Machine controls greyed out
21 Apr 2021 22:41 #206728 by andypugh
Replied by andypugh on topic Machine controls greyed out
Hit the "reply" button, then click the "go to editor" link lower right and then there is an "attach file" button.
23 Oct 2021 15:34 #223996 by paulstenlund
Replied by paulstenlund on topic Machine controls greyed out
Ok, I'm back. I just can't deal with complicated linux commands at my age. Can any one give me a link to a card that will work for sure?
Thanks much
Paul
23 Oct 2021 21:20 #224034 by paulstenlund
The pc is a Dell optiplex 7010 can anyone name a parallel card that is known t5to work with linuxcnc
Paul
  • Moderator
  • Moderator
24 Oct 2021 00:00 #224047 by tommylight
Replied by tommylight on topic Machine controls greyed out
Does 7010 have PCI or only PCI-E slots?
For PCI ones, i had several types, all of them used MosChip/NetMos chipsets and all of them worked (and still are working) with LinuxCNC.
No PCI-E so far, mainly couse i could not find them here.
24 Oct 2021 00:32 #224051 by paulstenlund
It has both slots the not working port was in PCI-E . I'd sure appreciate a list od PCI cards. Amazon could have one here Mon
Paul
25 Oct 2021 00:54 #224159 by paulstenlund
tommylight
Do you hve a pci card for me?
thanks
Paul
  • Moderator
  • Moderator
25 Oct 2021 01:17 #224164 by tommylight
Yes, but the shipping will cost me 65 Euro !!!
I am in Kosovo, our postal service was bought by Deutche Post a while back, they gave up and just plain left it, bikes and cars and vans also!
The only thing that works properly in that regard is DHL, post office is hit-and-miss with receiving stuff and just refuse to ship anything abroad from here.
28 Oct 2021 12:30 #224576 by andypugh
If I was looking on Amazon then I would probably try:
www.amazon.co.uk/Controller-IEEE1284-Par...ATIBLE/dp/B0010V7K8S
Avoid any where the main chip is small and low down, those tend to be using a general purpose chip that needs a driver at boot-time to become a parallel port. And the driver is Windows-only.
Or: Get a 5i25 which is better than a Parallel port card, and will definitely work.
25 Nov 2021 03:12 #227553 by paulstenlund
Installed a PCI parallel card
Run sample config paraport test and all pins showed green
created a config, it failed - can't find paraport 1 of many msgs
cofig probs -- Need help
Paul
27 Nov 2021 21:49 #227780 by andypugh
I think that you can ignore the message about parport1 if you are using parport0 (you probaly are).
It's a slightly spurious message from a part of the system that we don't directly control, if I recall correctly.
What are the other error messages?
Time to create page: 0.175 seconds
