7i76e input output config
- Yannis
- Thank you received: 4
04 Mar 2021 15:19 #201025
by Yannis
7i76e input output config was created by Yannis
Hello
i experience some difficulties config input and outputs on the 7i76e
with my config i can open linuxcnc enable the motors and i can jog the motor
I
i can not
open the spindle (output) or trigger the limit switch or e stop (input)
Suggestions?
I
i can not
Suggestions?
- Thank you received: 5330
04 Mar 2021 16:22 #201027
Replied by PCW on topic 7i76e input output config
Normally the inputs would be wired like this:
Field-power --> LimitT1 --> LimitT2 --> 7I76E input
Also the 7i76e spindle enable is not connected on the hal file
The following user(s) said Thank You: Yannis
- Yannis
05 Mar 2021 06:04 #201081
by Yannis
Replied by Yannis on topic 7i76e input output config
The best way to connect the limit switch is to provide the 7i76e constantly with 24 volts and 0 volt when the switch is triggered?
05 Mar 2021 15:05 #201100
Yes , Normally closed (NC) contacts are preferred for home/limit switches
since a broken wire will cause an immediate fault
- Yannis
06 Mar 2021 07:03 #201159
by Yannis
can you point me where can i find info for connecting signals and pins?
06 Mar 2021 14:24 - 06 Mar 2021 15:50 #201187
Normally you would set the spindle up in pncconf.
For example, this is what pncconf generates for open loop analog spindle control
with spindle encoder:
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp [HMOT](CARD0).7i76.0.0.spinout-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp [HMOT](CARD0).7i76.0.0.spinout-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
setp [HMOT](CARD0).7i76.0.0.spinout-scalemax [SPINDLE_0]OUTPUT_SCALE
net spindle-output => [HMOT](CARD0).7i76.0.0.spinout
net spindle-enable => [HMOT](CARD0).7i76.0.0.spinena
net spindle-ccw => [HMOT](CARD0).7i76.0.0.spindir
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [SPINDLE_0]ENCODER_SCALE
net spindle-revs <= [HMOT](CARD0).encoder.00.position
net spindle-vel-fb-rps <= [HMOT](CARD0).encoder.00.velocity
net spindle-vel-fb-rpm <= [HMOT](CARD0).encoder.00.velocity-rpm
net spindle-index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
Last edit: 06 Mar 2021 15:50 by PCW.
- Yannis
18 Mar 2021 12:40 #202732
by Yannis
Hello I have two boards of 7i76e
with the one and the same configuration I can trigger an output
with the other one I have this error
- Yannis
18 Mar 2021 12:49 #202735
by Yannis
Debug
18 Mar 2021 15:05 #202745
If you get that error it likely means:
1. You have no field or VIN power (VFIELD >+ 5V VIN >8V)
2. W8 in right hand position
3. 7I76E with damaged I/O section
- Yannis
02 Apr 2021 11:15 #204479
by Yannis
Time to create page: 0.350 seconds
