- Thank you received: 280
You might be able to work around the need for a custom post processor, by building the nessisary post processing into a filter in Linuxcnc that automatically makes the nessisary changes to the files as they are loaded. I do this on several machines to convert g-code that was made for a different machine compatible with another.The velocity extrusion with some filters works very well. The cons are that it requires coding to post-process the gcode outputted from slicing softwares. As different slicers are writing the gcode in different manners, I don't think is the right way because you will be slicer-dependent.
Moreover to get the proper amount of extrusion it requires parameters as layer height and Nozzle diameter that are previously set in the slicer software. This software doesn't talk with linuxcnc and it generates human errors when the operator loads a gcode from time before and doesn't remember the slicing parameters. In synthesis, in my opinion, the velocity extrusion is a good workaround but it's not a final solution.
