ROS LinuxCNC Link
5 years 5 months ago #208492 by Bari
Replied by Bari on topic ROS LinuxCNC Link
Roiki wrote: You would want to use ros for this. It already has a support for real sense cameras and more so all you need is to figure out what you want to use it with.
The problem I have with ROS and with most robots is the lack of real time support for things that have to be synchronized in well under 1mS. I need to synchronize motion to mechanisms e.g., printheads, lasers, etc. that operate at a hundred times faster and I can't use interpolation. Try and ask for encoder outputs from inside a robot so that you can keep track of position in real time. I need realer time!
I'm not a fan of Intel and the depth measurement accuracy of their cameras is only 2%. In my circuit board fiducial application XY is of most interest since the PCB's are pretty consistent in thickness. A few microns of variance in Z will cover the worst of applications. I don't need stereo vision for this.
5 years 5 months ago - 5 years 5 months ago #208493 by Grotius
Replied by Grotius on topic ROS LinuxCNC Link
Hi Arciera,
Here is a tiny present for you :
link
Hi Bari,
My program uses 1000 preprocessed frames a second. It's a different approach. It's like playing a video.
Last edit: 5 years 5 months ago by Grotius.
5 years 5 months ago #208496 by Aciera
Replied by Aciera on topic ROS LinuxCNC Link
Nice, thanks!
Looks like a rainy day tomorrow, so I'll give it a go and report back.
5 years 5 months ago #208499 by Grotius
Hi Arciera,
Wich linux version are you running?
5 years 5 months ago #208523 by Aciera
I'm running Debian 10
5 years 5 months ago #208525 by Aciera
Regarding your github link:
Is there actually a branch for me to build and test there?
Time to create page: 0.320 seconds
