ABB IRB 6400 retrofitting
4 years 1 month ago #251002 by Freak
Replied by Freak on topic ABB IRB 6400 retrofitting
Hi! I tried to set all 8 sserial to mode 2 i can't see any sserial in "show hal configuration" and the 4 leds are always on (lights up) whether I try to toggle'em with "setp ...".
mesaflash --device 7i94 --addr 10.10.10.10 --readhmid Configuration Name: HOSTMOT2 General configuration information:   BoardName : MESA7I94   FPGA Size: 9 KGates   FPGA Pins: 144   Number of IO Ports: 2   Width of one I/O port: 21   Clock Low frequency: 100.0000 MHz   Clock High frequency: 200.0000 MHz   IDROM Type: 3   Instance Stride 0: 4   Instance Stride 1: 64   Register Stride 0: 256   Register Stride 1: 256 Modules in configuration:   Module: DPLL   There are 1 of DPLL in configuration   Version: 0   Registers: 7   BaseAddress: 7000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: WatchDog   There are 1 of WatchDog in configuration   Version: 0   Registers: 3   BaseAddress: 0C00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: IOPort   There are 2 of IOPort in configuration   Version: 0   Registers: 5   BaseAddress: 1000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: SSerial   There are 1 of SSerial in configuration   Version: 0   Registers: 6   BaseAddress: 5B00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 64 bytes   Module: LED   There are 1 of LED in configuration   Version: 0   Registers: 1   BaseAddress: 0200   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes Configuration pin-out: IO Connections for Expansion+Serial 0..1 Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir P1-01/DB25-01           0   IOPort       None            P1-02/DB25-14           1   IOPort       None            P1-03/DB25-02           2   IOPort       None            P1-04/DB25-15           3   IOPort       None            P1-05/DB25-03           4   IOPort       None            P1-06/DB25-16           5   IOPort       None            P1-07/DB25-04           6   IOPort       None            P1-08/DB25-17           7   IOPort       None            P1-09/DB25-05           8   IOPort       None            P1-11/DB25-06           9   IOPort       None            P1-13/DB25-07          10   IOPort       None            P1-15/DB25-08          11   IOPort       None            P1-17/DB25-09          12   IOPort       None            P1-19/DB25-10          13   IOPort       None            P1-21/DB25-11          14   IOPort       None            P1-23/DB25-12          15   IOPort       None            P1-25/DB25-13          16   IOPort       None            J6 1,2                 17   IOPort       SSerial          0        RXData0         (In) J6 3,6                 18   IOPort       SSerial          0        TXData0         (Out) J6 TXEN                19   IOPort       SSerial          0        TXEn0           (Out) J7 1,2                 20   IOPort       SSerial          0        RXData1         (In) IO Connections for Serial 1..7 Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir J7-3,6                 21   IOPort       SSerial          0        TXData1         (Out) J7-TXEN                22   IOPort       SSerial          0        TXEn1           (Out) J8-1,2                 23   IOPort       SSerial          0        RXData2         (In) J8-3,6                 24   IOPort       SSerial          0        TXData2         (Out) J8-TXEN                25   IOPort       SSerial          0        TXEn2           (Out) J9-1,2                 26   IOPort       SSerial          0        RXData3         (In) J9-3,6                 27   IOPort       SSerial          0        TXData3         (Out) J9-TXEN                28   IOPort       SSerial          0        TXEn3           (Out) J4-1,2                 29   IOPort       SSerial          0        RXData4         (In) J4-3,6                 30   IOPort       SSerial          0        TXData4         (Out) J4-TXEN                31   IOPort       SSerial          0        TXEn4           (Out) J3-1,2                 32   IOPort       SSerial          0        RXData5         (In) J3-3,6                 33   IOPort       SSerial          0        TXData5         (Out) J3-TXEN                34   IOPort       SSerial          0        TXEn5           (Out) J2-1,2                 35   IOPort       SSerial          0        RXData6         (In) J2-3,6                 36   IOPort       SSerial          0        TXData6         (Out) J2-TXEN                37   IOPort       SSerial          0        TXEn6           (Out) J1-1,2                 38   IOPort       SSerial          0        RXData7         (In) J1-3,6                 39   IOPort       SSerial          0        TXData7         (Out) J1-TXEN                40   IOPort       SSerial          0        TXEn7           (Out) P2-/ENA                41   IOPort       None
4 years 1 month ago #251008 by tommylight
hm2_eth board_ip="10.10.10.10 sserial_port_0=0120xxxx"
should become
hm2_eth board_ip="10.10.10.10 sserial_port_0=01202222"
And you need to check the pins, not mesaflash, to see the actual pins.
Can you start LinuxCNC?
If yes, use the "show hal configuration", on the left choose "pins" then the card name then the rest of the boards that were found.
The following user(s) said Thank You: Freak
4 years 1 month ago #251011 by Freak
yes the output is in the attachment, is it normal to not see the sserial entry?
4 years 1 month ago #251032 by tommylight
No.
All Mesa sserial cards i use have a green flashing led when LinuxCNC is up and running and their pins show.
4 years 1 month ago #251095 by Freak
Thankyou, so when i tried to load every single component I realized that at the beginning:
halcmd: loadrt trivkins coordinates=XYZ halcmd: loadrt motmod servo_period_nsec=1000000 num_joints=3 motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: update_joint_homing_params <stdin>:2: waitpid failed /usr/bin/rtapi_app motmod <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for motmod failed, returned -1
I installed linuxcnc 2.9.0~pre0 and the rt kernel through package manager.
4 years 1 month ago #251097 by dgarrett
Replied by dgarrett on topic ABB IRB 6400 retrofitting
For this error:
In the master branch, you must load required modules
(kinematics, trajectory planning, homing, motion)
in an order that resolves symbols.
Example using trivkins and defaults for the homing and
trajectory planning:
$ halrun
Note: Using POSIX realtime
halcmd: loadrt tpmod
halcmd: loadrt homemod
halcmd:
halcmd: show comp
Loaded HAL Components:
ID Type Name PID State
16 RT __servo-thread ready
15 RT motmod ready
14 User halcmd627680 627680 ready
12 RT homemod ready
7 RT tpmod ready
4 RT trivkins ready
The following user(s) said Thank You: arvidb, tommylight, Freak
Time to create page: 0.339 seconds
