Linux Mint + other distros (why)?
11 Jan 2021 09:19 #194864 by tommylight
Replied by tommylight on topic Linux Mint + other distros (why)?
For runing machines and nothing else, well except for gcode editing, i use official Debian.
As Beagle mentioned, if it is not on the net, nothing to worry, it will work for years and years ... till some hardware fails.
The following user(s) said Thank You: CORBETT
11 Jan 2021 12:58 #194895 by BigJohnT
Replied by BigJohnT on topic Linux Mint + other distros (why)?
I have been sticking with Debian as LCNC was distributed on Debian in the theory that was more bullet proof than other distributions.
Debian was chosen after a licensing issue came up with Ubuntu that prevented us from using it on the LiveCD. Ubuntu 10.04 is/was my favorite and is still running on my Hardinge CHNC chucker lathe and my shop built plasma cutter and everyone is connected to my LAN except my VNC which still runs on DOS 6 as it's a 386 motherboard.
JT
The following user(s) said Thank You: robertspark, CORBETT
11 Jan 2021 16:53 #194925 by CORBETT
Replied by CORBETT on topic Linux Mint + other distros (why)?
JT,
Ok good to know.... as I was thinking that you guy's had built around the Debian platform specific.
DOS 6... I remember those day's... In 1988 my father bought a Texas Instruments server with Unix (why I am comfortable from command line), it was a learning curve at the beginning...
Tom,
Yeah at the moment I am going to stay with Debian at the machines, just as I have them.
Beagle,
Yeah I know what you are saying with breaking things if you don't know what you are doing, LOL... I am pretty good at finding out if it will break as I usually think I know more than I do... LOL. I still learn something new everyday.
11 Jan 2021 22:27 #194968 by rodw
Replied by rodw on topic Linux Mint + other distros (why)?
I am happy to use Debian but prefer to use Mint on a desktop.
I found that I could not install Debian without a network connection which posed a bit of a problem when I had to install a network driver. Mint did not care and caught up later..
If LCNC were to add the network driver required for an Odroid H2+ to the default ISO, it would be perfect!
11 Jan 2021 23:35 #194985 by BigJohnT
I've install Debian several times without a network connection... using the full install and not the net install.
JT
11 Jan 2021 23:49 #194989 by rodw
JT
Aahh! so I picked the wrong option. I will redo it.
12 Jan 2021 02:52 #195005 by tommylight
Use the non-free version of Debian ISO, no issues with drivers.
12 Jan 2021 07:04 #195018 by CORBETT
I had a different problem in which I was trying to do the network install, but I only had wireless internet mifi.... It would seamlessly install when hardwired cat5, but no go with wireless (no drivers). I would take a computer to my friends house to do a fresh install off his hardwire connection and back to my place to setup.
This got time consuming when I wanted to start a different build... So I finally made a work a round by getting a TP-Link TL-WA860RE Range Extender and connecting cat5 directly to the computer basically like a AP.. chose this as it was $12 shipped on eBay, cheap to accomplish the goal, and they are probably cheaper now even.
12 Jan 2021 07:13 #195019 by rodw
There is if the network driver is not yet in the repositories. The H2+ uses 2.5gb ethernet
12 Jan 2021 11:39 #195037 by tommylight
Time to create page: 0.126 seconds
