changes in NML-interface?
- Reinhard
- Thank you received: 94
27 Jun 2021 12:43 #213017
by Reinhard
changes in NML-interface? was created by Reinhard
lately i have been busy elsewhere. When I checked my application now, I found that access to NML layer no longer works.
So I compared my testprog with axis/extensions/emcmodule.cc and found little to no differences.
But when I run my testprog, I get the following errors:
At the beginning this message rises:
later at polling status channel I get error at peek(), which obviously does not return EMC_STAT_TYPEI searched all known places, but didn't get the point.
Can someone please shine me a light about recent changes?
libnml/nml/nmlmsg.cc 93: NMLmsg: size(=5) must be atleast 16later at polling status channel I get error at peek(), which obviously does not return EMC_STAT_TYPE
if (!check_stat(s->c)) return NULL;
if (s->c->peek() == EMC_STAT_TYPE) {
EMC_STAT *emcStatus = static_cast<EMC_STAT*>(s->c->get_address());
memcpy((char*)&s->status, emcStatus, sizeof(EMC_STAT));
}Can someone please shine me a light about recent changes?
- Reinhard
28 Jun 2021 15:06 #213149
by Reinhard
Replied by Reinhard on topic changes in NML-interface?
I did some closer tests and it turns out, that the error is a timing issue, which is definitely new.
With former variants of LC I always got a valid response from peek.
And my app called peek/poll every 40ms
With the actual behaviour peek returns 0 and sometimes (? - unpredictably) it returns a valid response. That's not a nice behaviour for realtime communications.
When I take into account, that a human eye is capable of recognizing 24 images a second, than the delay between status calls turns out to be exactly 40ms.
Is there a way, to get faster status feedback from backend?
- Thank you received: 4149
28 Jun 2021 20:38 - 28 Jun 2021 20:39 #213170
Replied by rodw on topic changes in NML-interface?
Not sure if this is relevant but from an earlier post by another user, the tool table size was increased. I think its all sent with the status so the packet becomes too big to be sent in a timely fashion... I thought there had been some changes since but its just an equate somewhere.
Last edit: 28 Jun 2021 20:39 by rodw.
29 Jun 2021 22:19 #213279
Replied by andypugh on topic changes in NML-interface?
I don't think you will get an answer to this question on the forum.
You _might_ get an answer on the developers mailing list.
- Reinhard
30 Jun 2021 02:24 #213299
by Reinhard
Hi Rod,
thank you very much for your attention.
Yes, I already got rid of the tooltable changes. Tooltable size changes already happened when I stil was developing my app.
I noted that tooltable now has been extracted ...
What I don't understand - nml-api looks unchanged, but former peek() of status channel always (!) did return an address to an status buffer.
Actually 1 out of 10 calls the return is a valid address. 9 out of 10 times it returns 0.
The frequency of valid calls is so slow, that it makes no sense to use that api any more.
30 Jun 2021 06:08 #213311
I wonder if the addition of State tags also increased the status buffer? Its been over 12 months since I looked at the interp module but I thought it was attached to the status structure. Can't remember
30 Jun 2021 07:57 #213317
github.com/LinuxCNC/linuxcnc/blob/master...ns/emcmodule.cc#L293
It seems to be doing pretty much what you are describing. I wonder if it is working as badly there too?
How does the Python interface do it?Actually 1 out of 10 calls the return is a valid address. 9 out of 10 times it returns 0.
- Reinhard
30 Jun 2021 16:01 #213351
by Reinhard
Due to lack of understanding I followed a suboptimal template with my first try.
In the meantime I found a better one and now my access layer is straight forward and without any python burden. It looks a lot cleaner now
My testcase works fine, but for java runtime I need a library - and there I have a build problem:
I link my lib with these settings:I link my testcase with the same settings, but without the "-shared" flag. That testcase works fine.
When I load the lib created with the "-shared" flag I get this error:I don't know, what I'm missing.
When I try to build the library without the "-shared" flag, I get these errors:
Thank you Rod, but don't worry - everything is fineI wonder if the addition of State tags also increased the status buffer?
Thank you, Andy for your attention and support!It seems to be doing pretty much what you are describing.
LC_FLAGS = -L$(abspath lc/lib) \
-Wl,-rpath,$(abspath lc/lib) \
-shared \
lc/lib/liblinuxcnc.a \
lc/lib/libnml.so.0 \
lc/lib/liblinuxcncini.so \
lc/lib/liblinuxcnchal.so \
lc/lib/libtooldata.so.0 \
-L/usr/X11R6/lib -lm -lGLWhen I load the lib created with the "-shared" flag I get this error:
ibLinuxCNC.so: undefined symbol: _Z9emcFormatiPvP3CMSWhen I try to build the library without the "-shared" flag, I get these errors:
/usr/bin/ld: /usr/lib/gcc/x86_64-linux-gnu/8/../../../x86_64-linux-gnu/Scrt1.o: in function `_start':
(.text+0x20): undefined reference to `main'
/usr/bin/ld: de_schwarzrot_system_CommandWriter.o: in function `Java_de_schwarzrot_system_CommandWriter_init':
/d/java/SR/UI4LinuxCNC/native/de_schwarzrot_system_CommandWriter.cc:87: undefined reference to `emcFormat(int, void*, CMS*)'
/usr/bin/ld: /d/java/SR/UI4LinuxCNC/native/de_schwarzrot_system_CommandWriter.cc:94: undefined reference to `emcFormat(int, void*, CMS*)'
/usr/bin/ld: de_schwarzrot_system_CommandWriter.o: in function `Java_de_schwarzrot_system_CommandWriter_setFeedOverride':
/d/java/SR/UI4LinuxCNC/native/lc/include/emc_nml.hh:548: undefined reference to `StateTag::StateTag()'
/usr/bin/ld: de_schwarzrot_system_CommandWriter.o: in function `Java_de_schwarzrot_system_CommandWriter_setRapidOverride':
/usr/bin/ld: de_schwarzrot_system_CommandWriter.o: in function `Java_de_schwarzrot_system_CommandWriter_setSpindleOverride':
collect2: error: ld returned 1 exit status
make: *** [Makefile:60: libLinuxCNC.so] Fehler 1Please Log in or Create an account to join the conversation.
01 Jul 2021 22:48 #213461
That looks familiar, but annoyingly I have forgotten what causes nonsense symbols like that. But I have seen the same thing (not the exact same symbol, but something equally not-a-part-of-the-code) and managed to solve it, but then forgot what I did.
[/code][code]ibLinuxCNC.so: undefined symbol: _Z9emcFormatiPvP3CMS
- Grotius
- Thank you received: 2349
02 Jul 2021 03:34 #213472
by Grotius
Replied by Grotius on topic changes in NML-interface?
One of the library's is outside the standard linux library search path.
This will add the path :
sudo ldconfig /path_to_the_lib
Time to create page: 0.596 seconds
