What does this error code in linuxcnc_debug.txt mean?
- RékaM
14 Sep 2021 16:46 #220623
by RékaM
Replied by RékaM on topic What does this error code in linuxcnc_debug.txt mean?
Yes, I was able to figure it out with some googling, thank you!
- tripwire
- Thank you received: 12
29 Apr 2022 17:02 #241651
by tripwire
Replied by tripwire on topic What does this error code in linuxcnc_debug.txt mean?
If you find a solution, PLEASE POST YOUR SOLUTION SO IT WILL HELP OTHERS!!!
- RékaM
03 May 2022 15:38 #241923
by RékaM
I'm sorry, this was so long ago that I've forgotten, and I've moved on to a different project; I can try and poke through my old files and see if I can figure out what I did if you're having a similar issue.
- tripwire
04 May 2022 00:42 #241957
by tripwire
I don't need the solution. I was just mentioning this to say that, generally, if one is searching for solutions on a forum and happens to discover the solution independently, it's a benefit to others if the person posts the solution.
So you needn't bother poking into old files.
- Thank you received: 4652
04 May 2022 13:02 #241976
Replied by andypugh on topic What does this error code in linuxcnc_debug.txt mean?
- RékaM
09 May 2022 15:28 #242386
by RékaM
That comic just gets funnier the more time passes since 2003.
Yeah, it's kind of ironic that I never posted the solution here because I've had the same issue of someone with my problem but no solution so many times, and I bet you if I ever come back to this project I'll have similar issues... If I do I'll make sure to post my solutions when I find them haha
Time to create page: 0.188 seconds
