Nope I used the linuxcnc post processor when I set it up. Is that something I have to add on to sheetcam?
13 Oct 2020 03:19 #185911
forum.linuxcnc.org/plasmac/38438-plasmac-post-processors
The following user(s) said Thank You: Electechcans
- Electechcans
13 Oct 2020 05:07 #185918
by Electechcans
When i run this PP it will run the entire cut and when it is done it stops in place at the end of the cut and i get a joint 3 following error, i have very little experience with gcode so im not sure what to do to make it go back to zero or where i started the job at. I used the PP from PHILLC54 (SheetCam post processor Revision F including a terse manual and toolset) because when i click the link in your post it doesn't go anywhere. His post is below yours here forum.linuxcnc.org/plasmac/38438-plasmac-post-processors
13 Oct 2020 10:17 #185957
There are some settings in the sheetcam job or somewhere to park the torch.
- Electechcans
13 Oct 2020 19:52 #186013
by Electechcans
I got this issue fixed thank you, now when i makes the first cut it finishes and goes to move to the safe position to get to the next cut and faults for arc off fault. I checked the disable arc on box and the job runs all the way through. I looked in sheetcam but i dont see anything, do i need to setup a snippet in sheetcam to fix this?
13 Oct 2020 20:43 #186019
Can you screen dump the fault and attach some gcode?
- Electechcans
13 Oct 2020 22:57 #186037
by Electechcans
It gets hung up on line 34 and says (valid arc lost program is paused). I put a camera pic in here, i cant screenshot it doesn't do anything when i try to use print screen, not sure where it is putting the screenshot or if its working at all. Like i said if i disable the arc ok signal it will run the whole job just fine.
13 Oct 2020 23:51 #186040
Are you using an arcok signal from your plasma cutter?
Time to create page: 0.145 seconds
