- Thank you received: 18
Hi Doggie,
I saw your video and checked your gcode. In your case ( in the second video) the arc_blend option is working because you didn't have the A axis coordinate inside the gcode. If you execute the same gcode with A axis, I suppose that your second video will be identical to the first one.
