Machine controls greyed out
17 Apr 2021 19:51 #206217 by paulstenlund
Machine controls greyed out was created by paulstenlund
Hello
The pc controlling my router died (12yrs, - pretty good run), replaced it, loaded Linuxcnc, now my machine controls are greyed ott.
I suspect my parallel port . How do I configure it in linux? or what else could it be?
Paul
  • Moderator
  • Moderator
17 Apr 2021 19:56 #206218 by tommylight
Replied by tommylight on topic Machine controls greyed out
Could be parallel port does not have pull up resistors, but first, does the machine have an E-Stop ?
17 Apr 2021 20:14 #206222 by paulstenlund
Replied by paulstenlund on topic Machine controls greyed out
I don'tbeleive it has a e-stop, no limit switches. its a Probootics controller that worked for years.
Paul
  • Moderator
  • Moderator
17 Apr 2021 22:00 #206232 by tommylight
Screenshot ?
17 Apr 2021 22:25 #206236 by paulstenlund
Don't know how to take a screenshot in Linux. The machine controls are greyed out from:
toggle machine power
to
Stop
Paul
  • Moderator
  • Moderator
17 Apr 2021 23:01 #206237 by tommylight
On Debian, there is a "take screenshot" menu item in "accessories"
On Mint just press the "prnt scrn" button on the keyboard.
18 Apr 2021 01:17 #206252 by paulstenlund
The screenshot didn't quite work, when you click shoot it closes the pull down machine menu, so you get the Linux main screen, but the top half of the "Machine " menu is greyed out
Paul
20 Apr 2021 12:35 #206526 by andypugh
Replied by andypugh on topic Machine controls greyed out
This sounds like e-stop is active.
Perhaps the new parallel port has a different default pin state. Or perhaps it simply hasn't been found.
20 Apr 2021 12:36 #206527 by andypugh
Can you attach the HAL file so we can see your e-stop net?
21 Apr 2021 21:59 #206720 by paulstenlund
don't know how to print/capture the hall file. I can go to HAL config and look at the settings, where do I find e-stop?
Paul
