PlasmaC encoder .00.velocity question
- bevins
- Thank you received: 338
10 Mar 2021 14:33 #201648
by bevins
PlasmaC encoder .00.velocity question was created by bevins
I am wondering if I am connecting to encA+ and encA- on the 7i76 TB3, why I would reference 7i92.0.encoder.0.0.velocity.
Where is the connection between that signal and 7i92.0.7i76.0.0.enc0 which is where I am connected?
I am a bit confused with this as I am ready to pull the trigger to do the PlasmaC config. Everything is connected and working even thcad is connected but not tested.I just need to know if I put 7i92.0.encoder.0.0.velocity in as Arc Voltage for mode 1 it will connect somehow to enc0 which is where my thcad is connected.
- Thank you received: 5314
10 Mar 2021 15:19 #201652
Replied by PCW on topic PlasmaC encoder .00.velocity question
hm2_7i92.0.encoder.00.velocity would be correct
7i92.0.7i76.0.0.enc0 would be MPG encoder count 0
- bevins
10 Mar 2021 15:27 #201653
by bevins
So, enc0 and enc1 has nothing to do with encA on TB3 of 7i76?
Replied by bevins on topic PlasmaC encoder .00.velocity question
10 Mar 2021 15:49 #201655
No, they are associated with the MPG encoders on field inputs 16,17,18,19
- snowgoer540
- Thank you received: 900
10 Mar 2021 16:00 #201657
by snowgoer540
Have you considered doing a QtPlasmaC config instead? Development has now stopped on PlasmaC. All new work will be done to the QtPlasmaC project.
It also has a lot of new features that were not possible with PlasmaC being on top of Axis or Gmoccapy.
Here's a link to the manual: linuxcnc.org/docs/devel/html/plasma/qtplasmac.html
Replied by snowgoer540 on topic PlasmaC encoder .00.velocity question
- bevins
10 Mar 2021 16:50 #201664
by bevins
When does the madness end? This is a customers machine that needs to be delivered in a week and a half.
The machine is working and I am able to draw files with a pen. I just did PlasmaC config and that seems to be working although I didn't do any plasma testing or anything.
Is it worth going the QT route? I have had issues with QT before and it was very quirky and I was never able to get it going on one machine.
I am running on linuxmint 19.3. I am wondering if it is worth it or not. I have nightmares about QT....
- snowgoer540
10 Mar 2021 17:15 - 10 Mar 2021 17:18 #201665
by snowgoer540
What madness? Did I miss something?
If it's a customer's machine and you're happy and they're happy...then let 'er eat. In this case maybe it's best to get more miles under the QtPlasmaC belt via other people's use.
I didn't mean to give you nightmares, just wanted you to be aware since you said you were making a new config.
Last edit: 10 Mar 2021 17:18 by snowgoer540.
- bevins
10 Mar 2021 18:27 #201673
by bevins
Madness meaning never ending changes......
Yeah, Is it ready for prime time?
Also is sheetcam being used for CAM with PlasmaC and QTPlasmaC? Any issues I need to know. Is there any setup to do I need to know that is documented somewhere?
- Thank you received: 7465
10 Mar 2021 18:36 #201676
Replied by tommylight on topic PlasmaC encoder .00.velocity question
I would advise to stay with PlasmaC for now, especially on customer machines.
I plan to do the same, hell i still have machines with LinuxCNC 2.7 on Ubuntu 10.04 running happily every day, changing them would be counter productive as it works perfectly and it will also take some time for them to get the hang of it.
Soon i will have at least 3 or 5 or more of my machines so i will use QtPlasmaC on those all the time!
- snowgoer540
10 Mar 2021 18:56 - 10 Mar 2021 18:56 #201684
by snowgoer540
Hard to tell tone via written media sometimes. But it seems like you might be complaining that there's active development/bug fixes, etc. on free, open source software.....
Last edit: 10 Mar 2021 18:56 by snowgoer540.
Time to create page: 0.707 seconds
