- LinuxCNC
- General LinuxCNC Questions
- How do I link my mymilll.ini file to the gscreen_gaxis screen display
- Slippery
25 Oct 2020 21:10 #187219
by Slippery
How do I link my mymilll.ini file to the gscreen_gaxis screen display was created by Slippery
I am new at linuxcnc, schooled in design, worked in machining. So I am not schooled in this part of the process. I have looked at most of the possible screens to use, I like the axis gui but don't like the size of the icons if a few feet away. I would like to use the gscreen_gaxis screen. But cannot get it load from my ini file. I have tried a number of display line names, but none have worked.
is there any help or hope for me
- BeagleBrainz
- Visitor
25 Oct 2020 21:57 #187233
by BeagleBrainz
Replied by BeagleBrainz on topic How do I link my mymilll.ini file to the gscreen_gaxis screen display
Yes there is help.
Generally we need a bit more info.
The error log helps. Attaching your hal & ini files also helps. A slightly more descriptive description of the issue, "I can not get it to load" is about as helpful as "I can not get my car to start". It tells us what is not happening but not what is actually happening.
Looking at the sim config the line appears to be:
DISPLAY = gscreenPlease Log in or Create an account to join the conversation.
- Slippery
25 Oct 2020 22:39 #187245
by Slippery
Replied by Slippery on topic How do I link my mymilll.ini file to the gscreen_gaxis screen display
Thank you
I have used Display = gscreen, and yes the gscreen does work. But not gscreen_gaxis.
I have attached my ini file and error message.
- BeagleBrainz
- Visitor
25 Oct 2020 23:36 #187250
by BeagleBrainz
This is from gscreen_gaxis.ini in the samples
More info
linuxcnc.org/docs/2.8/html/gui/gscreen.html#_ini_settings
Looking thru the above and the sim files I can't see any reference to gscreen.gaxis, where did you get this from ?
DISPLAY = gscreen -c gaxis -cMore info
- Slippery
25 Oct 2020 23:41 #187251
by Slippery
gscreen.gaxis
This is what I had put in trying to make something work!!!!!
- BeagleBrainz
- Visitor
25 Oct 2020 23:42 #187252
by BeagleBrainz
Yeah but where did you read that was the parameter to use ?
- Slippery
25 Oct 2020 23:47 #187253
by Slippery
This works... Now I have to show how new I am at editing and reading these files. What is or does the -c do or mean in the line of code??
- Thank you received: 2175
- Slippery
25 Oct 2020 23:49 #187255
by Slippery
Thank you very much!!!!
- BeagleBrainz
- Visitor
25 Oct 2020 23:53 - 25 Oct 2020 23:55 #187256
by BeagleBrainz
I'd already linked that page here forum.linuxcnc.org/38-general-linuxcnc-q...creen-display#187250 did you just ignore it ?
When I was playing around with the sim the Touch Off buttons seemed in active.
Last edit: 25 Oct 2020 23:55 by BeagleBrainz.
- LinuxCNC
Time to create page: 0.152 seconds
