ABB IRB 6400 retrofitting
3 years 2 months ago #278891 by Freak
Replied by Freak on topic ABB IRB 6400 retrofitting
Hi, I managed to control the robot with the custom stmbl and linuxcnc, but I was wondering if it is possible to skip the homing procedure having the position.txt file and the resolver of the stmbl, similarly to  #116065 .
There is someone that already solved this problem or should I investigate more?
I though maybe I have to apply an offset to the feedback inside the stmbl in order to center the zero in the home position, then multiply the sserial0.scale with the position in the position.txt, and replace decimals with the resolver + offset value in stmbl? (considering if decimals are >0.5rev then position=int(position)-1+resolver_read).
Moreover I have to apply an offset of -90° to the joint 2 because of the DH params, maybe that can be a problem?
3 years 2 months ago - 3 years 2 months ago #278901 by Aciera
Replied by Aciera on topic ABB IRB 6400 retrofitting
[edit] Actually, rereading your post, I'm not sure if you are looking for specifics using the homing solution as proposed by andy in the linked post or if you are looking for alternatives.
Last edit: 3 years 2 months ago by Aciera.
3 years 2 months ago #278914 by Freak
I would like to use the stmbl position feedback as absolute resolver (in the machine the resolver are attached to the motor, so they are not absolute in term of joint). Then homing would be just applying an offset without moving the machine.
I'm just interested knowing if this problem has already being solved or not.
3 years 2 months ago #278938 by Aciera
Ah, I think Andy would be the man to answer this then.
The following user(s) said Thank You: Freak
3 years 1 month ago #280122 by Freak
Ok I'll wait for Andy then :D
3 years 1 month ago #280335 by Freak
I created this new topic since the question I think deserve it's own.
Time to create page: 0.060 seconds
