can some one help.
- samn
07 Mar 2021 22:07 #201371
by samn
can some one help. was created by samn
after setup linux cnc wizard and ran test x y z all look good working ok., exit wizard
tring to jog machine after homing nothing movin
- Clive S
- Thank you received: 486
07 Mar 2021 22:27 #201373
by Clive S
Can you post the HAlL and INI files from the config folder
Replied by Clive S on topic can some one help.
- Thank you received: 7468
07 Mar 2021 22:34 #201376
Replied by tommylight on topic can some one help.
Assuming this is a stepper system with the usual drives, disconnect the "enable" wires, start LinuxCNC and test again.
- samn
07 Mar 2021 23:12 #201381
by samn
Replied by samn on topic can some one help.
tommy when i run test run it work fine, so witch to the linux mode, homeing x y z
i got no joging movement ,,
- Thank you received: 4652
08 Mar 2021 00:16 #201382
Replied by andypugh on topic can some one help.
The stepconf test does not use the enable signals.
You probably configured the enable signals to the drives, and these are probably set up the wrong way round.
Most stepper drives work with the enable terminals disconnected.
There really is very little to be gained by using the drive enable pins with a stepper system.
- samn
08 Mar 2021 01:10 #201383
by samn
would you be possible to give some kind example oh how do i need to setup driver, or best way to configure signal to the driver,
- Mike_Eitel
- Thank you received: 183
08 Mar 2021 08:22 #201396
by Mike_Eitel
Replied by Mike_Eitel on topic can some one help.
I have the enable signals connected to e-stop.
And by principle I dislike unconnected inputs. Also if they have internal pull-ups, they should be defined by wire. That way you decided what you expect to become
m5c
Mike
m5c
Mike
- Grotius
- Thank you received: 2349
08 Mar 2021 08:45 #201397
by Grotius
Replied by Grotius on topic can some one help.
@Samn,
exit wizard
One thing to pay attention to is that in the homing procedure the machine has to move back from home switches after homing.
This offset value is user defined.
Maybe your homing sensor stay's active. In this case the machine can not be moved.
exit wizard
The following user(s) said Thank You: samn
- samn
08 Mar 2021 17:14 #201448
by samn
after clear-E stop, reset homing, move stepper on screen X Y Z looks like is moving stepper motor are not. I think there is some kind disconnect between Lunix and driver.
08 Mar 2021 18:38 #201462
We need more to go on.
We have made two suggestions about what might be wrong. Did either help?
The test worked so step and dir must be wired OK.
The DRO is moving, so you have not forgotten to take LinuxCNC out of e-stop.
Do the motors turn freely or are they locked when LinuxCNC is turned on?
Time to create page: 0.187 seconds
