Spindle speed variation ssv for chatter control
- snujcnc
- Thank you received: 4
03 Feb 2021 11:40 #197541
by snujcnc
Spindle speed variation ssv for chatter control was created by snujcnc
I want to know
Linux CNC can control spindle rpm during operation
Ssv spindle speed variation
This type of function require to control chatter during turning operation
If we rotate spindle 1000 rpm and we program variation 150 rpm then during auto mode running spindle rpm variation should be 1150 to 850 continuous
Any idea how to implement this functionality
- Thank you received: 7483
03 Feb 2021 12:45 #197544
Replied by tommylight on topic Spindle speed variation ssv for chatter control
Yes it can.
No double posting, other post deleted.
- snujcnc
03 Feb 2021 13:41 #197547
by snujcnc
Replied by snujcnc on topic Spindle speed variation ssv for chatter control
How?
03 Feb 2021 16:35 #197569
If it is CSS or Constant Surface Speed, basically changing the spindle speed based on the perimeter of the material, here is everything on the LinuxCNC site about it:
www.google.com/search?source=hp&ei=2M8aY...P1DM4Q4dUDCAY&uact=5
If it is for the "jerk limiting" :
www.google.com/search?ei=588aYN-gGdyPwbk...E9DSwQ4dUDCAw&uact=5
- snujcnc
03 Feb 2021 18:39 #197582
by snujcnc
CSS I know and I am using this feature
I am talking about
Spindle rpm variation during machining on turning Center
This function help reduce chatter on this shaft turning
I am talking about
- Clive S
- Thank you received: 486
03 Feb 2021 18:47 #197584
by Clive S
Replied by Clive S on topic Spindle speed variation ssv for chatter control
similar to this
- Thank you received: 4149
03 Feb 2021 19:22 #197588
Replied by rodw on topic Spindle speed variation ssv for chatter control
You should be able to use the siggen component to apply a sine wave offset to your spindle speeds.
The following user(s) said Thank You: tommylight, Catch22
- Henk
- Thank you received: 92
03 Feb 2021 19:29 #197589
by Henk
Replied by Henk on topic Spindle speed variation ssv for chatter control
Yes. Siggen set up to output a sine wave with low frequency. Maybe the amplitude and frequency adjustable with a pyvcp panel. Use sum2 to add it to your spindle speed command.
The following user(s) said Thank You: tommylight, snujcnc, Catch22
- Catch22
- Thank you received: 17
04 Feb 2021 00:52 #197609
by Catch22
Replied by Catch22 on topic Spindle speed variation ssv for chatter control
Sounds simple to me...Not...
- robertspark
- Thank you received: 216
04 Feb 2021 21:39 #197686
by robertspark
Replied by robertspark on topic Spindle speed variation ssv for chatter control
if someones got the time, I'd like an idiots guide to this please
Time to create page: 0.111 seconds
