System Identification for control
5 years 2 months ago - 5 years 2 months ago #218540 by PCW
Well theoretically they are interchangeable via a Fourier transform
I suspect the main issue will be that the response to either
Step or Bode plot will be dominated by nonlinearities
Last edit: 5 years 2 months ago by PCW.
5 years 2 months ago #218607 by jang
How do you measure the response of your router?
I don't know router sorry,,, but I got data using ethercat. and so I can watch the data with halscope.
5 years 2 months ago #218677 by jang
thank you for your reply
I got some data about step command already
but I think the data can't be used for bodeplot
because bode plot require dynamic command and response like sine wave(in various frequency)
If I get the bode plot then I can know resonance(?) frequency or response which reached at -3dB
I have dual servo gantry system
Can I use stepgen in my linuxcnc ?? Or can I give velocity command with siggen???
First, I'll try with sim.axis example
5 years 2 months ago #218733 by aleksamc
As for me you will never get resonance freaquency in gantry system.
With increasing of the freaquency change, you will get decay of responce of your motor, it will overheet and may be, will give some smell. It all depends on your persistence.
Resonanse freaquency could be only in systems that has big PID regulator gains. You can increase this values - and resive resonance. I had such things. But if your gains in safe zone, you will never had problems with your gantry system because it's very inertial and has counterforces, if we spoke about cnc.
About stepgen I think it's witten in manual.
linuxcnc.org/docs/html/man/man9/stepgen.9.html
You need siggen set to the input of te stepgen, possibly.
5 years 1 month ago #219959 by Aciera
Just in case you are still working on this, you might be interested to look at external offsets. There is a simulation configuration called 'Dynamic External Offsets' under /configs/sim/axis/external_offsets that uses a sinus generation on the z axis.
Maybe this could be adapted to your needs.
5 years 1 month ago #220082 by db1981
Hello,
i don't think that trying this within linuxcnc will lead to an usable result...
Event with using an 2khz Servo thread, the resolution for getting an good result would be to low.
but you told that you are using ethercat, this drives are all from the "newer days"... all drives i know have internal functions to draw and record an bode plott.
Everytime we have done this, the controller runs on an 65us cycle time....
