ROS LinuxCNC Link
5 years 5 months ago #208357 by Aciera
Replied by Aciera on topic ROS LinuxCNC Link
Thanks for the examples.
To come back to my favourite question, how would we choose the Mode of movement (ie JOINT-,XYZ-,TOOL-mode) ?
Is it determined by the parameters given?
So if I wanted to execute a Joint move (ie without using the kinematics/inversekinematics) would I write:
line1 {type{rapid} point{endpoint} joint{90,90,0,148,62,-95} velstart{20} velend{20}}
If I then wanted to execute a move in XYZ cartesian mode (ie using the kinematics/inversekinematics):
line2 {type{line} point{endpoint} cart{100,200,10) eul(0,45,-45} velstart{20} velend{20}}
Is it possible to simulate the program before running it on the physical robot using a graphical STL model?
5 years 5 months ago - 5 years 5 months ago #208359 by Grotius
Replied by Grotius on topic ROS LinuxCNC Link
Hi Arciera,
Yes, you got it. I see your rapid move example has a initial velocity and a end velocity of 20.
If i see your example, i understand the syntax at first sight. The software know's what to do with these lines.
No need to choose mode. :)
Do you have a working robot halfile for mesa already?
Yes, it has the opencascade simulator in the touch screen tab. Later on i will finish that implementation.
I will be super easy to setup your robot model trough the touch screen mode.
For info:
The final programming line wich will be stored in the 1ms files are auto-completed during preprocessing.
I am really excited when i do a first run on real hardware. It will take some time to work trough the project now.
Last edit: 5 years 5 months ago by Grotius.
5 years 5 months ago - 5 years 5 months ago #208368 by Aciera
I do have a working hal file but it is not for a mesa board. Since I use Mitsubishi drives with an optical SSCNET bus I use dmitrys nyx-branch to be able to use his PCI-interface card. : github.com/yur7aev/linuxcnc/tree/nyx_master
So really since I'll need LinuxCNC with the SSCNET driver to run my hardware I don't know if I'll ever be able to get my robot to run on your application.
But here is my config anyway:
File Name: RV-6SDL.tar
File Size:253.5 KB
[edit]
I have removed the rather large STL model files.
Last edit: 5 years 5 months ago by Aciera.
The following user(s) said Thank You: tommylight, Grotius
5 years 5 months ago #208372 by Grotius
Ok, i will look at your hal file and report back.
Update,
The gui makes component with one buttonclick and loads it into the kernel. B)
5 years 5 months ago #208402 by Bari
Replied by Bari on topic ROS LinuxCNC Link
Nice work! Teach modes for robots are good enough for moving things like a pallet around but fall short for most things with precision movements.
How would you be able to hook into something like machine vision that will create offsets for the "learned" paths? An example might be that a robot moves to the corner of a circuit board where there is a fiducial. The camera looks at the pattern and outputs an offset to center the end of arm tool.
5 years 5 months ago #208413 by rodw
Replied by rodw on topic ROS LinuxCNC Link
Bari wrote: Nice work! Teach modes for robots are good enough for moving things like a pallet around but fall short for most things with precision movements.
You may be able to use something like this www.intelrealsense.com/lidar-camera-l515/
These return a depth image stream (and infrared and rgb streams ) that gives a distance from the camera to objects at the pixel level
I've been playing with one for dimensioning parcels in keeping with your warehouse theme.... We just got integration with weighing scales integrated last night.
Time to create page: 0.087 seconds
