- Thank you received: 4
The video seems to indicate that the tool is engaged with a separate mechanism that tweaks the screw to add feed.Yes it is a cutting process. The tool is removing about 0.0001 every pass it makes. Once it has done a cycle of grooves say 4 it then gets raised by a mechanism that rotates a screw in the tool that pushes on a wedge that raises the cutter up.
I was imagining putting the raising mechanism on the same end as the indexing mechanism, so that the end of the barrel is completely unobstucted when the tool is retracted.The only problem i can see with having something attached to the cutters raiser screw, permanently following it along the barrel, is that you need to constantly check what depth the rifling groove is with special bore gauges.
