Parallel Port Dropping Steps
- rmhenrie
02 Apr 2021 16:30 - 02 Apr 2021 19:16 #204526
by rmhenrie
Parallel Port Dropping Steps [SOLVED] was created by rmhenrie
I've never posted to a forum before now. I usually beat my head against a wall until I figure it out myself but I'm not sure what's going on here.
The Problem
I've set up a new machine. Normal XYZ running version 2.8.1 with 2 PPort PCIe cards and BOBs. I ran Stepconf like I always do to set up an initial hal and ini file. I tested the steppers in Stepconf and they worked perfect. Smooth and precise motion. I launched my configuration and when I jog the machine though I get really jittery motion. What's also interesting though is that it worked perfect in stepconf, and if I issue a G0X.. (or G1) command in MDI it works perfect again. I opened up halscope to view the parport.0.pin-02-out (X step pin). When I jogged the X axis, it looks like the step pulses are getting dropped since there were intermittent gaps between pulses. When I issued the G0 command, the were no gaps (links to the pictures below).
What I've Tried
Setting step time and step space to 10000ns and 20000ns.
Setting the base thread to 50000ns in Stepconf and 150000ns manually in the ini file
Other Important Info
I don't think this is a hardware problem as it happens on all axes.
I'm not using the reset function as Stepconf doesn't add it in the hal file
Halscope snapshot jogging x axis:
photos.app.goo.gl/UzHY3ya4RpFAhFzT9
Halscope snapshot using G0 command with x axis:
photos.app.goo.gl/exc4XLomFfvZD6wS9
The Problem
What I've Tried
Last edit: 02 Apr 2021 19:16 by rmhenrie.
- rmhenrie
02 Apr 2021 16:35 #204527
by rmhenrie
Replied by rmhenrie on topic Parallel Port Dropping Steps
Here is the latest hal and ini file I've tried too.
Thanks in advance!
Thanks in advance!
- Thank you received: 7468
02 Apr 2021 17:28 #204536
Replied by tommylight on topic Parallel Port Dropping Steps
- rmhenrie
02 Apr 2021 19:15 #204547
by rmhenrie
That fixed it. Thank you so much!
02 Apr 2021 21:14 #204559
You are welcomed, always.
Time to create page: 0.106 seconds
