ABB IRB 6400 retrofitting
5 years 7 months ago #202175 by Freak
Replied by Freak on topic ABB IRB 6400 retrofitting
Another quick update, I have the new pcbs, I plan to assemble this or next weekend.
The following user(s) said Thank You: arvidb, tommylight
5 years 7 months ago #202181 by tommylight
After assembling, i will gladly test them for you, just mail them my way ! :)
The following user(s) said Thank You: Freak
5 years 4 months ago #211315 by Deckerjwd
Replied by Deckerjwd on topic ABB IRB 6400 retrofitting
just put a irb2400 with an s4 controller in. plan on leaving the controller but was thinking it would be cool if i could send it G-code to RAP over serial, without gutting the system.
5 years 4 months ago #211353 by Aciera
Replied by Aciera on topic ABB IRB 6400 retrofitting
Have a look at roboDK, that offers a Gcode import function if I remember correctly
4 years 2 months ago - 4 years 2 months ago #250900 by Freak
Hi, It's been a while since I couldn't continue the project. Right now I'm trying to debug the old intel nuc + 7i94 + custom stmbl.
I installed debian bullseye and linuxcnc from testing and also the rt kernel. The latency is very good.
I can connect to the 7i94 but I don't know how the smart serial works. There aren't any "sserial" entry inside the "show Hal configuration", am I missing something?
(I've loaded the 7i94ssd firmware, and the hal conf is:
loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10 sserial_port_0=0120xxxx" setp hm2_7i94.0.watchdog.timeout_ns 25000000 addf hm2_7i94.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf hm2_7i94.0.write servo-thread setp hm2_7i94.0.dpll.01.timer-us -50
In the meanwhile I post some pics about the first assembled stmbl image missing /media/kunena/emoticons/smile.png
Last edit: 4 years 2 months ago by Freak.
4 years 1 month ago #250985 by fins
Replied by fins on topic ABB IRB 6400 retrofitting
What's the output of:
mesaflash --device 7i94 --readhmid
Check this post  for a good explanation of the sserial_port  mode settings, your current one would have 4 ports enables in mode 0,1,2 and 0 respectively, and the other 4 diabled.
Time to create page: 0.081 seconds
