- Thank you received: 4
H1) Can you make a complete custom GUI with ini and hal files to suit for a machine that doesn't behave anything like a mill or lathe in linuxCNC.
We need to have 3 set up screens and one job monitoring/status screens. The machine has 3 axis's of sorts, hence the need for 3 set up screens. First screen is for setting linear movements along the barrel. Second screen is for tool rotation as the linear axis moves it along the barrel. This will set the rifling twist and no of grooves to be cut. And the last one is to raise the rifling cutter hook in the tool after a set of grooves has been cut.
2) If part one is possible with linuxcnc, can anyone recommend any reading/learning material to help us. Or any videos of similar projects to point us in the right direction. Any help or advice much appreciated.
You can rely on getting plenty of support here. FWIW I am also in the UK and used to shoot competitively. (but only at paper)Thanks for the pointers and links. Got some reading and understanding to do but it does look like we can achieve what we want with Linuxcnc. This is all a bit alien to us but will give it a try and hope we get somewhere. Otherwise its probably going to be outsourced to someone who does know what there doing.
Yes it seems a friendly community on here with lots of help. The problem I've got is the steep learning curve with this software and my lack of technical knowledge on the subject. I was brought up on manual machines and have had some experience on 2 axis CNC lathes for profiling the blanks but building a machine from scratch is a different game.
It's unlikely, I was shooting in the mid 1980s as a student, and using old rifles owned by the club. My preferred one was an immensely heavy Martini-action '22. Nobody else liked it, but I found the stability helpful. It didn't occur to me at the time, but it could have been very old.That's interesting you used to target shoot. Might of used one of our barrels maybe?
Apparently slight gain, for example, 1in8 at chamber to 1in7.8 at muzzle really helps accuracy in certain calibers.
