Touch probe configuration
5 years 10 months ago #191863 by MaHa
Replied by MaHa on topic Touch probe configuration
I'm affraid, your probingroutine needs some improvement.
About #5070. After successful probing, it gets TRUE, it stays true, until unsuccessful probing occures (no contact). So your probing will not be done after the 1st successful probing. Set #5070=0 before calling the subroutine. Another thing, for a loop like 'O<control> while [#5070 NE 1]' ,something like
o800 IF [#<_task> EQ 0] o800 RETURN o800 ENDIF
is needed at the top, or ending up in a endless loop when loading the routine.
The following user(s) said Thank You: Aciera, elisa
5 years 10 months ago #191944 by elisa
Replied by elisa on topic Touch probe configuration
Perfectly explained, thank you very much!
5 years 8 months ago #198034 by hex705
Replied by hex705 on topic Touch probe configuration
did you get this working ? if so, is it documented somewhere ?
5 years 8 months ago #198437 by elisa
Yes, it worked with the code above
Time to create page: 0.386 seconds
