- Thank you received: 2349
Aciera wrote: @Roiki
Actually I'm not aware that there is support for industry style robot programming even in ROS. Last time I had a look at it one had to use c++ or python script to send the commands. But maybe this has changed.
Roiki wrote: You would want to use ros for this. It already has a support for real sense cameras and more so all you need is to figure out what you want to use it with.
And imo it would make more sense to contribute to an already existing framework that others can use than to roll your own solution.
+1Aciera wrote: So sometimes we just need to be grateful for what may look as a suboptimal solution in order to advance at all.
