can some one help.
- samn
08 Mar 2021 19:48 #201479
by samn
Replied by samn on topic can some one help.
i m using Probiotic PBX-RF, BOARDS.
i did try all above recommendations, no lock, also e-stop shown off , linuc display shows machine on i press on key board tale coordinate x y move on display, but my driver don't move
but they do move when i run wizard config test ,
- Thank you received: 4652
08 Mar 2021 20:26 #201482
Replied by andypugh on topic can some one help.
If the motors are not locked then the drives are not enabled.
Do you have the drive enables wired?
- samn
08 Mar 2021 20:40 #201484
by samn
yes ,
- samn
08 Mar 2021 22:19 #201491
by samn
Motor are lock as soon as linux cnc start motor lock .
08 Mar 2021 22:44 #201496
Do the motors remain locked when LinuxCNC is taken out of E-stop and turned on (F1 then F2)
- samn
08 Mar 2021 23:18 #201501
by samn
That is correct. Is there's a way we can connect
- samn
09 Mar 2021 00:01 #201503
by samn
Andy is their a way for me to call u
- samn
09 Mar 2021 17:42 #201570
by samn
is there a way to check linux cnc communicate with driver board after exit wizard configuration.
09 Mar 2021 20:55 #201593
If the drives are enabled then does the DRO in LinuxCNC move when you jog / home?
If it does, and if the motion test worked, and the wiring has not been changed since then, then I am out of ideas.
- samn
09 Mar 2021 21:17 #201597
by samn
Andy I'm ready to swap the driver board. Any recommendation for good driver with linux
Time to create page: 0.129 seconds
