7i76e input output config
02 Apr 2021 11:32 #204481 by PCW
Replied by PCW on topic 7i76e input output config
That usually indicates a setup problem of some kind.
What it means is the the step generator feedback does
not match the position command.
Can you post you current hal and ini files?
02 Apr 2021 15:01 #204511 by Yannis
Replied by Yannis on topic 7i76e input output config
File Name: CMSTEST.hal
File Size:12 KB
File Name: CMSTEST.ini
File Size:4 KB
02 Apr 2021 15:26 #204516 by PCW
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 15.0
MAX_ACCELERATION = 50.0
STEPGEN_MAXVEL = 15  <<<<<<<< this needs to be 25% larger than MAX_VELOCITY
STEPGEN_MAXACCEL = 50  <<<<<<<<<  this needs to be 25% larger than MAX_ACCCELERATION
The following user(s) said Thank You: Yannis
Time to create page: 0.142 seconds
