Touch probe configuration
5 years 10 months ago #191740 by elisa
Replied by elisa on topic Touch probe configuration
Sorry.
Now It's attached
File Name: touchprobe...12-2.txt
File Size:1 KB
5 years 10 months ago - 5 years 10 months ago #191745 by Aciera
Replied by Aciera on topic Touch probe configuration
As you said, since you use trivial kinematics there is nothing else but drive that one joint.
[edit]
Any particular reason for not using a non-trivial kinematic?
Last edit: 5 years 10 months ago by Aciera.
The following user(s) said Thank You: elisa
  • Moderator
  • Moderator
5 years 10 months ago #191750 by tommylight
Replied by tommylight on topic Touch probe configuration
Aciera wrote: Any particular reason for not using a non-trivial kinematic?
Wanted to ask the same thing.
Not sure but it should be that when in World mode it should behave like a normal 3 axis machine although it has 5 or 6 axis/joints.
I have yet to dive into LinuxCNC robot part of the pond! :)
  • The Feral Engineer
  • Senior Member
  • Senior Member
5 years 10 months ago #191751 by The Feral Engineer
Replied by The Feral Engineer on topic Touch probe configuration
Did you make your configuration with stepconf? On your port and pin setting page, you just link your probe input to the proper parallel pin and you'll get the proper config in your HAL file. Then you can use halmeter to test it. You just need to tie your probe to an input on your interface card. On my g540, I run it one side to input 4 and the other to common. Doesn't matter which lead goes where, it's just completing a circuit.
5 years 10 months ago #191843 by elisa
Okay, I got it.
So I can drive it by setting the correct joint angles and then with #5070 I will get the probe status, right?
I use trivial kinematics because I process the joint angles with an other program, then I pass the gcode to LinuxCNC.
5 years 10 months ago #191847 by elisa
No, I didn't do it. Is it necessary? How can I configure it with stepconf?
Alternatively, it will be sufficient to add a .HAL file with only the line "net probe parport.0.pin-10-in => motion.probe-input"?
Sorry if I'm asking a lot of questions but I'm a beginner.
Time to create page: 0.336 seconds
