QTPlasmaC THC slow to respond causing arc loss
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 May 2021 13:39 - 28 May 2021 13:40 #210519 by bevins
How can I speed up the response of the thc? Mess with the voltage? I have no idea where to look.
I did not search the forums to be honest.... but I will just looking for a quick response maybe that might help.
IT seems to be ok on thicker material but when I drop to thinner material and run at 190ipm on long cuts, it looses arc.
Last edit: 28 May 2021 13:40 by bevins.
  • snowgoer540
  • snowgoer540's Avatar
  • Moderator
  • Moderator
28 May 2021 13:53 - 28 May 2021 16:25 #210522 by snowgoer540
Replied by snowgoer540 on topic QTPlasmaC THC slow to respond causing arc loss
What is your Z axis Edit: MAX speed?
It sounds to me like your Z axis may not be fast enough to keep up as your XY velocities increase.
Also, some people have reported success with a P value of 10, and others have had to bump it up to like 20. Be careful though as too much P will cause it to oscillate due to over corrections.
Last edit: 28 May 2021 16:25 by snowgoer540.
  • bevins
  • Platinum Member
  • Platinum Member
28 May 2021 14:16 #210525 by bevins
What is your Z axis setup speed?
From the manual: Note
Setup Speed has no effect on THC speed
So I left it and didn't touch it.
28 May 2021 14:20 #210527 by rodw
I've never changed the default setting.
Just check your shield cup is tight. I had it unscrew a few days ago so the arc was a lot longer than it should have been.
If your heights are OK, try knocking the speed down with a speed override to 80%
  • bevins
  • Platinum Member
  • Platinum Member
28 May 2021 14:43 #210532 by bevins
Yeah the shield cup is tight.
Cant slow down as it would affect the cut.
  • Moderator
  • Moderator
28 May 2021 15:02 #210535 by tommylight
Replied by tommylight on topic QTPlasmaC THC slow to respond causing arc loss
If it is to slow, try adding this in hal
setp plasmac.thc-feed-rate 3000
or whatever in inches.
There is also the P value at 10 by default in the config tab of QTPlasmaC so i upped that to 12.
  • snowgoer540
  • Moderator
  • Moderator
28 May 2021 16:30 #210539 by snowgoer540
My deepest apologies. I meant Max speed. Trying to help you out while the lady fills the grocery cart. ¯\_(ツ)_/¯
So, what is your max speed set at?
The pin Tommy suggests is set from the ini file. And comes from the speed you set the Z axis to.
Sorry Tommy, but it is ill advised to manually set it to anything else. This is because your Z axis may not be able to handle changes that fast. So when you suggest to change it to 3000 (ipm in this case) the axis likely can’t handle that. At some point, it will cause issue.
  • Moderator
  • Moderator
28 May 2021 17:57 #210545 by tommylight
I did mention inches below it, 3000 in/m would be interesting !
Setting that in hal is not the best way but since i did skip those steps in pncconf i ended up with a feed rate of 0, and since Bevins is very experienced i though he might have skipped it to.
Sorry for the mess up...
  • snowgoer540
  • Moderator
  • Moderator
28 May 2021 18:30 #210547 by snowgoer540
Haha no worries, there’s been plenty of mess ups in this thread. At the end of the day, we all are just trying to blast metal with the power of the sun and help each other be successful.
Even if it doesn’t always seem like it.
  • bevins
  • Platinum Member
  • Platinum Member
28 May 2021 19:49 #210553 by bevins
I'll try these this weekend. Thanks guys
Time to create page: 0.137 seconds
