QTPlasmaC THC slow to respond causing arc loss
- phillc54
- Thank you received: 2100
30 May 2021 04:06 #210654
by phillc54
Replied by phillc54 on topic QTPlasmaC THC slow to respond causing arc loss
The velocity allowed for THC is determined from these variables in the .ini file:From the axis section, offset_av_ratio = 0.5 apportions 50% of the velocity and acceleration to the axis and 50% to the eoffsets so the THC maximum velocity from the above would be 10. This is the reason we use 0.5 and double the joint velocities in the axis section.
The SETUP_VELOCITY in the Paramaters Tab is used for moves to and from probe height, pierce height, cut height etc. not for THC.
THC is allowed the maximim velocity but is tempered by PID.
[AXIS_Z]
MAX_VELOCITY = 20
MAX_ACCELERATION = 200
OFFSET_AV_RATIO = 0.5
[JOINT_n]
MAX_VELOCITY = 10
MAX_ACCELERATION = 100The SETUP_VELOCITY in the Paramaters Tab is used for moves to and from probe height, pierce height, cut height etc. not for THC.
The following user(s) said Thank You: Clive S, snowgoer540
