Control panel, MUX wiring help
01 Feb 2021 01:20 #197268 by rodw
Replied by rodw on topic Control panel, MUX wiring help
I think the keyboard module requires root.
Seems so but I think It just gets the keys using a program called dump. You could try saving the dump to a text file and using that.
But also pyAutoGUI seems to do the same thing.
pyautogui.readthedocs.io/en/latest/#
Man the last time I played with this stuff it was in the DOS days.
01 Feb 2021 01:26 #197269 by rodw
I have not tried this but:
You should be able to write a component in Python to "stuff" data (single character or a string) into the keyboard buffer.
The first version of matrix_kb had this capability. But it did it by calling external kernel routines, and there was a worry that we had no way to know that these were thread-safe so it was taken out.
This commit is where I removed that code:
github.com/LinuxCNC/linuxcnc/commit/b494...c3b3790a457e1ed354c8
So if that was all put in a separate userspace component, the matrix_kb could look (partially) like a standard keyboard to the OS.
(In a userspace component there is no need to worry about thread safety)
I wonder how this would be treated in PREMPT_RT? I thought it basically removed any non-thread safe code.
01 Feb 2021 01:32 #197270 by andypugh
Replied by andypugh on topic Control panel, MUX wiring help
userspace HAL components (In C and Python) work in all supported realtime systems.
01 Feb 2021 02:45 #197273 by rodw
So this example from the page above seems to work just from the python prompt
import pyautogui
pyautogui.write('Hello world!', interval=0.25)  # type with quarter-second pause in between each key
Auto types "Hello World" If you Select a text editor, it still types happily away
There seems to be a lot more you can do.
This is cool too
pyautogui.alert('This is the message to display.') # Make an alert box appear and pause the program until OK is clicked.
It would be pretty easy from here to make it a real keyboard...
01 Feb 2021 08:18 #197284 by RotarySMP
Replied by RotarySMP on topic Control panel, MUX wiring help
Luckily I sold that Maho menbrane keyboard, before you guys tempted me down this rabbit hole :)
03 Feb 2021 00:10 #197495 by andypugh
I am well down the rabbit hole, I have a HAL component that consumes the scancodes from matrix_kb or from a 7i73 and converts them to keystrokes.
I even had a prox limit switch connected via an STMBL drive typing the letter "c" in the terminal.
But then I broke it again, but it seems that it will work.
Watch this space.
The following user(s) said Thank You: RotarySMP, rodw
03 Feb 2021 00:23 #197497 by rodw
Watch this space.
So was it C for Curious or C for Cool?
Sounds exciting either way! I have a circuit board here waiting on one part before it turns into a shield for the 7i73... well hoping a mate will turn it into said shield cos he's much more into SMD soldering than I am!
03 Feb 2021 11:51 #197542 by RotarySMP
Maybe one of these set up as a fourth axis (C Axis) to push the button on the keyboard for you :)
Mark
The following user(s) said Thank You: tommylight, Clive S, rodw
03 Feb 2021 16:30 #197566 by tommylight
Replied by tommylight on topic Control panel, MUX wiring help
LOL, this one has evolved a fair bit ! :)
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
03 Feb 2021 21:33 #197596 by Todd Zuercher
Replied by Todd Zuercher on topic Control panel, MUX wiring help
Not sure why, but that really struck me funny. Thanks
Time to create page: 0.497 seconds
